Old 01-18-2021, 10:02 AM   #1
M0nk3y
Switching EcuTek Tunes (X Company to CSG)
I've tried my best to research but just to avoid inaccurate info I'm posting this topic.
Currently, I have a EcuTek tune from "X Company" (there is no need to mention the company. The tune is fantastic and I've ran it successfully for the past 3 years).
I have a PTuning FF Kit I'm about to install, and as such switching my tune to a FF Tune from Zach @ CSG.
Question is: When it comes time to send my file to Zach, my current tune is obviously locked to "X Company" and cannot be edited from someone else, correct? Would I have to re-flash my ECU to a stock config file?
Reasons why I'm asking. I have multiple revisions of my current tune, however I don't have any stock file within those revisions. My car was initially tuned on a Dyno and further revisions done via email. It looks like my file is ZA1JF40C. Would this be the correct stock file to flash and then send off the CSG? Or could I just send my current config file and have Zach go from there?
Thanks for the rather dumb question.
Kyle H. - #89 STX
Old 01-18-2021, 10:06 AM   #2
jflogerzi
jflogerzi's Avatar
You don't send your current file. Zach at CSG will send you a new base map based on your current mods/setup and you will flash over your current tune as your ecu has a license on it. He will then ask you to log with certain logging points selected. He will then send you revisions based on the logs. Rinse and repeat till tune is done
2013 Series 10 FRS #553
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
CSG Mike (01-20-2021), DarkPira7e (01-18-2021)
Old 01-18-2021, 10:30 AM   #3
M0nk3y
Does he need my actual stock base map or will he simply pull it from a stock ROM file?
I guess that's my misunderstanding. Just trying to figure out if I need to go ahead and find my stock file at all.
Kyle H. - #89 STX
Old 01-18-2021, 12:27 PM   #4
tomm.brz
Drives: brz 2017 hksv2
he needs no map from you, as the others said he will send you directly what you need
tomm.brz is online now   Reply With Quote
Old 01-19-2021, 12:32 AM   #5
jflogerzi
jflogerzi's Avatar
Nope. No need for a base map file. Zach already has access to all MY stock files.
The Following User Says Thank You to jflogerzi For This Useful Post:
M0nk3y (01-20-2021)
Old 01-20-2021, 07:26 PM   #6
CSG Mike
CSG Mike's Avatar
Zach would be working off of CSG base maps; you don't need to send him anything.
You'd effectively be tuning from scratch, but you'd also be gaining everything that has been integrated into the CSG base maps, and effectively getting the best possible tune that is available at the time of your tune.
Just make sure he has a complete list of modifications on your car, as well as your model year, transmission type, and region (e.g. USA).
M0nk3y (01-20-2021)
Old 01-27-2021, 08:23 PM   #7
Grady
Grady's Avatar
And please do not report back with your results or felling on the new tune. I have a feeling it may cost me money!
The Following 2 Users Say Thank You to Grady For This Useful Post:
CSG Mike (02-02-2021), DarkPira7e (01-27-2021)
Old 01-27-2021, 11:41 PM   #8
jflogerzi
jflogerzi's Avatar
Just do it! Zach at CSG is one of the best tuners for this platform
Old 01-28-2021, 09:05 AM   #9
M0nk3y
I'll most likely be posting up time delta from improved lap times
JDL 4-2-1 + E85 + Zach =
This. Very stoked this is in the works
Kyle H. - #89 STX
Old 01-28-2021, 10:17 AM   #10
Grady
Grady's Avatar
I know he tuned my car up until the last revision to help with LSPI.
Old 06-24-2021, 11:39 AM   #11
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
What has been integrated into the CSG base maps beyond the basic tune?
Mike_ZN6 is offline   Reply With Quote
Old 06-24-2021, 11:41 AM   #12
jflogerzi
jflogerzi's Avatar
That's secret sauce as with tuning there are more than 1 way to skin a cat. Don't worry your in good hands. Just enjoy the process and reap the rewards at the end. The car will drive fantastic
Flex Fuel kit, tunes - switching between fuels Nigruto Scion FR-S / Toyota 86 GT86 General Forum 3 04-25-2020 09:49 PM
Switching from OFT to Ecutek stlgrym3 Software Tuning 17 08-20-2018 06:39 PM
ecutek racerom map switching trevorthepanda Software Tuning 7 06-25-2018 10:17 PM
EcuTek map switching with OFT? andrew5826 Software Tuning 25 05-10-2014 04:23 PM
ecutek map switching defroster ft86me Software Tuning 8 08-04-2013 03:09 PM
