Old 02-21-2021, 11:17 PM   #1
DVH96
Drives: Brz 2016
Need help, White dust in the exhaust
I came back from work today. When I got home I realized there is white dust inside my exhaust tips. The car felt fine. Checked for codes and nothing showed up. Any ideas or tips would be appreciated!Name:  WhatsApp Image 2021-02-21 at 2.36.01 PM.jpg
DVH96 is offline   Reply With Quote
Old 02-21-2021, 11:24 PM   #2
BlOody_BoOger
BlOody_BoOger's Avatar
Drives: Hot lava FRS Monogram Charizard
Originally Posted by DVH96 View Post
I came back from work today. When I got home I realized there is white dust inside my exhaust tips. The car felt fine. Checked for codes and nothing showed up. Any ideas or tips would be appreciated!Attachment 197708
If you have an open flash. Or ecutek to see data logs. Look to see if your not running lean. It could be that.
Sent from my IN2017 using Tapatalk
BlOody_BoOger is offline   Reply With Quote
Old 02-21-2021, 11:59 PM   #3
DVH96
Drives: Brz 2016
Checked the AFR and it seems to be in a good range when under load.
Old 02-22-2021, 12:28 AM   #4
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
I was going to ask you what that white dust tastes like thinking it's road salt, but I see that you're in Mexico.
I'll guess maybe coolant residue from a possible blown head gasket?
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 02-22-2021, 12:39 AM   #5
DVH96
Drives: Brz 2016
OHH noo. I thought about it. Did the basic checks, no brown oil, no coolant discolor, no white smoke, no overheating. I guess ill take it to the mechanic shop this week for further inspection.
Old 02-22-2021, 01:28 AM   #6
Impureclient
Drives: 2015 FR-S
Check for catalytic converter failure.
The Following 3 Users Say Thank You to Impureclient For This Useful Post:
whataboutbob (02-27-2021), x808drifter (02-22-2021), zc06_kisstherain (08-31-2021)
Old 02-26-2021, 08:33 PM   #7
SuperSub7
Drives: Awesome
going to second about the catalytic - might want to check that out.
SuperSub7 is offline   Reply With Quote
The Following User Says Thank You to SuperSub7 For This Useful Post:
Old 02-27-2021, 12:42 AM   #8
CB750F
CB750F's Avatar
Drives: 2015 BRZ WRB
Sorry op, I can't help it....
CB750F is offline   Reply With Quote
Old 02-27-2021, 12:04 PM   #9
whataboutbob
AutoX-10/10ths every run
I had the cat in my stock header fail at one point and it covered the entire rear bumper of the car with dust that looked just like that.
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
jcw99 (03-05-2021), Lantanafrs2 (02-27-2021)
Old 02-27-2021, 04:37 PM   #10
norcalpb
norcalpb's Avatar
Well since he’s in Mexico maybe he ran over a brick of cocaine? /S
OP it’s probably your cat as mentioned above.
Old 03-01-2021, 01:50 PM   #11
Grady
Grady's Avatar
Could be running lean. Has the car been modified or tuned?
Old 08-13-2021, 01:03 AM   #12
Palmermc
Hello,
I was curious if you ever figured out what was causing the white dust. I had exactly the same thing happen to my car this past weekend. Also nothing weird with the oil or coolant. I’m suspecting a damaged cat. Eager to hear what you learned.
Thanks,
Mark
Palmermc is offline   Reply With Quote
Old 08-31-2021, 02:21 PM   #13
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by Palmermc View Post
Hello,
Thanks,
Mark
replace front pipe with catless pipe (upgrade) and see what happens
Old 08-31-2021, 04:08 PM   #14
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Code:
Palmermc
Trader Rating: 0 reviews
I think what'll happen is his car won't smog and he's going to be SOL.
WTB: Shifter Linkage Dust Boot & Shifter Dust Boot Erick.Hnandez Want-To-Buy Requests 6 01-27-2021 06:58 PM
white powder thing in my exhaust tip 2JZ-GTE Engine, Exhaust, Transmission 14 01-08-2015 01:51 AM
Brake dust or rail dust? Dealership bs? Muskokan Issues | Warranty | Recalls / TSB 12 12-21-2013 10:30 AM
white Frs bites the dust Fallen43 CANADA 8 10-06-2013 09:49 AM
White M/T FRS with exhaust $23k yayforaddison Cars for Sale/Trade 1 03-29-2013 10:59 AM
