#407 |
Drives: Whiteout track car; lava donor
Anyone using the Garmin Catayst (https://buy.garmin.com/en-US/US/p/690726)? My AIM Solo 2 is good, but this looks much better!
#408 | |
Drives: rocketship
| The Following User Says Thank You to sachu For This Useful Post: | Four_wheel_drifts (11-29-2020) |
#409 |
Drives: Crapcan
Word is the Ridge is about 2 sec faster with the new pavement
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | bcj (01-26-2021) |
#410 |
Drives: Nevermorange FRS
I can't wait and I also want to race with the Chicane in place.
When racing in mixed class group where you often time have different cars that run similar laptimes, just differently. Fast in straight, slow in turns or fast in turns and slow in straights. The long straight is frustrating for a momentum car that will put in lots of work/risk to make a pass in the turny bits only to have the horsepower car easily re-overtake them on the straight. By adding the chicane it allows the momentum car a better chance to retain their position once they've earned it and then get on with the race. Also the entry to the chicane is a much better passing zone than T1 ever was and now the old T1, because the entry speed is slow can act as better passing zone as well. I'm hoping this is overall a net positive as a 'racing' track.
SCCA T4 - FRS
| The Following User Says Thank You to rice_classic For This Useful Post: | NoHaveMSG (01-25-2021) |
#411 | |
Drives: rocketship
#412 |
That's a good piece of feedback. I'll let IRDC know that when they run it in late August. Maybe for the start of the race, bypass the chicane, then reset the cones after the cars go through. Or, throw the green flag after the chicane but that could make the next section sketchy... tough call.
SCCA T4 - FRS
#413 |
Drives: 2020 BRZ/86, 2020 BMW 330i
Took my 86 to Pacific Raceways for the first time yesterday, during a Power Lunch lapping with Proformance.
Definitely need an oil cooler, the temp was peaking around 235.4F(113C). Didn't want to push the car too hard. Also got off the track ![]() Too much speed and started braking a bit late. This is with pedal dance activated. This isn't the Ice Mode, right? Since the tire squeal is clearly heard, so the breaking force should be equal to the applied pedal pressure. Last edited by Arthur-A; 03-21-2021 at 11:22 PM. |
| The Following 3 Users Say Thank You to Arthur-A For This Useful Post: |
#414 | |
Drives: Crapcan
Northwest Track Days: Who, Where, When
235 is no big deal. It’s when you start hitting 270+ you really start dropping oil pressure. I’ll have to check out the vid later. You will for sure be wanting one before summer though. Sent from my iPhone using Tapatalk
#415 |
Drives: rocketship
signed up for next weekend at PIR for both days with HOD!!
Gotto get new brake rotors, transmission fluid and spark plugs done this weekend! Might have enough tire tread left on the Conti ECS to last both days.....hopefully
| The Following User Says Thank You to sachu For This Useful Post: | NoHaveMSG (04-11-2021) |
#416 | |
I’ll be there both days coaching and running. I need to confirm that Honey Bee Tire will be there to support us. If so, and you cord a tire, we likely can figure something out. If not, at worse, I have a few stock wheels and tires about 1/2 hour away from PIR. |
| The Following User Says Thank You to Four_wheel_drifts For This Useful Post: | sachu (04-12-2021) |
#417 | |
Still, if you need anything, come see me. White FRS with BRZ front bumper and now peeling black vinyl roof wrap. |
| The Following User Says Thank You to Four_wheel_drifts For This Useful Post: | sachu (04-14-2021) |
#418 |
Drives: rocketship
Thanks for the heads up. WIll come say hi for sure!
I do have a second set of wheels tires with BFG all seasons. My Maxxis VR1 set showed up yesterday but I am hoping to be able to squeak by with the COnti ECS this weekend.
#419 |
Drives: 2014 DMG BRZ
Just did a day at the ridge (first track day in..... 6? years!)
I had some weird things happening - I lose power steering up the hill in turn 2-3 for a few milliseconds, but it comes back immediately after the left up the hill. Does anyone else get that? |
#420 | |
Drives: Crapcan
Yes. It is power steering cutout or you may be running to low or too soft of suspension setup and you are hitting your fender liner with the tire. That 2-3 section is high loads. Sent from my iPhone using Tapatalk
| My BRZ at The Ridge Motorsports Park | alliedcam1 | Northwest | 2 | 08-30-2014 04:33 AM |
| The Ridge this weekend with NASA NW anyone going? | VIPwryann | Northwest | 6 | 08-24-2014 01:38 PM |
| Trail Ridge Road in my FR-S | Brett | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 0 | 07-12-2013 10:43 PM |
| AJ BRZ at Ridge Motorsports Park ! Take 2 ! | AJ PwR | Tracking / Autocross / HPDE / Drifting | 0 | 05-30-2013 05:05 PM |
| BRZ at Bay Ridge Subaru | Pakjk89 | NY / NJ / CT / PA | 0 | 03-27-2012 02:26 PM |
