Old 11-07-2020, 04:31 PM   #29
I don't see how it invalidates the theory that a clogged fuel filter is preventing flow at lower pump settings.
Possible culprits:
1. Fuel filter is clogged
2. Fuel pump is dieing
3. Some fuel pressure regulation device is malfunctioning.
4. Coils/plugs
5. Alternator (possibly also the reason the battery was shot?)
I can probably check the the Alternator voltage output pretty easily, (obd readout or multimeter) to make sure it's at 14V+ right?
That just leaves 1-4. I think it's going to be more cost/time effective to just replace the filter and pump together than try to rig something together to figure out how to measure fuel pressure in a running engine and fi more diagnosis. If that costs me $300 and an afternoon to learn that wasn't it, well I learn better the hard way anyway lol. Plus, the filter at least is overdue for replacement anyway.
If that doesn't solve the problem, the plugs are due for replacement, and then coil packs. If I am still in the dark after that, well, it might be time to pay somebody to fix it...
Edit, first, I'm going to inspect the fuel lines under the car. I wonder if they may have been damaged when I got the cat inspected...
Fuel delivery issues are still in play but I can't draw a straight line to the counter-intuitive poor performance at idle while improving under power. That we are dealing with a returnless system invalidates only my specific case in support of Tcoat's observation.
Nothing wrong with replacing the pump assembly. It would eliminate 1-3 in one fell swoop. You still have to drain the tank to replace the pump. 300 bucks would buy lots of pressure gauges.
Definitely check the charging system. Do the headlights dim at idle? Does the engine stumble when everything's turned on? Cabin fan, headlights, brake lights all at once?
It occurs to me that we haven't discussed relocating coil packs. If the misfire is consistently on 5 and 6, swap a couple. They don't last forever. Worn (or conventional) plugs are hell on coil packs.
Spuds (11-07-2020)
Old 11-07-2020, 05:15 PM   #30
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Thanks for the ideas.
Fuel pump pressure is controllable electronically, so the best guess is it lowers the target pressure at lower rpm to put less strain on the pump, then steps it up as more fuel is needed. At some point that increase results in enough pressure to keep all 6 injectors going. It may not have a feedback loop in the control of the pump, so it is not adapting to increased pressure demand.
I think I might have a fuel pressure test kit from my grandfather, probably need a bunch of modern connectors though lol. What should the pressure be? I cannot seem find specs using my apparently weak google-fu. I suppose if it's lower at idle than it is primed but no flow that is evidence that the filter is the problem?
Everything electronic I can control works fine all together, and ecu voltage is still reading 14.2ish so I think charging is fine? Engine stumbles at low rpm as described, and is remarkably consistent.
Yeah I hear you on coil packs, but the chances of two different packs on different banks going at the exact same time are pretty low. I cleared the codes and checked again, still 5 and 6. I suppose it's cheaper to try to swap coils around before getting that in-tank assembly though...
The Following User Says Thank You to Spuds For This Useful Post:
Ultramaroon (11-07-2020)
Old 11-07-2020, 05:35 PM   #31
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
reset the codes, swap the coil packs to 1 and 3, drive and then check codes.
if it stays on 5 and 6, check the plugs. if the plug holes are swimming in oil, get the valve cover gasket kit for both sides.
thomasmryan is offline   Reply With Quote
The Following User Says Thank You to thomasmryan For This Useful Post:
Spuds (11-07-2020)
Old 11-08-2020, 04:01 PM   #32
Is that a thing for these engines? I can picture it.
Old 11-08-2020, 06:54 PM   #33
Spuds
The Dictater
Spuds's Avatar
Spent a few hours this morning shuffling plugs and coil packs around, using every single socket, wrench, and adaptor in my arsenal of course (ok just the 10mm and 12mm sockets and wrenches). Reset codes, still reports misfiring on 5 and 6. No visible damage to coils, plugs were dry and looked fine.
Sooo, fuel supply next?
At least I can say I've done spark plug stuff on a Subaru lol.
Old 11-09-2020, 06:49 PM   #34
Atmo
Drives: TBA
Another long shot: The misfires are isolated to #5-6, it isn't coil packs so yeah, something's off with fuel delivery.
I recall that D4-S mapping is compound DI/Port at lower rpm, exclusively DI at midrange, then both again at the high end. So, could the #5-6 port injectors be clogged? Maybe bench testing them would help.
Atmo is offline   Reply With Quote
Old 11-09-2020, 06:51 PM   #35
thomasmryan
Drives: hyper blue
see if the intake manifold bolts are tight on the drivers side. (it's an o-ring type gasket.)
Old 11-09-2020, 06:55 PM   #36
Spuds
The Dictater
Spuds's Avatar
Why would a Subaru car without Toyota's D4S have this problem?
Old 11-09-2020, 06:56 PM   #37
Spuds
The Dictater
Spuds's Avatar
Cylinders 5 and 6 are on opposite banks...
Old 11-09-2020, 06:58 PM   #38
Atmo
Drives: TBA
That's putting it nicely!
Old 11-09-2020, 08:21 PM   #39
thomasmryan
Drives: hyper blue
yes, i finally found the diagram in the manual. a google fail on my part.
the 06 manual shows a drain plug on the tank.
Spuds (11-09-2020)
Old 11-12-2020, 12:59 PM   #40
mrg666
pessimistic skeptic
mrg666's Avatar
coil packs
spark plugs
injectors
valve springs
My FR-S was checked in that order for the exact same problem. It was valve springs.
The Following User Says Thank You to mrg666 For This Useful Post:
Spuds (11-12-2020)
Old 11-12-2020, 03:05 PM   #41
Spuds
The Dictater
Spuds's Avatar
Originally Posted by mrg666 View Post
coil packs
spark plugs
injectors
valve springs
Well, I just ordered a fuel pump assembly, but good to know if that doesn't work.
Old 11-13-2020, 03:18 PM   #42
mrg666
pessimistic skeptic
mrg666's Avatar
I very much hope it is the fuel pump. Replacing valve springs requires engine taken out. Good luck.
Troubleshooting a Leak with OFT Lakitu Software Tuning 27 06-22-2018 03:31 AM
Troubleshooting Idle bfsnail Forced Induction 3 12-03-2016 06:05 PM
BRZ DRL Troubleshooting MaximaZero Issues | Warranty | Recalls / TSB 2 11-17-2015 04:31 AM
Troubleshooting with a KW c38 pgranberg11 Forced Induction 7 10-13-2015 08:05 AM
Need troubleshooting help. Camop82 Scion FR-S / Toyota 86 GT86 General Forum 6 10-14-2013 02:16 AM
