Old 10-19-2020, 12:40 PM   #15
SamtheKorean
September
SamtheKorean's Avatar
Drives: 2015 BRZ
Yes, it is definitely possible. The more upstream sensor is the important one for afr as I recall. The one further downstream is just a check to make sure the cat is working , which I think you don't have. Running lean is likely to induce knock.
Any idea what your ltft is? It changes at different load values (load increases with airflow) so you might need a log to see it. Basically if your o2 sensor is messed up, you are likely to see large + or - values in your fuel trim.
I’ll upload a log by tonight here and tuning thread as well. I’ll have to look at those values I know my ltft value kinda goes everywhere(-8.00~+5.00)
SamtheKorean is offline   Reply With Quote
Old 10-19-2020, 12:44 PM   #16
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Yeah, it will move around a bit normally. But sometimes it goes off the charts and that shows something is wrong.
Alternatively, you could just have bad gas
NoHaveMSG (10-19-2020), SamtheKorean (10-19-2020)
Old 10-19-2020, 01:12 PM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
so when the car is started it starts from .70 and it goes up to 1.00 after few minutes of driving and yes i’ll try to upload my log.
You must be running one of the V4 OFT tunes. I don't know how TF they didn't put initial IAM value at 1 It going to 1 and holding is a good sign.
Old 10-19-2020, 01:25 PM   #18
DarkSunrise
DarkSunrise's Avatar
Take a log and post to datazap. Look for any negative FLKC or Knock Correction (KC) events. Those are the degrees your ECU is pulling from the ignition timing advance to compensate for knock at those specific RPMs and loads.
That said, if your IAM is 1, you probably don't have any serious knock issues.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
alphasaur (10-22-2020), SamtheKorean (10-19-2020)
Old 10-19-2020, 07:23 PM   #19
SamtheKorean
September
Drives: 2015 BRZ
Alright so update for anyone helping me out or just browsing, after work today I reflashed my ECU(went back to original oem file and went back to stge 2 + 93oct tune). I noticed my IAM started from value of 0.70 as always did. This time omw to school, IAM did not reach to a whole value of 1.00. It ended up only reaching to 0.87 by the time I was at school. I did a few log recording otw to school, few pulls and normal cruise. I will post a log to see if anything’s wrong.
Old 10-19-2020, 08:42 PM   #20
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Your going to need to drive the car for a while before a log will be worth it. Since you reflashed the car needs to relearn trims and KC learned. Will probably go up after it gets some mileage on it.
Old 10-19-2020, 09:07 PM   #21
SamtheKorean
September
Drives: 2015 BRZ
I’m pretty sure my upstream air:fuel sensor is long gone, ltft is seemed to be stuck at 0.00% or some negative value for long period of time without changing the value
Old 10-20-2020, 12:15 AM   #22
SamtheKorean
September
Drives: 2015 BRZ
https://datazap.me/u/samthekorean/lo...1-5-8-12-13-14 heres the log data, is my ltft supposed to stuck in certain value for that amount of time?
Old 10-20-2020, 04:52 PM   #23
Spuds
The Dictater
Spuds's Avatar
It looks like ltft is behaving normally. It's averaging about, -5%. If the average creeps up past 10%, then you should start worrying. The two flat spots you see are normal. You were in open loop (OL) in both of those cases. On open loop acceleration, you are in the highest load bucket for the ltft, so it just adds/subtracts the value in that bucket. On open loop idle it adds/subtracts from the lowest load bucket. Notice how stft is flat 0, that's another effect of OL, stft is simply not added. The reason for this is because your o2 sensor is not supposed to accurately read much richer than 14.5. In OL, your afr is likely to be in the 12s under acceleration and off throttle it reports as 20.
Based on your IAM dropping from 1 to .82, it looks like your engine detected a bit of knock but then it got better as it went back up to 1. I wouldn't be too worried on my own car, it happens sometimes. You could try to find better gas. I've found certain stations tend to be better than others for one reason or another.
I don't remember if KC learned is supposed to be an absolute value or not, but it is all positive so I'm sure that says... Something? I don't put much stock in KC learned myself. Unless you are into actual competitive racing, it's not going to make much difference in what your car can do given your gas and environment.
SamtheKorean (10-20-2020), Ultramaroon (10-20-2020)
Old 10-20-2020, 05:50 PM   #24
Kodename47
Kodename47's Avatar
Drives: UK GT86
OK here you go:
FLKC is Fine Learnt Knock Correction - Negative is where it is pulling timing, it can only be positive when IAM is less than 1 and is where it is attempting to add timing back in. If successful then the IAM will increase. This is stored in load/RPM regions so if it has added or removed in the past then this will resume from the last stored value.
Knock Correction - Usually known as FBKC (Feedback Knock Correction). This is at lower loads, is as it says and is instant feedback. Only FBKC or FLKC can be active at any one time.
KC Learn - This is the ignition advance map multiplied by the IAM plus the FLKC value. Or in simple terms, how much ignition advance is being added. Not a useful logged parameter IMO.
IAM - If the default value is higher than the IAM at shutdown, then the IAM moves to the default value at startup. The IAM can only increase under certain conditions so it not increasing is not necessarily a sign of an issue. Only if it drops (and TBH if it drops by a reasonable amount) or never reaches 1 would I look at addressing it. If you're happy that you get regular good fuel, I would set it higher than 0.7 and see what happens.
Read Here:
http://www.romraider.com/forum/topic1840.html
.: Stealth 86 :.
Kodename 47 DJ:
The Following 3 Users Say Thank You to Kodename47 For This Useful Post:
SamtheKorean (10-20-2020), Spuds (10-20-2020), Ultramaroon (10-20-2020)
Old 10-20-2020, 07:34 PM   #25
SamtheKorean
September
Drives: 2015 BRZ
Jesus you have no idea how much of this informations has helped me, I’m thinking about gaining more knowledge about tuning I would want to help people/myself out as you did. Thank you brotha
The Following User Says Thank You to SamtheKorean For This Useful Post:
Spuds (10-20-2020)
Old 10-20-2020, 08:20 PM   #26
Spuds
The Dictater
Spuds's Avatar
Lol, well I learned most of what I know through the tuning section of the forum here.
FR-S engine rebuilt and knocking DJjoey0812 Issues | Warranty | Recalls / TSB 2 01-16-2020 07:46 PM
Rattle/knocking from engine (video) draculr Issues | Warranty | Recalls / TSB 24 08-06-2019 08:57 AM
Knocking Raspy Sound from engine bay 914_WHITE_FRS Issues | Warranty | Recalls / TSB 60 05-08-2015 01:30 AM
loud knocking constant with engine speed whatsmynameagain Issues | Warranty | Recalls / TSB 34 12-09-2014 10:58 PM
Engine knocking after flash Tenchi Software Tuning 10 09-26-2014 12:50 AM
