| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2020 Subaru BRZ Sport-tech
Brake Fluid Advice - track use
Hi there,
New track driver here - just wanted to ask a few questions about brake fluid... 1. How often do you change your brake fluid? Each season or after a certain number of track days? 2. I'm currently running the stock brake fluid in the stock brembos, I've only done 4 track days with them but I want to change the fluid for something better for track use. Amy suggestions? dot4? 3. How much should it cost to get done at a shop? Thanks. Thanks Last edited by ThaDonJsuan; 10-10-2020 at 11:39 PM. |
#2 |
Thanks
I was happy with Castrol SRF. never boiled with AP racing sprint, stock power and 200 TW tires. So i just changed it start of the season.
#3 |
Drives: 2020 Subaru BRZ TS
I have never tracked the car but would use the car manual recommended DOT. I'm also thinking brake fluid should be good for at least a season or until the next rotor/pad swap.
#4 | |
Thanks
OEM fluid is a waste of time at the track. And pads for that matter after your first track day, or less.
#5 |
Drives: '23 BRZ
I've never had any problems running name-brand off-the-shelf parts store DOT4 (lately I've also used parts store Wagner DOT5.1). I'll start the track season with a full flush with new fluid. I take fluid with me to the track to bleed if necessary, but typically can get 6-8 track hours usage before having to bleed brakes.
#6 |
JHerbert Racing
Drives: 2013 Scion FRS
RBF 600 or 660 is always a good budget bet. I flush mine in the beginning of the track season, then again halfway through.
| The Following User Says Thank You to Takumi788 For This Useful Post: | NoHaveMSG (10-12-2020) |
#7 |
Drives: '20 Tundra, '84 SpecE30
Castrol SRF may be pricier upfront, but I ran it in the STI and would change it once a season. That wet boiling point is unmatched, which imo is the most important temperature to consider.
#8 |
Drives: Crapcan
Highly recommend picking up a power bleeder with the appropriate master cylinder adapter. Makes the job a breeze.
https://www.motiveproducts.com/colle...r-bleeder-kits
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | thomasmryan (10-22-2020) |
#9 |
Drives: '23 BRZ
Bears repeating:
Off-the-shelf DOT4 or DOT5.1 has never let me down at the track (even in a 550hp FD RX-7), lasts multiple track events (sometimes whole season for me, sometimes mid-season caliper-bleed required), inexpensive and readily available. Spend more if you want to, but most likely won't see any real benefit... Particularly "new track driver" in modestly-powered car with massive Brembo brakes! |
#10 |
Drives: 2013 Subaru BRZ
Depends on the brake fluid you're running. I tried using Motul 600 at a suggestion from others and boiled it in 4 laps and I needed to bleed it pretty much after a single session (not day a single 20 min session). The Castrol SRF stuff I switched to I think can last me the whole season without bleeding. I'm at 4 track days and 4 time attack events on them and its still fine. You'll know it needs to be bled because your brakes feel like ass. I've found once you boil brake fluid it never really goes back to normal until you re-bleed. 2. I'm currently running the stock brake fluid in the stock brembos, I've only done 4 track days with them but I want to change the fluid for something better for track use. Amy suggestions? dot4? Definitely upgrade brake fluid. Depending on how fast of a driver you are and how often you track something like Castrol SRF might be a good choice as it lasts a long time. If you only go once or twice a year ATE Typ 200 might be a better choice. 3. How much should it cost to get done at a shop? I've not done it at a shop but I purchased a power bleeder for ~100 bucks and I just do it at home, takes like 10 mins. |
#11 |
Drives: 17 Asphalt 86
DOT4/DOT5.1 should be enough.
RBF600/660 is an option but I find it expensive for my application. Mainly street/occasional track setup. I bought 2 liters of motul 5.1 for something like $30CAD. 1 liter was used when I flushed the system. |
#12 | |
Drives: '23 BRZ
So to RE-repeat: off-the-shelf name-brand DOT4 or DOT5.1 is gonna be just fine for OP... Last edited by ZDan; 10-13-2020 at 12:21 PM. |
| The Following User Says Thank You to ZDan For This Useful Post: | NoHaveMSG (10-13-2020) |
#13 | |
Drives: 2013 BRZ Sport-Tech
Still, I wouldn't say no to name brand dot 4/5.1. Motul stuff is too expensive for my tastes. 2-3x as much as ATE200 where I've looked. |
#14 | ||
Drives: '23 BRZ
That was my one foray into "specialized" brake fluid. IMO it's overprescribed and overused and in most cases for tracked cars, totally unnecessary. Quote:
| CSG Brake Thread - Expert Tuner/Motorsport Brake Advice & Experience | CounterSpace Garage | Brakes, Suspension, Chassis | 14 | 10-23-2019 01:54 PM |
| Advice for leaked brake fluid from front lower caliper pin? | EndlessAzure | Issues | Warranty | Recalls / TSB | 17 | 08-26-2019 09:11 PM |
| Brake Pads and Fluid For DD/AutoX/Track Days/HPDE | ToyoburuBRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 07-23-2016 04:59 PM |
| Local shop selling Motul 300V, high end brake fluid, etc. for track? | mike_ekim1024 | Northern California | 12 | 03-09-2014 03:08 PM |
| Track Day Brake Fluid | Skorov | AUSTRALIA | 2 | 11-11-2012 08:10 PM |
