#1093 | |
I only have vague memories, but I doubt it was a huge difference, but it is a cheap and easy way to get the max amount of potential grunt, before needing to upgrade those other "extras". I find E85 is great, but there are so many day to day hassles with both consumption rates and availability.... so I now only use it for "special" occasions. |
| The Following User Says Thank You to grumpysnapper For This Useful Post: | robv666 (02-12-2021) |
#1094 |
Drives: Toyota 86 GT
I see that the Edelbrock Supercharger ships with a 3.25” Pulley as standard. This equates to 82mm and I think this is with standard injectors and pump also.
They both use the TVS1320 core so boost levels I assume would be close to each other on a given pulley size. Would running an 85mm on 98RON with a Harrop be right on the limit of the standard injectors? Sent from my iPad using Tapatalk |
#1095 | |
Now they might have been trying to be "responsibly conservative" in their thinking, but I figured if I'm asking for advice from the experts.... I should probably take it. BTW you won't be disappointed with the power as it comes... its great fun! |
| The Following User Says Thank You to grumpysnapper For This Useful Post: | robv666 (02-13-2021) |
#1096 | |
Master Collaborator
If you're wanting to run the Harrop on the 85mm pulley, you should step up to 100RON. If that's not available, and neither is E85, you're going to have knock issues and poor engine performance. If you have E85 available to you and that's what you choose to burn with the 85mm pulley, you will need to increase fuel flow with a higher flow pump and at least slightly larger injectors. The Deatchwerks 300 seems to be a popular pick when it comes to a higher flow pump, and there are a few more choices on injectors. My personal set up will be the DW 300 pump, and Injector Dynamics 1050X injectors along with E85 and the 85mm pulley. |
| The Following User Says Thank You to FR-S2GT86 For This Useful Post: | robv666 (02-13-2021) |
#1097 | |
Drives: Q5 + BRZ + M796
I wouldn't.
#1098 |
The higher you go, the less noticeable it will be on pump gas. At some point, adding E85 will feel like you added a supercharger to your supercharger; ie, the jump from 95mm to 85mm is good, but the jump from 95mm to 85mm with E85 is like the jump going NA to 95mm.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | robv666 (02-13-2021) |
#1099 | |
The 85mm pulley should be used with 93+/98ron or E85. Even then, it may not be happy with the 93/98ron on hot days. I needed injectors to run the 85mm pulley with my tuner.
#1100 | |
https://www.ft86club.com/forums/show...14&postcount=6
#1101 |
Steve Bodalenko
Drives: Toyota 86 GTS
Just wondering what the drivability is like at low speeds with the ID1050? Harrop are of the opinion the DW700's are a better size, with flexfuel kit, because, in their experience, latency makes the 1050X's less attractive . They also think the OEM fuel pump is fine till you go to the 82mm pulley which I'm looking at. Even with that size pulley they still recommend the 700cc injectors.
#1102 | |
At very low load, all the driving is on DI. The moment where it transitions to DI + PI, with minimal PI, is when the 1050X really shines. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Bodalenko (02-16-2021) |
#1103 | |
Drives: 2016 Toyota 86 GT (Auto)
![]() TBH I don't know what temperature I'm measuring but I guess it is the coolant temp. can I measure the oil temp? Through the OBD interface type of guage? (P3 Guage) I already have a bigger radiator + built in oil cooler and I'm maxing out at 100c° BTW what are the average oem coolant/oil temperature range? Many thanks Unreal Sent from my ONEPLUS A6000 using Tapatalk |
#1104 | |
The questions are: 1- How can I fit better fan+Shroud to fit my setup? 2- what are the oem temp ranges for coolant/oil? Sent from my ONEPLUS A6000 using Tapatalk |
#1105 | |
1- Will it fit my setup? 2- Is it plug and play instal or does it require tuning? 3- What are the acceptable oem temp ranges for coolant/oil. Sent from my ONEPLUS A6000 using Tapatalk |
#1106 | |
2. it requires wiring. it does not require tuning 3. for this car, I'd say maximum temps are 225F coolant and 260F oil. Keep in mind if you see these temps, you're likely going to have thermal runaway and see higher temp anyways. These are MAXIMUM temps. You really should see a max of 212F coolant and 250F oil, 100C/120C |
| The Following User Says Thank You to CSG Mike For This Useful Post: | UNREAL (02-23-2021) |
| JDL turbo kit owners thread | yomny | Forced Induction | 1352 | 01-08-2025 04:20 AM |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 01:18 PM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
| Harrop car lip kit? | djdnz | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 12-15-2015 02:50 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
