Old 10-13-2020, 04:55 PM   #15
kiwigummy
kiwigummy's Avatar
Drives: 18 BRZ RS, 15 STi, 17 ILX A-Spec
Would be interested in knowing if there are other options as well.
I normally get Stoptech/Powerslot rotors but it doesn't seem like they have them for BRZ PP
kiwigummy is offline   Reply With Quote
Old 10-13-2020, 05:14 PM   #16
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Just get centric premiums. Most "performance" (non 2-piece) rotors are just centric premiums that are drilled and slotted anyway. Dont waste money on rotors, spend the money on the pads.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 10-13-2020, 05:32 PM   #17
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
How about these?
https://www.counterspacegarage.com/s...ront-sti-5x100
https://www.counterspacegarage.com/s...bon-brzpp-rear
Old 10-13-2020, 08:03 PM   #18
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
@mike_b is running Girodisc 2-piece rotors on his Performance Package Brembos. The rears are dual drilled STi rotors. He also had to do some modifications to the rear pads.
Originally Posted by mike_b View Post
The rear rotors are from an STi application but they are dual drilled and work on the BRZ pp brembos. You do have to trim the metal backing plate of the outside pad to the contour of the pad face and the pad with the squeal tab must go on the inside. The front rotors are 6.0lb lighter per corner and the rear rotors are 5.3lb lighter per corner.
Sounds like 22.6 lbs of rotational weight savings in just the rotors!
Check out this thread for the details: https://www.ft86club.com/forums/show....php?p=3363834
Mike_ZN6 is offline   Reply With Quote
The Following User Says Thank You to Mike_ZN6 For This Useful Post:
mike_b (10-14-2020)
Old 10-13-2020, 11:30 PM   #19
jflogerzi
jflogerzi's Avatar
Anyone looking for cheaper parts centric has rear PP size rotors
Look for (125.47043) centric part number. 120$ with shipping and tax for a pair
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Takumi788 (10-14-2020)
Old 10-15-2020, 04:18 PM   #20
kiwigummy
kiwigummy's Avatar
Yup, I believe the Stoptech/Powerslot slotted ones are just these rotors but slotted. For pads I use Endless ME20.
Thanks for the links. Will likely go with either these.
Old 10-16-2020, 03:30 PM   #21
babykwiss
Drives: Scion FRS
if anyone has actual part numbers for these 2
I would really appreciate it if you could post. I'm in the market to for replacing.
babykwiss is offline   Reply With Quote
Old 10-16-2020, 03:37 PM   #22
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I believe you need these
Front: 125.47019 https://www.apcautotech.com/part-det...baru&model=brz
Rear: 125.47043 https://www.apcautotech.com/part-det...baru&model=brz
but I haven't ordered mine yet either to say for sure
See also https://www.ft86club.com/forums/show...14#post3271014
The Following User Says Thank You to timurrrr For This Useful Post:
sroby (02-05-2021)
Old 10-16-2020, 05:59 PM   #23
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
For non-Premium, looks like these are the part numbers:
Front: 121.47019 https://www.apcautotech.com/part-det...baru&model=brz
Rear: 121.47043 https://www.apcautotech.com/part-det...baru&model=brz
sroby (02-05-2021)
Rear rotor replacement drz400dude Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 08-24-2019 01:43 AM
Performance Pack rotor options Var Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-08-2018 04:43 PM
Replacement 'stock' rotor suggestions for track? Open Loop Tracking / Autocross / HPDE / Drifting 10 10-17-2018 07:00 PM
Lightweight REAR rotor options himbo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 10-15-2018 05:59 PM
