Old 08-24-2016, 11:21 AM   #253
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by clbembry View Post
Yup there's damage, it's visibly warped, and it leaks. Both my extended protective warranty and Scion CPO warranty so conveniently exclude all weather strips from their coverage so it looks like I'm SOL. After an hour on the phone with Scion they said they would have a regional manager take a look at it, but I'm guessing they're coming up with their apology as to why they can't fix it right now...
Yeah, theres a TSB for it. Here's the thread, its one of the ones near the bottom:
http://www.ft86club.com/forums/showthread.php?t=21868
Print it out, or call and tell them its covered under TSB. Good Luck.
It has priests in it?
Old 08-24-2016, 01:56 PM   #254
clbembry
clbembry's Avatar
I actually walked through the TSB with both the dealership and Scion Client Success. I pointed out how Scion CPO boldy claims "You don't have to worry. You're covered." and "Covers any repair or replacement of components which fail under normal use due to a defect in materials or workmanship" and that while I understand weatherstrips are excluded from the warranty, this is a case of defect in materials as highlighted by the TSB and therefor should be included in my opinion. I told the guy at Scion that it's subjective whether or not to exclude it in this case.
Anyway, went to the dealership and they said they got a call from Toyota to "Good Will" the repair so it's getting fixed, just not under my extended warranty or my CPO. It's a bit of a bittersweet feeling but at least it's taken care of. If anyone else runs into this issue and is outside of the 3 year/36,000 mile warranty I suggest following a similar route that I did.
clbembry is offline   Reply With Quote
The Following User Says Thank You to clbembry For This Useful Post:
HunterGreene (08-25-2016)
Old 12-30-2020, 03:57 PM   #255
Spankopotomous
Spankopotomous's Avatar
Necropost, back to the top you zombie!
Wind noise from rolled over door weather stripping is slowly driving me mad. After reading though this and other TSB threads I gave a Toyota Service center in Los Angeles a call.
$2k and change for them to do it out of warranty, only a couple hundred of that being parts.
I will forgo the updated switches and stabilizers. Replacing the front left and right door seals myself comes out to $190.
Anyone know if these are the correct updated parts? My google-fu is failing me
Mentioned in the TSB
SU00305207
SU00305208
What my local parts center has, and what I will probably purchase
SU00305803
SU00305804
Originally Posted by Blighty View Post
Code:
Yeah, I mean                    that absolutely should be appreciated more.
            it           engine
                is a great
Spankopotomous is offline   Reply With Quote
The Following User Says Thank You to Spankopotomous For This Useful Post:
T-Steve (01-01-2021)
Old 01-01-2021, 07:09 PM   #256
Decep
Drives: 2013 FR-S Series 10
Are these difficult to replace? I get some interesting wind noises but only at speeds i probably shouldn't be going so i haven't bothered yet. But it will only get worse.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Side by side cosmetic differences between BRZ and FRS/86 (same dimension lights) Moto-P FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 128 02-27-2019 08:25 PM
Side by side cosmetic differences between BRZ and FRS/86 (same dimension lights) Moto-P BRZ Photos, Videos, Wallpapers, Gallery Forum 109 08-19-2014 11:56 PM
Driver side door handle lordtakuban Cosmetic Modification (Interior/Exterior/Lighting) 19 06-19-2014 02:30 AM
Studying for Learner's Permit driver's knowledge test PACMAN Other Vehicles & General Automotive Discussions 2 01-03-2012 12:17 AM
Little request: FR-S vs GT86 vs BRZ side by side photos! EJ20 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 12-02-2011 01:53 AM
