Old 02-20-2021, 09:43 AM   #15
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by darkbasicmaster View Post
My daily commute is quite a lot, I have a 2013 FRS and it’s the only vehicle I have. I have 126k miles on it and I just recently changed the transmission fluid on it. Other than regular oil changes, what else can I do to make this last with a long daily commute. For a month it’ll probably be 200 miles a day. Right now it’s about 130 ~.
the limit of a vehicles lifespan is directly related to how willing one is to maintain and fix what's broken on the entire vehicle.
https://www.autoweek.com/car-life/a1...on-mile-truck/
every one of these 'million mile' stories, they go through multiple transmissions, sometimes engines, and dozens of other parts.
“Things are gonna break,” says Hudson. “I just fix it as it needs it.”
follow the owners manual service intervals, and be aware of the normal noises. if it's making a noise that's not normal, be willing to either fix it, or pay someone to fix it.
The Following 4 Users Say Thank You to soundman98 For This Useful Post:
aghuman (02-25-2021), Dadhawk (02-25-2021), Grady (02-22-2021), Tcoat (02-20-2021)
Old 02-21-2021, 12:26 AM   #16
Decep
Drives: 2013 FR-S Series 10
Originally Posted by GT86xz View Post
Hi everyone. I have a Toyota Mark II and it went 300 thousand miles without major repairs. I believe that almost all Toyota models will behave as well. It's — reliability indicator.
sir this is a Wendy's. I mean, this is a Subaru.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following 3 Users Say Thank You to Decep For This Useful Post:
BrahmaBull1990 (02-22-2021), soundman98 (02-21-2021), strat61caster (02-25-2021)
Old 02-21-2021, 01:23 AM   #17
Snake
Drives: ADM Toyota 86 GT
Only flog it when it's up to temp. Take it easy when it's cold.
Sent from my CPH1979 using Tapatalk
Snake is offline   Reply With Quote
Old 02-21-2021, 07:04 AM   #18
alone1i
Not pro yet
Drives: 2020 Toyota GT86
Subarus are unreliable, is it a impression?
alone1i is offline   Reply With Quote
Old 02-21-2021, 08:23 AM   #19
WNDSRFR
Drives: FR-S,GTI
My Subaru-Toyota-Scion seems to be very reliable.
The Following 3 Users Say Thank You to WNDSRFR For This Useful Post:
alone1i (02-21-2021), Dadhawk (02-25-2021), humfrz (02-21-2021)
Old 02-21-2021, 11:14 AM   #20
soundman98
soundman98's Avatar
subaru's gained a notion in the modding community for being unreliable because guy's wanted to turn the boost up on their wrx's, and still expected to do hardcore, grippy tire, full rev, 0-100mph launches. then they were shocked when the transmissions blew up, or had head gasket issues from turning the boost up too far...
alone1i (02-21-2021), humfrz (02-21-2021), Tcoat (02-21-2021), x808drifter (02-21-2021)
Old 02-21-2021, 01:23 PM   #21
Some individuals had issues so they apply their own experiences across the board. They just ignore the millions that had no problems and focus on their individual experience supported by anybody else they can dig up that had the same.
The reverse applies when you get people saying that the Honda XXX or Toyota YYY were "bullet proof". Thiers was fine so they band together with others of the same opinion and ignore everybody that had issues.
It is simply human nature to find the people that support your opinion and say it is the truth.
alone1i (02-21-2021), Hoahao (02-22-2021), soundman98 (02-21-2021)
Old 02-21-2021, 05:21 PM   #22
g e
I got 250,000 miles out of a 1985 VW Golf.
Couple of clutches, lots and lots of front boots, changed all belts and hoses every 70000 miles .
Finally got to a point where there were 5 $500 items that needed fixing. AC condenser one of them. Sold the car for $900 and bought a new 2000 Passat. Got 145,000 out of it.
g e is offline   Reply With Quote
Old 02-21-2021, 10:36 PM   #23
CB750F
CB750F's Avatar
Drives: 2015 BRZ WRB
Our cars are Subarus.
I had a Suzuki(18 yrs) that made it to 170,000 miles. Motor & trany was changed.
OP, as most said, just follow maintenance.
CB750F is offline   Reply With Quote
Old 02-22-2021, 05:40 PM   #24
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
I use to have a '94 Accord back in the day,and one morning I was dropping it off for some repair work(don't even remember what was being done),and another mechanic from another shop who knew the owner was bs'ing about customer's expectations. The one thing that will always stick with me is when he said that every used car owner should allocate around $2500 per year strictly for auto repair and maintenance. You figure aside from just oil changes,you also have other stuff like new tires,shock/struts,tie rods,ball joints,CV boots/axels,tune ups,and the list goes on and on,and it's easy to see that this is a pretty good amount to have in reserve,and that's not even counting the unexpected repairs.
Personally,I feel like that theory should kick in around 100k miles on any car,and maybe even sooner for a lot of cars out there.
Th3rdSun is offline   Reply With Quote
The Following User Says Thank You to Th3rdSun For This Useful Post:
soundman98 (02-23-2021)
Old 02-24-2021, 02:40 PM   #25
aghuman
aghuman's Avatar
Drives: 2013 Asphalt FR-S
I 'm just over the equivalent of 200k miles on my 2013 and have been doing the same thing most people have noted here which is routine scheduled maintenance and checking into things when something feels off. You'll know your car pretty well by now so it should come somewhat instinctively when something needs to be addressed. Aside from routine stuff, other work that needed to be done on mine thus far is a rear wheel bearing, preventative clutch replacement from a failing TOB, failed alternator and one bad coil pack.
aghuman is offline   Reply With Quote
The Following 2 Users Say Thank You to aghuman For This Useful Post:
CB750F (02-24-2021), soundman98 (02-24-2021)
Old 02-24-2021, 08:35 PM   #26
CB750F
CB750F's Avatar
Only changed TOB once?
I expect about the same at that millage, maybe a boot & axel too?
Old 02-25-2021, 02:43 PM   #27
aghuman
aghuman's Avatar
Yea just the single swap out at the equivalent of 130k miles. It wasn’t horrendous when I did it, just a minor noise but based on the other experiences people on this forum went through I knew it was the safe bet to just get it done with.
CB750F (02-27-2021), Tcoat (02-25-2021)
Old 02-25-2021, 04:12 PM   #28
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
NA Subarus have been pretty damn bulletproof from the 90's onward aside from having a bit of oil consumption issues (whether it's leaking out the seals or burning it). This car has been pretty decent, I have reasonable confidence to 150k miles, 200k miles is a question mark imho but it's not too expensive to fix if you don't go through a dealership and order all new parts.
ineedyourdiddly
alone1i (02-25-2021)
Following time or mileage interval for low mileage car? Ohio Enthusiast Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 06-08-2021 04:53 PM
New rims cut my 0-60 a lot more than expected Riftur Scion FR-S / Toyota 86 GT86 General Forum 133 04-21-2017 03:28 PM
Seeing more than expected? CLTBRZ BRZ First-Gen (2012+) — General Topics 26 07-09-2012 04:47 PM
Expected Price of car in 3-5 years? FRSDREAMER Scion FR-S / Toyota 86 GT86 General Forum 72 03-20-2012 07:44 PM
Not what I expected. Casual Scion FR-S / Toyota 86 GT86 General Forum 34 11-23-2010 08:25 PM
