#15 |
Drives: 2017 Toyota 86
So, am I reading right that E85/flexfuel and boost requires injectors and fuel pump upgrades? I'm not really interested in high HP numbers, but I like the idea of running E85 for safety since its readily available where I live.
#16 |
Drives: brz 2017 hksv2
you need injectors for sure, pump is not mandatory usually but suggested
anyway@BRZ_88 , only 30hp dispersed between crank and wheels is too few at peak power, it s higher |
| The Following User Says Thank You to tomm.brz For This Useful Post: | pallen (07-01-2020) |
#17 | |
Imperator
Drives: Supercharged 2013 BRZ Limited
If you're planning on going the forced induction route you will definitely need to replace them both to accommodate the increased fuel flow. |
| The Following User Says Thank You to BRZ_88 For This Useful Post: | pallen (07-01-2020) |
#18 |
Drives: 2017 toyota 86
Stock injectors with E85 is good to about 280whp it can handle 300whp but it’s close to the limits and advised to change but not 100% necessary. Beyond that you will most likely need to. Always check with tuner and their recommendations. I believe fuel pump is good till about 330-350whp on E85 before necessary.
| The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post: | brianbui23 (01-25-2022), pallen (07-02-2020) |
#19 | |
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | pallen (07-05-2020) |
#20 |
Drives: 2015 Lightning Red BRZ
Installing JDL kit now with a GTX2867R. The plan is somewhere between 6-8lbs of boost. I can't offer any personal experience yet, but the impression I've got from reading stuff here and talking to tuners, ~8lbs should be "safe". Every motor is different and if it blows up on the dyno, I'll be upset, but not really surprised. My goal (hope) is to stay low boost daily driving for a year or two until I can get a built block that can handle near 400, if I even want the extra power later.
I do know some folks with the JRSC who absolutely love them. I didn't get one because I may want more power later and superchargers have more limitations than turbos. Sent from my SM-G950U using Tapatalk |
| The Following User Says Thank You to zberz For This Useful Post: | JesseG (01-08-2021) |
#21 |
Drives: '13 Subaru BRZ Crystal Black Silica
I'm supercharged, sprintex s5-210 w/ intercooler kit running 9psi on 93 octane. Have been supercharged for more than 20k miles. When did I supercharge it? 88k. I purchased the car used at 55k without any prior knowledge of initial owner abuse or anything.
Fast forward to today, I have gone through two transmission, and everything else is still running fine. I have mods to help with the FI and I have a very safe tune from Open Flash Performance. My opinion, I am absolutely tickling the structural integrity of my connecting rods. If i take steps forward towards 12 psi, I would have already bent my connecting rods with this many miles.
IG: setgo.moto
| The Following User Says Thank You to Setgo For This Useful Post: | JesseG (01-08-2021) |
#22 |
Drives: Totaled 2013 Toyota Corolla
So I'm after similar if not slightly higher numbers (320-350WHP) with a supercharger on E85. Seems like Jackson Racing and Kraftwerks have been the most recommended. Are you on stock rods? I don't mind spending the money for better rods if it means I can push closer to 350WHP more reliably. Any other parts besides oil cooler, clutch and rods I should be looking at if I want to push towards 350WHP?
#23 | |
#24 | |
#25 | |
| The Following User Says Thank You to zberz For This Useful Post: | Mike_ZN6 (01-05-2021) |
#26 | |
Drives: 2013 FR-S Series 10
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
| The Following User Says Thank You to Decep For This Useful Post: | Irace86.2.0 (01-07-2021) |
#27 |
#28 |
| Stock Engine / Drivetrain Power Limits | lokiwho | Engine, Exhaust, Transmission | 13 | 12-18-2015 01:22 AM |
| FA20 Stock Capacity | Swivel | Engine, Exhaust, Transmission | 143 | 04-08-2015 03:12 PM |
| WTB FA20 Stock | Cross | Want-To-Buy Requests | 22 | 08-19-2014 03:59 PM |
| WTB FA20 Stock | Cross | Want-To-Buy Requests | 1 | 08-01-2014 07:47 PM |
