| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2020 BRZ rs
Do dealerships replace “cricket” fuel pumps under warranty?
I’m in western Canada about to pull the trigger on a brz or 86. Has anybody in Canada had any luck getting either Subaru or Toyota to replace the stock pump under warranty?
#2 |
Wheels for Brains
Depends on the model year and mileage/age of the car.
There is no guarantee that switching pumps will make the crickets go away. It's usually due to interactions with the fuel, mainly ethanol content and additives and how they impact fuel lubricity. |
#3 |
Drives: 2015 BRZ WRB
Buy Shell, you won't have no more crickets.
#4 |
Drives: Crapcan
I run shell and have crickets
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Jfheisenberg (03-03-2021) |
#5 |
Drives: 2020 BRZ rs
Gotcha, so after market stereo is the way to go. Just adjust the volume until you can’t hear any crickets or anything else aside from sweet tunes!
| The Following User Says Thank You to BitusB For This Useful Post: | ToySub1946 (02-22-2021) |
#6 |
Drives: 2015 BRZ
Yep, if the TSB shows that your is car affected by the fuel pump chirp and your car is still under factory warranty they will replace it. I had mine replaced years ago without a problem.
| The Following User Says Thank You to Vital For This Useful Post: | Dadhawk (02-23-2021) |
#7 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
#8 | |
Like the guys said the fuel pump replacement is a Service Bulletin not a recall so the car has to still be in warranty for it to be no charge.
#9 |
Howdy
Drives: 2020 BRZ PP
I thought crickets were a result of crappy gas and the direct injection pump? My car was doing it and switching to Chevron premium helped. It is still a bit noisy in the morning, but I just accepted it as a fact of owning the car; I didn't know they would replace it.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
#10 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | BrahmaBull1990 (02-22-2021) |
#11 |
Wes
It's just a sound, there's nothing harmful happening. I've been filling up with Petro 94 since day 1, and it chirped but it either stopped or I'm used to it, 75000 km later I don't even think about it.
Instagram: @gt86ws
#12 | |
Drives: 2016 Scion FR-S
Fuel quality is a factor in hearing the crickets or not. For me, they show up in the winter, and go away in the summer. I always use 93 octane. So I wouldn’t say it’s only because of poor quality fuel, but a combination of that and temperature. For me anyway. Oh one other thing I noticed. When I bought my car, I heard the crickets at idle. I’m guessing they threw in the least expensive 89 octane fuel. After getting a full tank of 93 in there, the crickets disappeared. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to JesseG For This Useful Post: | BrahmaBull1990 (02-22-2021) |
#13 | |
This is why it is so hard to narrow down cause and affect. No two people seem to have the same results no matter what fuel, temperature, additives, driving style, etc. etc they tried. The good news (for me) is that I have never had a peep out of the 2020! Oh and 89 octane fuel is no poorer quality than 93 no matter what marketing you wish to believe. It is just a difference in in knock resistance not a measure of quality
#14 | |
I was just thinking that also, I’ve had the crickets at random times even when it’s warm out. So there isn’t much rhyme or reason to it. Typically with winter fuel I get the crickets more, but it’s random. That’s really good news the 2020 doesn’t have it. They must be using a different high pressure fuel pump, or different internals. Sent from my iPhone using Tapatalk |
| Tags |
| crickets fix, warranty |
| Parallel Fuel Pumps | RedFR-s | Forced Induction | 31 | 03-16-2022 05:50 PM |
| Have to replace entire assembly to replace fuel filter? | tobkin | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 08-04-2017 03:26 PM |
| FS: OEM Fuel tank with pumps | MicheleAbbate | Exterior Parts (Aero, Lighting, Etc.) | 3 | 06-02-2016 04:08 PM |
| Aeromotive 325 fuel pumps | 1stGenBRZ86 | Forced Induction | 12 | 05-05-2014 07:22 PM |
| Please read if swapping fuel pumps | Dipstik-sportech | Forced Induction | 5 | 06-17-2013 03:39 PM |
