Old 10-08-2020, 04:48 AM   #43
TRS
TRS's Avatar
Drives: 2013' Toyota 86 (EU spec)
I think its not putting something to extreme. There seems simply a difference between what you and I are expecting of a reliable and maintenance freindly build (speaking about petrol swaps or upgrades). Also I think this can be caused by the environment the cars are driven in. I had to improve and invest some bugs to get a FI build (on a already FI engine) which was able to drive me 15miles to work each morning, with 10miles at constant 170mph and same way back in the evening over years. In addition we should maybe remember that modifications on a Road car are more limited in my area and also are bound to 1.5 to 2 times the price you might have to pay. Maybe Im realy wrong, but I worked on many builds (not only my own) and I think I learned the difference between a 3k and 15k FI build the hard way. Not saying a 3k build doesnt work somehow, but somehow is nothing I would take as a base for any comparrison.
As well I learned that a drivetrain and engine designed for arround 200hp and tuned to 400hp will have weakpoints to care about in short time cycles, even if you put many effort and money to erase most of them. This is what I mean with high maintenance effort for such a build.
A engine drivetrain coming with 400hp from factory will not requires this kind of maintenance. But as already said, it comes down to usage.
I also dont like to compare budget builds (which are Proben to be possible) with a 24 or 26kWh battery to a 400hp petrol build. I feel this would be somehow extreme.
Furthermore, in your last post you wrote down pretty much the essence of what Im talking about. So in the end it seems that we are not that far from each other. I cant say it often enough, Im not against E mobility, but as it has its benefits it also has its downsides, as any thing in the world. And there will be the day when that kind of swap is the best thing to do. Maybe this day isnt even far. But today I think there are other good options to choose from. Anyway there need to be people out there working on that, since those are the ones who develop the know how and expirience to achieve this one day.
TRS is offline   Reply With Quote
The Following 2 Users Say Thank You to TRS For This Useful Post:
Irace86.2.0 (10-08-2020), Lantanafrs2 (12-06-2020)
Old 10-08-2020, 08:18 PM   #44
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
Im no expert at all but it looks like it would be easier to put a BRZ shell on top of a model 3 drivetrain B is For Build style.
glorydays is offline   Reply With Quote
Old 10-08-2020, 08:30 PM   #45
Just cut out some of the middle and solder it back together.
soundman98 (10-09-2020)
Old 10-08-2020, 09:15 PM   #46
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I jokingly said the same in an earlier post. In reality, the body length, width and wheelbase don't match at all, which would make the botch job much harder.
For reference, the base Model 3 weighs 3,550lbs with a 50kW battery. It has a wheelbase of 113” and dimensions of 185x73x57”. This is a bit larger than an 86 at 101” wheelbase and 167x70x52”...
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
glorydays (10-09-2020)
Old 10-10-2020, 04:37 PM   #47
Irace86.2.0
400kW=536hp 2450lbs
Old 12-06-2020, 02:31 PM   #48
Irace86.2.0
https://carbuzz.com/news/the-worlds-...rce=apple.news
This is a cool product for a body on frame design. These won't be cheap of course. Maybe that will change in the future.
gravitylover (12-16-2020)
Old 12-06-2020, 05:40 PM   #49
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Isn't that what the chebby volt started out as?
Had a skateboard like that you could put anything you wanted on top.
Old 12-06-2020, 09:23 PM   #50
soundman98
ProCrastinationConsultant
soundman98's Avatar
i believe gm's had at least 2 skateboard concepts since the 90's. they've never come to anything more than 'design studies'
Old 12-06-2020, 09:47 PM   #51
For years I have been of the opinion that we will see standardized, hot-swapped battery modules and mechanized service stations. If it doesn't start for passenger cars, it will for commercial vehicles.
gravitylover (12-16-2020), soundman98 (12-06-2020)
Old 12-07-2020, 02:05 AM   #52
Irace86.2.0
Tesla did the battery swap thing. They actually had a functional station. I think the price to swap a battery was too expensive, and it had less appeal to people wanting to keep their battery with their car. That, and I don’t know if the swap demo was more of a gimmick in the sense that there are coolant lines that would need disconnecting and topping off; it isn’t just an unscrew and screw the new one back in. That worked as a temporary demo, but coolant would be needed.
As you said, for commercial applications, this would be good.
https://www.google.com/amp/s/www.bus...t-2015-6%3famp
Ultramaroon (12-07-2020)
Old 01-08-2021, 09:40 PM   #53
Irace86.2.0
Old 01-09-2021, 01:09 PM   #54
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
It will never be a thing for passenger cars. The industry kind of decided that. Beyond the cost, it just doesn't make any sense at all when solid state batteries are coming up on the horizon.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
The Following User Says Thank You to Goingnowherefast For This Useful Post:
Ultramaroon (01-09-2021)
Old 01-09-2021, 02:34 PM   #55
soundman98
soundman98's Avatar
There was a post somewhere else that one of the companies did a study on it, and it turns out people are really possessive of their battery packs, so many people wouldn't give them up even if it was an option
Old 01-09-2021, 02:45 PM   #56
I have many unpopular opinions. Maybe they're thread-worthy.
soundman98 (01-09-2021)
Electric motor noise under car Dadillac Issues | Warranty | Recalls / TSB 22 06-21-2019 01:12 PM
FS: OEM Electric Power Steering Column, with Motor and Module MicheleAbbate Interior Parts (Incl. Lighting) 12 12-31-2018 04:47 PM
DSport Crate Shortblocks Williampreza Engine, Exhaust, Transmission 16 05-21-2018 01:45 PM
Strange electric motor noise while car is parked and off msmont BRZ First-Gen (2012+) — General Topics 11 10-20-2015 07:00 PM
Paris Motor Show Thoughts... ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 21 10-06-2010 10:42 AM
