Old 12-03-2020, 10:05 PM   #169
burnt_toast
Drives: 2017 BRZ CWP
Originally Posted by APEX Race Parts View Post
My apologies for the late reply. COVID and other factors have kept our production team on their toes, but the good news is that we do have the new ARC-8 17x9" ET35 finally going into production this month. This means wheels will be ready to ship to customers prior to 2021 track season.
In regards to the spoke profile, it has to be a profile 1 like the current 17x9" ET42 in order to clear the PP Brembo brakes, etc. BBK clearance is a non-negotiable for us
For enthusiasts looking for a more concave spoke design, I would urge you to look at our new EC-7R forged wheel line. These wheels offer the best of both worlds, brake clearance and spoke concavity.
- Ryan
Hey Ryan, no worries! I caved in last weekend and ordered a set of Arc-8s in bronze during the sale. They got here yesterday and they look awesome, very happy. At first I wasn't into the nearly flat profile, but now I love how beefy it makes the car look. There was a scratch on one of them but luckily it'll be covered by the tire, so no big deal.
I'm trusting my Filipino brother @pinoy_dorifto that these wheels/SX2's will clear my Sachs/RCE Yellows with minimal camber for the time being while I look into my coilover options.
Thank you Ryan and the Apex Team
burnt_toast is offline   Reply With Quote
The Following User Says Thank You to burnt_toast For This Useful Post:
APEX Race Parts (12-17-2020)
Old 12-17-2020, 03:35 PM   #170
APEX Race Parts
FT86Club Official Vendor
APEX Race Parts's Avatar
Drives: Launch-Year Whiteout FR-S
Black Friday was a great time to acquire a set of wheels. We appreciate your business and hope you enjoy them!
That is certainly an interesting place to see a scratch, and we are sorry to see that. Our wheels are packaged with safety in mind (double boxed with lip protectors), and in the rare case damage does occur, it is typically at the lip of the wheel after our friends at UPS has gone all Ace Ventura on us Thankfully the location of yours will be covered by the tire as you mentioned, but please reach out if I can assist further.
- Ryan
APEX Race Parts is offline   Reply With Quote
Old 01-06-2021, 07:22 PM   #171
Jedifar
Drives: 2022 Toyota GR86
Need help
Interested in getting some wide 245 40 17 Hankook RS4s for my ARC-8 17x9 42+ wheels
I have PP struts with TRD springs and running Verus camber plates.
Would I have any issues with fitment with no spacers? Any rubbing with fender or strut?
I do have a 3mm spacer but would want to avoid running them (not sure if ill need extended lugs for that)
Jedifar is offline   Reply With Quote
Old 01-06-2021, 10:34 PM   #172
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Originally Posted by Jedifar View Post
Need help
I have these on pp struts with TRD springs. It is insanely close up front with 245/45 tires- with the 3mm spacer you should be ok, I'm getting 5mm spacers for mine because it's literally credit card width away from the spring perch. Depending on how wide the RS3s run, you may be safer than ne- I'm on Bottom NT555Rs
Leonardo (01-07-2021)
Old 01-07-2021, 03:37 PM   #173
Jedifar
I figured. Would I need extended studs to run 3mm on these ARCs (this configuration would be track only)?
Do you have any rub otherwise (fender, lining, etc?)
I'll most likely be going with 235 rs4s in that case just to be on the safe side
Old 01-07-2021, 05:17 PM   #174
DarkPira7e
DarkPira7e's Avatar
Talking
To be fair, my car hasn't run in the year I've owned these, so I can't say if they rub at full lock. I'd guess no. You should be ok on stock studs, but if you're doing track, I'd bite the bullet and upgrade them anyway
Old 01-09-2021, 11:19 PM   #175
Racenut
Racenut's Avatar
I'm so pleased with these wheels. They look exactly how I wanted them to when I ordered them. Ready for track day #1 tomorrow.
Racenut is offline   Reply With Quote
The Following User Says Thank You to Racenut For This Useful Post:
APEX Race Parts (03-02-2021)
Old 02-28-2021, 10:23 PM   #176
wywern209
Drives: 2014 BRZ Limited
Planning to pick up a set of these soon to go with a set of continentals or michelins in 245/40R17. My 2014 BRZ is lowered on eibach prokit springs and I would like to know if these will fit/not rub without spacers. I did see that some others have their cars on prokit springs in the thread.
wywern209 is offline   Reply With Quote
Old 02-28-2021, 11:23 PM   #177
jflogerzi
jflogerzi's Avatar
It's more about camber and offset. The stock struts have a bigger spring perch which could cause issues.
2013 Series 10 FRS #553
Old 03-01-2021, 11:56 PM   #178
wywern209
What if I'm not interested in running any camber? Is there enough room between the tire/wheel and the spring perch? I don't really want to deal with running spacers or stud extensions.
Old 03-02-2021, 12:17 AM   #179
Racenut
Racenut's Avatar
My tires are 235/40-17. I put the wheels on before I put the coilovers on just because I was anxious to see how they looked. With the stock strut and spring, I could not get my finger between the tire and spring up front. But, I did drive around for several days like that without any rubbing. 245's, especially if they are a "wide" 245 might rub.
Old 03-02-2021, 07:47 PM   #180
APEX Race Parts
Our ARC-8 17x9" ET42 will work great with the non-Sachs stock suspension and 245/40-17 Michelin PS4S tires. No spacers are required as long as you are not dialing in camber at the knuckle (camber bolts compromise wheel to strut clearance unlike adjustable camber plates). The higher ET42 offset keeps the wheel tucked under the fenders for a flush fitment without poke so that camber is not a requirement.
For enthusiasts running the PP Sachs struts (which have a slightly larger silhouette), or for enthusiasts that plan to dial in camber at the knuckle using camber bolts, we recently developed an ARC-8 17x9" ET35 which will position the wheel 7mm further away from the strut thus avoiding the need for spacers. Due to the more aggressive offset, a touch of negative camber is recommended to prevent the wheel and tire from poking.
Edit: The new ARC-8 17x9" ET35 is now live on our site! LINK
The idea is to give 86/BRZ owners both 9" fitment options to ensure drivers can acquire a wheel that best suits their specific needs without compromise.
- Ryan
The Following User Says Thank You to APEX Race Parts For This Useful Post:
Racenut (03-03-2021)
Old 03-03-2021, 04:32 PM   #181
wywern209
For enthusiasts running the PP Sachs struts (which have a slightly larger silhouette), or for enthusiasts that plan to dial in camber at the knuckle using camber bolts, we recently developed an ARC-8 17x9" ET35 which will position the wheel 7mm further away from the strut thus avoiding the need for spacers. Due to the more aggressive offset, a touch of negative camber is recommended to prevent the wheel and tire from poking. The new ARC-8 17x9" ET35 will be live on our site this week!
- Ryan
Would running lowering springs affect the need for spacers with the ET42 wheels?
Old 03-03-2021, 04:44 PM   #182
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
If the only thing in the suspension you're changing is the lowering springs, the wheel will have the same range of motion as with original springs, and will hit the same spots (or will not hit the same spots).
However, changing from original springs to lowering springs can affect how frequently something rubs and how hard something rubs if it does rub with original springs.
Wheel Directory: Volk Racing TE37 17x9.0 +36 03Z33 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 04-11-2018 02:58 AM
Wheel Directory: Volk Racing TE37 17x9.5 +40 B L U E S L A T E Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 06-04-2017 12:29 AM
Wheel Directory: Volk Racing CE28 17x9.0 +38 Dpark27 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 03-14-2015 08:34 PM
Wheel Directory: Volk Racing TE37 17x8.0 +36 / 17x9.0 +36 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 46 05-06-2014 01:19 AM
Wheel Directory: Volk Racing TE37 17x9.5 +40 / 18x10.0 +44 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 04-16-2013 08:28 PM
