#2423 |
ProCrastinationConsultant
So I just learned there were tarriff exemptions on graphics cards that expired January 1. The card I was planning on getting is now $120 more...
#2424 | |
[insert cool phrase here]
Drives: BRZ Premium
So, just wait a few weeks/months. If you can.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | soundman98 (01-08-2021) |
#2425 |
Because compromise ®
Drives: Red Herring
I've just purchased Valhalla. I was desperate for something new to play. I am expecting a reasonable game with much exploring to do. I do think Ubisoft does open worlds quite well with just enough story to tie things together. I am disappointed to read that there isn't much assassination to do. That is, no more sneaking about which is something I quite enjoy.
I have finished my second complete play through of 2077 and I've had enough of the game after 193 hours. I won't uninstall it yet (I remove games I am no longer playing) because I will probably get the urge to visit the city again but probably won't stay long.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | Dadhawk (01-08-2021) |
#2426 | |
In Odyssey, you "could" sneak around, but it wasn't a real requirement. Also, there were two of my favorite items missing, besides the hidden blade which is inexcusable its not there, double assassination and the poison dart that makes NPCs attack each other. I used those extensively in earlier games. I know the hidden blade is in the "First Blade" story but the player never actually gets one. There is also an item that extends assassin damage to surrounding NPCs but it isn't the same as a double assassination.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#2427 |
Drives: Red Herring
Here is my 1 hour playing Valhalla impression: it's a reskinned Odyssey and/or Origins.
Surprise!
#2428 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Returned my Asus power supply that couldn't fit in my new SFF build. So with the credit, I bought another Corsair ML140 Pro fan for my intake. After reading a bit, for my Evolve Shift 2, it seems a fan with good static pressure is better for getting air into the case with all the cables in the way. I also have this fan for my exhaust as it seems to fit a good balance between static pressure and air flow. Plus it comes with a white LED which matches the AIO and GPU lights!
| The Following 2 Users Say Thank You to weederr33 For This Useful Post: | Dadhawk (01-08-2021), soundman98 (01-08-2021) |
#2429 |
Microsoft did the Flight Simulator update in December that allows it to work through OpenVX with VR headsets. Finally tried it tonight.
I have an Oculus Quest 2 headset. Instead of using the QuestLink cable I use Virtual Desktop sideloaded to allow wireless gaming. After making a registry change required for Virtual Desktop to work, I booted up Flight Sim. All I can say is the visual view from the cockpit is amazing. Yes, it still looks like a video game since the resolution is less 4K but I honestly felt like I was sitting in the cockpit. The view from the Cessna 172 was exactly right. Unfortunately I wasn't able to really fly much because its a "do it yourself" configuration. I have to map controls etc, and I don't have my flying controls connected so as hard as it is to fly with keyboard, its harder still when you cant see the keyboard. I did manage to get it up and moving a standard rate of climb by doing it outside the headset then putting the headset back on. It's a little glitchy, I need to play with the setup, but it definitely has the potential to be a VR must have. It felt much more natural than trying to fly the screen. I mean, I had depth! More to come as I have time to play with it.
| The Following User Says Thank You to Dadhawk For This Useful Post: | Spuds (01-09-2021) |
#2430 |
Drives: Red Herring
Here is my 5 & 1/2 hours playing Valhalla impression: it's a reskinned Odyssey and/or Origins.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | Dadhawk (01-09-2021) |
#2431 |
Decided to restart my playthrough of CP2077 now that I got familiar with all the things. And I'm noticing all the little details. A V's apartment there's a lovely reference to Demolition Man with the sea shells by the toilet
| The Following 2 Users Say Thank You to weederr33 For This Useful Post: | Mr.ac (01-12-2021), soundman98 (01-10-2021) |
#2432 |
Drives: '16 BRZ Limited
Not sure if this is the right thread to ask in, but I recently built a pc and needed a help/recommendation for a smaller cpu cooler fan.
The issue i run into is that one of the fans that came with the cpu cooler touches the top of the RAM and leaves the case unable to close. The cooler comes with 2 140mm fans with a circular casing which from what I've been told is the same mounting point as a standard 120mm square fan PC Build Sheet for those that are interested Motherboard: MSI X570 Tomahawk wifi Processor: Ryzen 5 5600x Cpu cooler: DeepCool Assassin 3 RAM: 32gb G Skill Trident Z Neo 3600 (16-19-19-39) Graphics Card: Asus RTX 3070 Dual OC SSD: SK Hynix Gold P31 1TB Case: DeepCool CL500 PSU: NZXT C750 |
#2433 | |
The Dictater
Drives: '13 Red Scion FRS
#2434 |
i'd just pick a heatsink with a smaller fan. i tend to pick fans like tires.
first, i find one that looks aesthetically pleasing. then i check the reviews. then i buy.
| The Following User Says Thank You to soundman98 For This Useful Post: | Dadhawk (01-13-2021) |
#2435 |
Drives: BRZ Premium
If you need to replace your cup cooler I would run your build by PC Part Picker.com
It should tell you what fits and what doesn't. You can always ghetto rig one fan to be slightly higher. Either by super glue or zip ties.
#2436 |
Be Kind
Drives: 2020 86
Started playing Sea of Thieves...
Day one was rough.
| Tags |
| pc master race, u no have 3080 |
| gamers lounge | Touge_ninja | Off-Topic Lounge [WARNING: NO POLITICS] | 25 | 01-21-2014 05:32 PM |
| GT Acadamy Gamers Banned from Britsh GT Pro-Am | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 16 | 02-11-2013 07:37 PM |
