#43 |
It's not valve springs. Poor idle and sudden improvement under load? No way.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Spuds (11-14-2020) |
#44 |
The Dictater
Drives: '13 Red Scion FRS
On today's episode of Spud's Subaru Saga, Spuds learns about in-tank rollover valves...
I need to get a thinner (and probably longer) hose... |
#45 |
Hose for siphoning? Tell me about the rollover valve. I don't see it in any diagram.
#46 | |
The Dictater
Edit:. To answer the first question, yes, I need a thinner and longer tube for siphoning. Not sure why I said hose lol. Last edited by Spuds; 11-15-2020 at 12:08 PM. |
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | Ohio Enthusiast (11-15-2020), Ultramaroon (11-15-2020) |
#47 |
I've struggled with that flappy valve in the past. How far can you get your hose? Does it maybe hang up on the sharp bend nearest the tank?
#48 |
The Dictater
It's hard to tell, there are a few bends I can feel it getting through on the way down, but hard to judge which is which when you can't even see the tube. I think a thinner hose might help a bit there as well.
#49 |
Transfer pump? HF has a good one for 10$
2013 Series 10 FRS #553
#50 |
The Dictater
#51 |
Long skinny tube? IDK.. I was tired when I posted this
![]() Sent from my GM1915 using Tapatalk
| The Following User Says Thank You to jflogerzi For This Useful Post: | Spuds (11-15-2020) |
#52 |
The Dictater
Alright, got the tank draining now, more on that later.
Any of you all know if there is a typical way to remove subaru seats without removing the rails? |
#53 |
The Dictater
Well, the good news is that I successfully replaced the fuel pump assembly without lighting anything on fire. The bad news is that it was ineffective in solving the problem...
Only other thing in the tank I can think of is the sending unit on the other side of the tank, which has its own fuel inlet and filter, feeding the pump through a line crossing above the tank. Maybe that is clogged or the line is messed up somehow? I guess injectors next? PS. Anyone need a perfectly functional OEM Subaru Tribeca fuel pump assembly? |
#54 |
Are you absolutely 100% sure that those plugs at 5 and 6 are firing? Can you get at the power for the igniters to unplug them while the engine's running? If it runs worse, or dies, then that cylinder was firing.
You can also remove the igniter and test it using a new plug and a ground strap. Testing is key. Think of how much time and effort went to replacing all that perfectly good shit. I've dealt with simultaneous seemingly-independent failures. It's rare but it happens. I've also dealt with a couple engines that were consistently wrong in how they reported misfires.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Spuds (11-22-2020) |
#55 | |
The Dictater
Yeah, there is a possibility that it is reporting misfires incorrectly. It definitely feels like a misfire, but it could be reporting which cylinders are misfiring incorrectly. |
#56 |
What would cause misfire through the first third of engine speed? Vacuum leak? Dirty MAF sensor?
| Troubleshooting a Leak with OFT | Lakitu | Software Tuning | 27 | 06-22-2018 02:31 AM |
| Troubleshooting Idle | bfsnail | Forced Induction | 3 | 12-03-2016 05:05 PM |
| BRZ DRL Troubleshooting | MaximaZero | Issues | Warranty | Recalls / TSB | 2 | 11-17-2015 03:31 AM |
| Troubleshooting with a KW c38 | pgranberg11 | Forced Induction | 7 | 10-13-2015 07:05 AM |
| Need troubleshooting help. | Camop82 | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 10-14-2013 01:16 AM |
