Old 08-01-2020, 01:00 PM   #1933
Compelica
Compelica's Avatar
Drives: 86 GT
Originally Posted by Compelica View Post
Appreciate the feedback. Just switched to full DI to 7200 RPM as per your recommendation to others; will report back. I'm aware of the less cleaning ability on 100% DI but I'm putting it on to test.
Got some logs after driving for about 165 KMs.
https://datazap.me/u/compelica/v1?lo...=17&mark=10278
Some observations:
1. AFR runs richer (was at 11.6 at 20% PI, now it's 11.4 at full DI above 5200 RPM range for range)
2. FLKC at -2 and -3 are now -.6 and -2 for the same rpm range (I'm assuming it's due to the charge cooling of additional DI but it could be the additional fueling as well?)
3. For the same rpm ranges (3200 to 5200), why am I seeing different LTFTs between two versions With 20% PI I'm seeing -1.79 but with full DI it's 0.3. Keep in mind that both tunes use 100% DI at that point. I'm assuming it should be the same since nothing was changed?
Also how can I determine if fuel trims are fully learnt? Right now my conclusion for the richer AFRs is that trims aren't fully learnt yet, but thoughts?
Compelica is offline   Reply With Quote
Old 08-13-2020, 07:51 PM   #1934
Gloonge
Drives: 2013 frs raven
Man I hate to be this guy, but could someone take a look at these logs for fuel trim issues. I am being tuned by shiv for my edelbrock sc, /w uel header. One is just a run out of boost from light to light, under 20%~ throttle. The other is just idling in my driveway switching the a/c on and off. Idk if I am reading to much into STFTs but they seem to shoot way up to +20% when the a/c is on and stay there. Shiv is taking longer than I would like to get back to me and unfortunately this is my DD that has already been down for 2 weeks.
https://datazap.me/u/gloonge/fuel-trims?log=1&data=
Gloonge is offline   Reply With Quote
Old 10-08-2020, 04:11 PM   #1935
BlOody_BoOger
BlOody_BoOger's Avatar
Drives: Hot lava FRS Monogram Charizard
How much time are you allowing for your ecu to stabilize fueling. You should at minimum drive the car 5O miles after a reflash before taking any parameters into consideration.
Sent from my IN2017 using Tapatalk
BlOody_BoOger is offline   Reply With Quote
Old 10-08-2020, 04:16 PM   #1936
Gloonge
Forgot to come back to this, it would continue well after 50 miles. It ended up being a bolt backed out on the a/c compressor. Guess it was tripping ou the knock sensor.
Old 10-08-2020, 04:17 PM   #1937
BlOody_BoOger
A bolt backed out? Like it was falling out?
Old 10-08-2020, 04:19 PM   #1938
Gloonge
Yea, I think I may have over tightened it when installing the super charger.
Old 10-09-2020, 12:49 PM   #1939
southside iraq
Drives: 2017 86
e80, what do you guys think, i think my clutch is slipping 4300-5300 rpm ?
, 19-16 psi
https://datazap.me/u/gillster91/log-...-31&zoom=0-448
southside iraq is offline   Reply With Quote
Old 10-26-2020, 09:43 PM   #1940
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Had the car on e85 for about 100km with this setup, but e85 for 1 1/2 tanks. If someone can have a look give an opinion I would appreciate it. I have read the whole thread and I think it`s alright. A couple of pulls and some normal driving. 1st pull 2nd and next one 2nd and 3rd
PSR uel headers and O/pipe
Invidia q300 cb
e85
2018 Brz Ts
https://datazap.me/u/gen3v8/1stlog?log=0&data=1
Old 10-27-2020, 05:14 AM   #1941
Boomerang
86
Boomerang's Avatar
Invidia q300 cb
e85
2018 Brz Ts
Looks pretty good but in the 3rd gear pull it starts running rich at 4000-6000 rpm.
Have you scaled your MAF?
Old 10-27-2020, 06:59 AM   #1942
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
No stock OFT V4.0x tune. 4th gear starts at 5200 rpm straight from 7500 rpm in 3rd @ 239.8. Other pull is 2nd and yeah I see the 13s But thats leaner?
Old 10-28-2020, 06:55 AM   #1943
Boomerang
86
Boomerang's Avatar
Oops yeah I meant leaner starting around 236.
Might want to scale your MAF still in this area..
Old 11-03-2020, 04:53 AM   #1944
LancePower
Drives: 2020 BRZ tS
Question on Wayno Tune
I ran the Wayno's Default Petrol Tune on 93 octane (USA) for 200 miles and did the Data Logging. The AFR @ 6500 was 11.02.
So I flashed the Lean 4% Tune and after 200 miles the AFR @ 6500 is now 11.6.
So I'm just below the 11.7 threshold.
For reference with the OFT Stage 1 Tune I was at 11.6 to 11.71 @ 6500.
What do ya'll suggest I do?
Am I okay at 11.6?
Would dropping to 91 Octane make a difference.
Thanks for your help!
LancePower is online now   Reply With Quote
Old 11-03-2020, 05:33 AM   #1945
Kodename47
Kodename47's Avatar
Drives: UK GT86
0.1 AFR is realistically going to make little/no difference. Remember it's a target but that doesn't mean it has to be that. Then the flip side is, how do you know the AFR reading is accurate? AFRs read from a single sensor are never accurate by their inherent nature. Just use the target AFR as a guideline - if it runs OK then it's OK. Richer is safer, you'll not make any more power by leaning up 0.1 AFR.
.: Stealth 86 :.
Kodename 47 DJ:
LancePower (11-03-2020)
Old 11-04-2020, 03:23 AM   #1946
DarkSunrise
DarkSunrise's Avatar
If anyone is curious, here are datalogs with a 2013 engine + 2017 OEM header + E85 (OFT 4.03).
Two second gear pulls here:
https://datazap.me/u/darksunrise/202...5?log=0&data=1
Third gear pull:
https://datazap.me/u/darksunrise/202...5?log=1&data=1
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
solidONE (12-30-2020)
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 02:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
