Old 10-24-2020, 06:22 PM   #85
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Originally Posted by Ghost of Akina View Post
Damn that looks good! Gotta get me some TE’s!
#TE37theWorld
I'll have to fine tune the height after the suspension settles over the next few days. Then alignment/corner balancing. Just need to get the wing done and it's pretty much good to go from a cosmetic stand point.
The Following 6 Users Say Thank You to TylerLieberman For This Useful Post:
Ghost of Akina (10-24-2020), Lonewolf (12-15-2020), RToyo86 (10-24-2020), URACK (10-27-2020), Wally86 (12-14-2020), Z06ZN6 (10-24-2020)
Old 10-24-2020, 06:45 PM   #86
Ghost of Akina
Ghost of Akina's Avatar
Drives: DE5 Integra Type S
Originally Posted by TylerLieberman View Post
#TE37theWorld
What are you think for a wing? Going to go duckbill in this one to? Not sure if there is a good solution to the 17+ MY yet.
"Precision without speed is empty, speed without precision, chaos."
Ghost of Akina is offline   Reply With Quote
Old 10-24-2020, 06:58 PM   #87
TylerLieberman
Drives: '24 GR86
Paint matched Verus duckbill. Similar to the Leg one I had on the last car, but it covers the OEM 17+ holes.
Old 10-24-2020, 07:17 PM   #88
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Did you paint your lip or is it the raw ABS plastic?
I planned to run mine without paint but it was pretty scuffed up in the box upon delivery.
Old 10-24-2020, 07:23 PM   #89
Ghost of Akina
Round 2: GR Inspired Hakone 86
Oh I didn’t realize the Verus covered the holes. Might have to add that to my list for tS over the winter.
The Following User Says Thank You to Ghost of Akina For This Useful Post:
TylerLieberman (10-27-2020)
Old 10-24-2020, 10:13 PM   #90
Z06ZN6
Drives: 2017 Toyota 86
What an epic color combo. Best looking Hakone I've ever seen. Nice work.
Z06ZN6 is offline   Reply With Quote
The Following User Says Thank You to Z06ZN6 For This Useful Post:
Old 10-27-2020, 10:35 AM   #91
ka-titties
Drives: 2013 BRZ Limited 6MT
Fantastic color combination. This is going to look choice with the Verus wing.
ka-titties is offline   Reply With Quote
The Following User Says Thank You to ka-titties For This Useful Post:
Old 10-27-2020, 02:35 PM   #92
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
That steering wheel and start button are such a nice touch. I'll have to get in touch with that guy soon too.
Cephas is offline   Reply With Quote
The Following User Says Thank You to Cephas For This Useful Post:
Old 12-13-2020, 11:08 PM   #93
TylerLieberman
Drives: '24 GR86
Took the car out to another event yesterday. This time at Arizona Motorsports Park. First time driving the car since adding the suspension, wheels, and tires.
Brought along an old friend who I hadn't seen in almost a decade with his MKIV Supra. Bone stock. 40k original miles. First HPDE ever.
The course is a bit higher in speed compared to the last track, which was mostly 2nd and 3rd gear, with one upshift to 4th and then immediately back down. This track was consistently 3rd and 4th with one straight being enough for 5th gear.
This video was from my first session, which yielded my best time of the day of a 1:58.8. I kept running into traffic the rest of the day, which prevented me from bettering that time, but the app showed I was easily on pace a couple times to get into the mid 57s without much issue before having to lift/slow down for other cars. My initial goal was sub 2, so I'm happy to have gotten that. Now I'm aiming for the 55s lol.
Did a once over on the car today to check everything. If you listen in the video, you can actually hear a bit of rubbing going around left hand corners. It was coming from the front right, and was enough to wear the fender liner a bit, as well as bow out the front fender near the door a touch.
A bit of heat and some pushing and the fender popped back in place lol. It was only a couple mm difference anyways, so no big deal. I did roll the front right a touch more for some additional clearance but I can't really roll the fender anymore than it is now. These tires run a bit wide though too, and it was only an issue with a passenger. I would raise the car, but I love the current height and don't want to touch it. Plus, I'm confident that as soon as I switch tires, I won't have the issue anymore.
Checked tires and brakes too. Pretty even wear across from what I can tell, and wasn't rolling over the outer shoulder. Definitely got some temp in them though.
Sent a pic of the pads to CSG Mike and he mentioned some of the built up material on the pads, which he suspected might be partially due to the fact I've been using the same rotors when switching between stock pads and the CSG C2s. So I'm gonna get another set of rotors to run with these to help improve pad wear and feel.
Everything else was great. Everything still tight and solid. Oil temps never went over 200º, though the ambient temp was in the high 60s-low 70s all day. No oil burning, nothing in the catch can. Car feels strong.
The car felt plenty playful too. Would move around a little bit under braking and corner entry if trail braking, but would be pretty neutral with maybe a hint of rotation mid corner at higher speeds, but stable at slower speed and stable on corner exit. Push too hard and the front starts to scrub and the car pushes, as expected. But everything felt pretty progressive and easily managable. It never did anything rapidly or aggressively. I'm sure a better driver could find things that could be improved, but I'm happy.
Setup wise, I'm pretty content. Just need some rotors. I'll eventually add some JDL 4-2-1 EL headers + ECUTek, and maybe a TRD 4.56 rear end with a 1.5 way. But other than that, I'm pretty good.
The Following 5 Users Say Thank You to TylerLieberman For This Useful Post:
beltax90 (12-13-2020), brewloc (12-17-2020), Kiske (12-13-2020), Lonewolf (12-15-2020), Thefalls (12-14-2020)
Old 12-13-2020, 11:32 PM   #94
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Time for another set of todoroki's?
Old 12-14-2020, 01:40 AM   #95
TylerLieberman
Drives: '24 GR86
Nah, because then the gap would be huge lol. I’d have to run extended LCAs up front which would change the characteristics of the car.
These tires run big so I’m pretty confident that once I change them, it won’t be an issue. I did raise that the front ever so slightly. Like 1/4 of a turn on the collar lol.
I’m not really willing to go any higher. I’d rather rub and be slower
Old 12-14-2020, 03:37 PM   #96
thedollarbill
Drives: 13 ZN6
The car looks so good!!! Great driving too!!! I aspire my build to look as good as yours!
2013 ZN6 14r x TRD x STI Build Thread
instagram: @sllygoos
thedollarbill is offline   Reply With Quote
The Following User Says Thank You to thedollarbill For This Useful Post:
TylerLieberman (12-14-2020)
Old 12-14-2020, 09:09 PM   #97
TylerLieberman
Drives: '24 GR86
Thanks man! I still really want that Verus duckbill to help tie the exterior together. I want it like now but I wanna focus my money on prepping for the next event after the holidays lol
The Following User Says Thank You to TylerLieberman For This Useful Post:
thedollarbill (12-14-2020)
Old 12-14-2020, 11:28 PM   #98
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
The SLs with OG stickers look great. You should definitely go with the Verus duckbill, too.
Any plans for more power?
Mike_ZN6 is offline   Reply With Quote
The Following User Says Thank You to Mike_ZN6 For This Useful Post:
TylerLieberman (12-15-2020)
FS: CSCS Round 2 Time Attack Entry RedFR-s Canada Classifieds 5 06-21-2016 10:14 AM
86 Cup Round 12 - Chuckwalla Valley Raceway (CCW), 2:06.883 fastest time of the day mav1178 Tracking / Autocross / HPDE / Drifting 2 11-24-2015 01:53 PM
86 Cup Round 9 - ACS Roval, 2:03.94 fastest time of the day mav1178 Tracking / Autocross / HPDE / Drifting 5 08-11-2015 02:06 PM
Rev Speed presents: Tuning Car Time Attack 2nd Round - Tsukuba AVOturboworld Scion FR-S / Toyota 86 GT86 General Forum 2 04-19-2014 01:53 AM
Tax return time = WHEEL CLEARANCE TIME from Gram Lights and Yokohama vividracing Wheels and Tires 4 04-04-2014 03:46 PM
