| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: 2013 BRZ Lmtd
HID light ballast?
hey guys i'm trying to replace the ballast on these HiD lights that came with my used 2013 BRZ.
anyone know where to buy, which compatible model to get? KDLT003 koito? Last edited by sirelboe; 12-18-2020 at 10:51 AM. |
#2 |
Wheels for Brains
Those are OEM Ballasts.
You would probably be better off trying to source a whole used headlight than trying to get just the ballast. They go for ~300 for a pair these days for headlights |
#3 |
i can actually find the used ballast for around $30ea but i want new.. not trying to face this issue again in a few months. i just need a compatible model that would fit and be same voltages. we're also in a deep freeze rn on the upper east coast so i'm sure that stresses it harder on cold startup. i think that's what caused it to recently start acting up.
#4 |
can anyone confirm if this will work? says replaces Denso / Koito Models: KDLT003 / DDLT003:
https://www.amazon.com/gp/aw/d/B01N4...SEQWAA1I&psc=1 or this one actually says on the sticker: https://www.amazon.com/gp/aw/d/B07J5...0RNYCGE8&psc=1 |
#5 |
ProCrastinationConsultant
it would require modification, as the oem ballast doesn't use the same input wire type:
https://www.ebay.com/itm/FACTORY-OEM...temCondition=4
#6 |
Drives: Dodge Patitas
Late reply, but check with TRS if they have some. Ask them about photos/connections. Hope you solved your issue.
#7 |
FT8Syg
Drives: `12 FRS & `17 BRZ Inazuma
This is your opportunity to upgrade your hid bulbs & ballast to other good manufacturers like Diode Dynamics, GTR Lighting, etc. that have made great advances in lighting tech. I'd stay away from Amazon unless you're getting reputable big brands (Philips, Bosch, Osram, etc.).
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
| OEM BALLAST | 6spd | Want-To-Buy Requests | 0 | 06-06-2016 09:03 AM |
| WTB: OEM BRZ HID Ballast | Cheeto | Want-To-Buy Requests | 1 | 02-17-2016 02:12 PM |
| D4S Ballast and Bulb | Andrew025 | Exterior Parts (Aero, Lighting, Etc.) | 0 | 09-02-2014 01:36 PM |
| Wtb: 55w h11 ballast | Tr1huynh | Want-To-Buy Requests | 0 | 03-05-2014 08:40 PM |
| HID slim ballast Kit for 86 ? | TRD_86 | Cosmetic Modification (Interior/Exterior/Lighting) | 21 | 08-02-2012 04:50 AM |
