Old 11-27-2020, 04:31 PM   #1
Grady
Grady's Avatar
P0300 Random cylinder misfire
Ok so I have an annoying P0300 happening during cold starts. Have a suspicion this may just be the nature of the beast with my mods. This seemed to start right after install of torque solution engine mounts. But has seemed to progressively get worse. I have attached 2 idle logs that show all cylinders displaying misfire conditions when cold. Once the engine is warm and all power pulls have reported 0 misfires. If anyone has any thoughts or experienced similar it would be appreciated.
In testing I have replaced PI’s and spark plugs. I have not done anything with DI’s or coils.
Mods are, AVO turbo, Light weight FW, DW700 injectors, NGK Racing plugs, torque solutions engine mounts, DT flex fuel, DT remote tuning.
Edit **It is a 2017 with 29k miles**
https://drive.google.com/file/d/1MlB...w?usp=drivesdk
https://drive.google.com/file/d/12BY...w?usp=drivesdk
Old 11-27-2020, 04:56 PM   #2
I get a P0300 code on mrs humfrz's Saturn, usually after she drives it. I erase the code and it stays away till she drives it again. Rinse and repeat.
Go figure -
Yes, it is another slow day in Puyallup -
p1l0t (11-27-2020)
Old 11-27-2020, 07:56 PM   #3
p1l0t
p1l0t's Avatar
I know you're post said DT flex fuel kit but what fuel are you running exactly? And from what state if it's pump gas? Since it's the P0300 and not a specific cyclinder I'm not thinking it is electric, although it could be.
Old 11-27-2020, 09:09 PM   #4
Grady
Grady's Avatar
Seemed to happen more on E85 but has happened on 93. Electrical/spark issues generally get worse with heat so have kinda ruled out but you never know.
Old 11-27-2020, 09:57 PM   #5
p1l0t
p1l0t's Avatar
Have you tried running a bottle of injector cleaner?
Old 11-28-2020, 08:25 AM   #6
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Engine mounts and lightweight flywheel probably aren't helping
Old 12-02-2020, 12:52 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Verify all the screws on the DI driver module are tight. They should be something like 86 in-lb.
HELP P0354 Cylinder 4 Misfire isaiah990 Issues | Warranty | Recalls / TSB 17 12-28-2019 11:38 PM
P0463, u0122, and P0301 Cylinder 1 misfire Shark_Bait88 Issues | Warranty | Recalls / TSB 0 08-12-2019 07:34 PM
P0300 random cyl misfire FRS Justin Issues | Warranty | Recalls / TSB 9 12-03-2017 05:02 PM
CEL P0300 & C1421 AfterFXNinja Issues | Warranty | Recalls / TSB 1 07-05-2017 08:11 PM
