Drives: Toyota 86 2014 GTS
Drivers seat clicking when driving...
My seat clicks on acceleration and deceleration and going around corners of going over bumps on the road. It’s constant and it annoys the living shut out of me. Any ideas? Anyone heard this problem before? Yes I’ve take. The seat out and inspected underneath. Nothing I can see. The bolts have been torqued to specification. So it’s not loose.. cheers.
| The Following User Says Thank You to Biggumzzz For This Useful Post: | spike021 (01-19-2021) |
#2 |
Does it still do it if the seat is moved up or back a notch or two?
Maybe try giving the moving parts a shot of silicone spray or WD-40 -
| The Following User Says Thank You to humfrz For This Useful Post: | Biggumzzz (01-18-2021) |
#3 | |
I’ve adjusted the seat every way possible and the noise persists. I’ll spray the moving parts with some silicone spray soon. Hopefully that helps. It’s driving me insane
| The Following User Says Thank You to Biggumzzz For This Useful Post: | humfrz (01-18-2021) |
#4 | |
Just guessing here -
#5 |
Rust bucket enthusiast
Have you made sure the bolts are torqued down enough? I've had to re-drive a couple of mine.
Be wary not to over bubba them though, they won't come back out willingly. My car is probably one of the few Subarus I've sat in that didn't have some sort of groan or creak in the seat though.
#6 |
Drives: 86 GT
I had the same problem, though it was on at the passenger's seat - I have a RHD. It's the horizontal bar that adjusts the bottom seat position, try reseating the position and tap on the bar to ensure no freeplay.
| The Following User Says Thank You to Compelica For This Useful Post: | Biggumzzz (01-18-2021) |
#7 |
#8 |
But hmmm. It’s been making clicking sounds for months. Thought maybe adjusting the seat would’ve done something. I don’t know. I’ve kicked it and everything hahah. Nothing. I’ll try greasing it soon
#9 |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
Does it happen when you also have a passenger? On mine, it was the snap on passenger the seat belt strap. I put the seat belt inside the loop and snapped it in place; the noise has not returned.
#10 | ||
.It's annoying but never bothered fixing it since it kind of just blends in with the rest of the oddity/novelty noises this car makes. Will definitely follow along so if you find a good fix I can try it on mine .
Instagram: @spike.grc
#11 |
Meow
Drives: GT86 (now sold)
I've had my seat make a noise on turns for a long time now. It's really weird, I can hear a noise and feel an "impact" through my bum, but can't tell where it's coming from.
The seat isn't loose at all, there's nothing in the pouch behind the seat or under it, it's as if something was moving inside of it. LHD car and skinny driver. |
#12 |
Drives: 86 GT
Mine only clicks when there is vibration (eg. rough roads, vibration from engine with clutch depressed and below idle). There is a spring(s) that keeps the horizontal adjustment bar in position - to adjust the seating position the bar has to be lifted but for some reason the bar can also pushed downwards towards the floor. This allows the bar to 'chatter' when the chassis vibrates and you get that 'tinking' sound.
With a passenger on the seat the person essentially dampens it so it doesn't vibrate, or as much - will take a look to see what can be done in the coming days. |
#13 |
Drives: Neptune Blue 2019 Toyota 86
I always thought this was my snowbrush being tossed around the rear footwell, until one day I put the brush on the front passenger floor and still felt like something was clunking around hitting the rear of my drivers seat (LHD). I'll report back if I find anything with mine!
2019 Neptune Blue Toyota 86 • Gruppe-S UEL Catless Headers • OFT Stage 2 Plus (91)
#14 |
Drives: 86 GT
Managed to fix the rattle. Just wedge a piece of paper like in the image below. The paper will restrict the movement of the bar moving downwards, and will keep the bar held in its resting position.
![]() Do not put too thick of a paper (approx 5mm is good enough) or the seat will not latch properly - you can tell this is happening if the seat wiggles even when the latch happens. |
| Drivers seat clicking sounds when driving? | Biggumzzz | Issues | Warranty | Recalls / TSB | 6 | 03-06-2021 06:13 PM |
| Drivers' Seat Clicking on 86 | toijin | Issues | Warranty | Recalls / TSB | 26 | 01-21-2021 02:15 AM |
| Clicking noise while Driving stops when Clutch is pressed | Inteze | Engine, Exhaust, Transmission | 12 | 04-09-2020 02:07 PM |
| clicking noise from drivers side rear | CARBONGT86 | CANADA | 11 | 08-23-2015 07:58 PM |
| RHD drivers seat | Basti | Want-To-Buy Requests | 0 | 09-07-2013 02:31 AM |
