| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2015 Scion FR-S Firestorm
coolant question
Hi guys,
a few weeks back, I found out my frs had coolant very low in the reservoir tank (I think it's called over flow reservoir?). Back then I added distilled water (~0.5L, definitely less than a liter) in the overflow reservoir. Now the winter has come, it may fall -30C or under during the season, which hasn't happened yet. The previous owner kept the car parked outside all the time, so the coolant itself seems fine. Anyways, I was worried that adding distilled water would dilute the coolant, but as far as I looked up, if there was any liquid that has evaporated, 'only' water would have been but the actual coolant would have remained, so adding distilled water wouldn't hurt? I thought of checking out the coolant itself with the squeeze up bottle thingy with a dial in the middle (the thing that tells you the freezing point lol don't know the proper name for it), but I'm not sure where I can stick the tube and suck up the coolant in the first place. I wonder what you guys think. Thanks. |
#2 |
30 minute maintenance
Drives: My18 wrxsti
Get it out of the overflow bottle and put it back afterwards if you`re not sure
#3 |
ProCrastinationConsultant
get a bottle of super blue to keep on hand, toss some in to the right fill line, and go with it.
https://smile.amazon.com/Genuine-Sub...7877850&sr=8-1 the water is going to evaporate over time from hot/cold cycles, as it's not an entirely closed system, so just keep it topped up, and it'll be fine.
| The Following User Says Thank You to soundman98 For This Useful Post: | Ultramaroon (12-13-2020) |
#4 |
Squeeze bottle coolant tester thingy is a good tool. If you check it from the radiator cap, make sure the check valve on the cap is nice and clean before you reinstall it. 99.5% of the "I'm slowly losing coolant" issues are due to a leaky check valve.
After a few heat cycles, fluid in the reservoir is pretty much the same as what's in the system.
#5 |
Famous Potatoes
Drives: '15 ultramarine
Just drive it, you'll be fine.
And like soundman said, if it goes low again, top off with proper antifreeze. |
| The Following User Says Thank You to Sapphireho For This Useful Post: | humfrz (12-14-2020) |
#6 |
i used to buy the non-diluted stuff so i didn't need to pay for half-water, but after realizing my captain-n-cokes that ought to be around 50/50 are really about 90/10, i figured i'm not enough of a mixologist to do a proper job, so i ought to let someone else handle the mixture!
| The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
#7 |
Master Collaborator
Hydrometer.
| The Following 2 Users Say Thank You to FR-S2GT86 For This Useful Post: | SCFD (12-14-2020), thomasmryan (12-18-2020) |
#8 |
It'll usually take a few heat cycles for whatever is in the coolant overflow to mix with the rest of the system. Considering that you put in distilled water a few weeks ago, I'm assuming it's been enough time to not worry about it.
However, since you have a hydrometer on hand, just stick it into the overflow tank and take a reading. |
#9 |
Thanks for the feedback people.
Maybe what I wrote earlier wasn't so detailed. I put in distilled water like 2 months ago, so no doubt that it's been all mixed up with the rest of coolant. Albeit small amount (~0.5L), my main concern was the increase in the freezing point of the coolant since I'm living in Alberta, Canada where it drops below -30C from time to time, which hasn't happened yet thankfully. I don't have a hydrometer with me yet but will buy it at the end of the week and see if I can pull out some of the coolant to test out. IN CASE I HAPPENED TO FIND THE FREEZING POINT IS HIGHER THAN WHAT I WANT, is there a third party undiluted antifreeze that I can mix to lower the freezing point? From everything I read from this forum and other websites, they all recommend the OEM coolant, which is right, but it protects as low as -37C, which seems like a borderline to me.. Again, thanks for the comments people! |
#10 |
Drives: My18 wrxsti
If you see near -40 I have no Idea
I know a higher concentration of coolant lowers the freezing point but reduces the systems efficiency. Scary to be honest
#11 | |
Weight Weenie
Drives: 15 FR-S
In you case I would go to the dealership and get a flush and fill. It's cheap and can't hurt. I've lived in AB and -40C is no joke. You must use a block heater, no? |
| The Following User Says Thank You to new2subaru For This Useful Post: | suppjc (12-15-2020) |
#12 |
Yup, I have a block heater. On the other hand, I might be just overthinking, considering I've been ok with other cars in the past. I'll try the hydrometer to see how the antifreeze is in the coolant and see if I need to flush, which I doubt I need to because it's still a low mileage car (~60000km). I looked up the coolant exchange process, and it seems doable. I'll see how it goes.
Thanks. |
#13 | |
#14 |
Weight Weenie
Drives: 15 FR-S
Most anyone is capable of doing a flush. Most wouldn't want to do it at -20C
| The Following 2 Users Say Thank You to new2subaru For This Useful Post: | soundman98 (12-19-2020), Ultramaroon (12-18-2020) |
| Question about coolant | timmydatooth | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 35 | 11-04-2018 01:59 AM |
| Used FR-S coolant question | HECK EM ALL | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 10-03-2017 10:14 PM |
| Coolant loss - Void Warranty/ Edit: coolant flush question | BRZach | Engine, Exhaust, Transmission | 15 | 01-02-2016 09:21 PM |
| Coolant Question | fantah | Hawaii | 0 | 08-01-2014 06:06 PM |
| Coolant Question | boredom.is.me | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 04-15-2013 08:50 PM |
