#85 |
Drives: Crapcan
Actually I think my above response is wrong. I remember that spacing the sub frame to reduce anti-squat would have a negative effect on roll center, but since the MCA mod is just changing the mounting point for the trailing arm it probably doesn't have the same effect on the whole rear suspension setup and it's roll center.
#86 | |
Canada Eh!
Drives: '13 FRS
If MCA is hard to get, this is an alternative. (not sure if its been shared yet)
Not sure if its any good though... Quote:
#87 |
Drives: FR-S Whiteout
Thats how I used to paint my RC cars. Except in rasta colors. lol
Intent > Content
cowardice is the mother of cruelty. |
#88 | |
Drives: JRSC BRZ SOLD
| The Following User Says Thank You to PulsarBeeerz For This Useful Post: | jeepmor (04-06-2022) |
#89 | |
Drives: 2016 BRZ
It should be noted that by going this route you are applying solid metal inserts into the bottom bushings of the subframe. The silver pieces are for the rear mounting points while the front brackets have the insert built in. I'm not saying it's a bad thing but if someone already has a ton of bushing replacements back there this could possibly send you over the edge of comfort (unless of course....racecar). |
#90 |
Random question. But if you guys had to choose between a trailing arm relocation kit, or keeping Verus suspension covers, what would you do?
I can't add the traction mod without cutting away at the covers. |
#91 | |
I have the STi bushings, and upper STi spacers, that is tolerable for street use, but fitting lower spacers too kills your comfort. |
#92 | |
Drives: 2016 BRZ
Look at the shape of the silver inserts and then compare them to the attached images of the Whiteline inserts/instructions. Only adding inserts to the front and leaving the rear stock doesn't sound like a great idea. Not looking to derail this thread into a bushing discussion anymore than this though. |
#93 |
Drives: Corolla GT
It looks like the bushing inserts are a direct copy of the WL inserts or vice versa. In the literature for the gpspworts traction arm it also mentions this "By installing this product, it is possible to bring out more stable traction performance while fulfilling the same function as "Rigid member collar".
It looks like its better to install this part than the bushing inserts and still maintain the 'comfort' ( read as less noise ). But then the subframe will still move around a bit. If someone makes a video with either traction mod, MCA or the gpsports, in combination with the stock bushing then we may have a clear view. But the thing is, each achieves traction through different routes. But both can be done together? Do they have an additive effect? It doesn't seem to be for everyone, since not everyone is looking for so much traction in the rear. Some of us like to have a loose rear end for some fun whereas some people need better rear traction for competition purposes. |
#94 |
Drives: 2017 86
Suspension mounts came. It was hard to order but they came three days later!
Really well packed & stickers! |
#95 |
Drives: 2017 86
Put them in, no added NVH or anything negative, the car felt pretty planted before so I'm not sure if there is any benefit but I'm happy.
| The Following User Says Thank You to e30cabrio For This Useful Post: | solidONE (02-06-2021) |
#96 | |
Define "planted". Rear end behavior over mid corner bumps? Corner entry? On the throttle? Seems like this would make the rear end less dramatic and more predictable through the suspension stroke. Feels like a good mod in my mind. Enough to want to test it out. lol Those red and black ones look snazzy, i'm sure the price tag matches.
Intent > Content
#97 |
Drives: 2017 86
I only drove about 40 miles. The car has a Nameless header, heimholtz overpipe, catback, P-Tuning flex fuel ECUTEK tune, Eibach sports, Konis, Blox sways, Whiteline endlinks 235 45 17 GT radials so it is well sorted. It's hard to tell from that short trip what these changed.
I'm waiting for 18" GRAM LIGHTS 57DR & Continental ExtremeContact Sport 235/40ZR18. The Gram Lights are back ordered until at least May. Last edited by e30cabrio; 02-07-2021 at 06:56 PM. |
#98 |
Drives: 2017 86
After about 80 miles more the car hooks up better and stays much more firmly planted during all manner of changes in direction and from changing road conditions. Worth every penny!
| Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? | davidchoi | Cosmetic Modification (Interior/Exterior/Lighting) | 49 | 11-22-2014 11:17 PM |
| "Clicking" or "knocking" caused by rear seat pull down lever. | husker741 | Issues | Warranty | Recalls / TSB | 6 | 11-27-2013 03:30 PM |
| "My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) — General Topics | 48 | 08-09-2013 07:34 PM |
| Factory suspension "sticktion" | andrew20195 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 04-02-2013 03:49 PM |
| "Official" Suspension/Brake Thread | NYC BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 06-27-2012 10:14 PM |
