#4005 | |
Cooling the oil is far more important than the weight you choose. I don't ever see over 225F oil temp. My car is at ~64k miles, still on the original engine, and is used mainly for track/canyon driving, and driving to/from venues/shops. I don't do much commuting in it at all; I have other cars for that. The car as many class/platform records, as well as championship wins. Just one data point, but imo, a particularly strong one. |
#4006 | |
Drives: Q5 + BRZ + M796
https://racing.tgr-europe.com/wp-con...anual_EN-1.pdf I'm happy with my 5w30 Signature Series oil from AMSOIL. Good enough. Cheap enough. American made.
#4007 |
Drives: Drives like a crab.
Hi,
I'm in the process of buying a used Edelbrock kit. Could you advise me on the things I need to check before purchasing and various parts (like gaskets) I should buy for a clean and proper install? Thank you. Plus, has anyone tuned their kit with OFT? Thanks² |
#4008 |
Drives: 2014 WRB BRZ Limited
Another random question... is anyone running a lightweight battery with this kit? Does it hold up ok? My stock battery died, so was thinking of going with a Braille 14115 (11.5 lbs) to help counteract the weight I added with the supercharger...
I assume it takes a little more to crank the engine with the SC... and there is the water pump for the SC cooling system that runs after the car is turned off.... so is a smaller battery a bad idea? I was originally going to get a Duralast gold but then noticed it was 7.5 lbs heavier than stock. The only thing I don't like about the Edelbrock kit is the extra weight which I can definitely feel in corners. So reducing that as much as possible would be nice. |
#4009 | |
Drives: 2015 FRS
Just use ECUtek, you already saved money by purchasing used anyways. Don't cheap out on the most important thing IMO. Last edited by ninjan00dles; 01-26-2021 at 11:24 PM. Reason: updated |
| The Following 7 Users Say Thank You to ninjan00dles For This Useful Post: | CSG Mike (01-19-2021), Decep (01-19-2021), Griever423 (02-28-2021), Lonewolf (01-20-2021), nos145 (01-19-2021), SexyPirates (06-29-2021), Wil (01-19-2021) |
#4010 |
At some point edelbrock changed the intake to no longer require the sealing grease. I think they no longer recommend it because it can gum up the MAF.... but not sure if the part number for the filter changed or not.
| The Following User Says Thank You to BR-ZED For This Useful Post: | ninjan00dles (01-19-2021) |
#4011 |
Drives: 2015 FRS
Good heads up, it’s mentioned in my install guide. I will call them
#4012 | |
You're mentioning an install guide. Where can I find it? Plus, it it that bad to tune with the OFT? My goal is rather simple and conservative: 260hp at first. I just want something ultra safe to start with. Last edited by Wil; 01-19-2021 at 08:33 AM. |
#4013 | |
Drives: 2015 FRS
Who will tune it for you on OFT? |
| The Following User Says Thank You to ninjan00dles For This Useful Post: | CSG Mike (01-19-2021) |
#4014 | |
Drives: 2015 FRS
The wet air filter oil will potentially contaminate the MAF sensor and cause drivability issues. Edelbrock support told me you can use a K&N degreaser to remove the oils from your wet air filter if you don't want to purchase a new dry filter. They said that a dry filter will have a lighter color on one side. A wet filter will be the same color on both sides and will have oil on it (of course). |
#4015 |
Drives: 2013 FR-S Series 10
so they say you can just run a wet K&N filter dry? that doesn't sound right.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
#4016 |
Drives: 2015 FRS
That’s what they told me. I have a dry filter anyways but wanted to pass that info along. You could always email/call them if you don’t trust the information, they have excellent customer support
#4017 | |
I was thinking about Shiv or Wayno. Or https://www.facebook.com/STAutosport, only Belgian dudes I know who tune on OFT. |
#4018 |
nerd
Drives: 17 Limited PP BRZ
Totaled my car with a nasty sideswipe. No engine damage or anything like that, so I'm having the shop that did my install do a back-to-stock before insurance collects the car. Any tips for what to do before selling the kit?
What can I do to bolster confidence in a potential buyer when I say that I'm selling a used kit because I totaled my vehicle? She runs like a dream and hasn't given me any trouble in ~12k miles, but I know hearing that would probably make me nervous. I've thought about making a video of cranking the car, letting it warm up, then a few idle revs. Can't drive it because I smacked the rear wheel pretty good and most likely caused some problems in the rear diff. |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 11:09 PM |
