Old 10-16-2020, 02:10 PM   #1
doku
doku's Avatar
Drives: 2017 Subaru BRZ w/ Performance Pack
Dash Cam head unit?
I was looking at getting a new headunit that supports Apple CarPlay and it seems like a few have like 4 camera inputs. That's cool, but I can't rightly figure out if they record the input like a dash cam. My friend's Tesla is always recording for example. Is there any setup like that out there?
I was looking at this one for example:
https://www.kenwood.com/usa/car/excelon/dmx907s/
2017 Subaru BRZ Performance Pack - Brembo Brakes - SACHs Dampers - Wedsport TC-105x 18x8.5 - Michelin Pilot Sport 4S 245/35 - STI Short Throw Shifter
doku is offline   Reply With Quote
Old 10-16-2020, 03:09 PM   #2
Your friend's Tesla has a bigger battery than your car, not sure you would want it to always record, if by that you mean when off.
Old 10-16-2020, 05:14 PM   #3
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Headunits switch off when the car is turned off. They don't usually record in the first place, and beyond that they won't record when they're off anyway. The 4 camera inputs are just for operation while it's on.
The unit you linked is designed to work in tandem with their dash-cam for that purpose.
https://www.kenwood.com/usa/car/dash...mera/drv-n520/
If you got both, then the dash-cam would be able to record while the vehicle is both on and off if set up properly. Then, when the vehicle is on, you could control it through the head unit. The recordings are captured and stored via the dash-cam in that case.
sharpsicle is offline   Reply With Quote
Old 10-16-2020, 05:41 PM   #4
Originally Posted by sharpsicle View Post
They don't usually record in the first place, and beyond that they won't record when they're off anyway. The 4 camera inputs are just for operation while it's on..
The Pioneer AVIX I have in my Suburban will record from either of it's inputs (one for front, one for back) when the car is running if you have an SD card in the unit. It does the typical 30 sec or so loop, then you have to push a button to commit it. Don't have a front camera so never have used it but have considered it.
Like you said, car off, no recording.
Old 10-16-2020, 09:27 PM   #5
doku
doku's Avatar
I wasn’t worried about car off. I really just wanted multiple angles of recording while I was doing auto cross or track days without like buying a bunch of GoPros or something. I’ll look at the Pioneer unit for sure! Thx
The Following User Says Thank You to doku For This Useful Post:
Dadhawk (10-17-2020)
Old 10-17-2020, 12:00 PM   #6
BTW, its AVIC not AVIX as I mentioned above, and looking at the latest one available on Crutchfield it may no longer do this. Mine is a couple of model years back.
It will handle two cameras though. Not sure if they have a higher model with more.
2016 OEM Head Unit With Accompanying Dash Pieces Jordan Silveira Audio/Visual, Electronics, Infotainment, NAV 0 02-12-2020 12:19 AM
FS: '18 OEM Subaru BRZ Starlink Nav head unit with dash trim - $350 BA9092 Audio/Visual, Electronics, Infotainment, NAV 1 12-03-2019 02:58 PM
FS: 2014 FRS Bespoke Head Unit w/ Navigation & GPS antenna / 2014 FRS Base Head Unit vitriumGTS Audio/Visual, Electronics, Infotainment, NAV 0 07-16-2019 03:02 PM
Dash lights full bright after head unit install Flash02 Electronics | Audio | NAV | Infotainment 0 04-08-2019 10:48 AM
Scion FR-S/Subaru BRZ head unit dash trim ucsmfu Interior Parts (Incl. Lighting) 1 10-17-2013 04:33 PM
