| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2020 Subaru BRZ Sport-tech
Soft rattle coming from right side (passengar door?)
Hi all,
I just started hearing a soft rattle noise coming from the passenger side area (seems like the passenger door) when driving over rough parts of the road. I took everything out of the car to see if I could identify the issue - but no luck. I have no idea what it could be. Has anyone else had any soft rattle issue coming from the passenger side when driving over rough parts of the road? |
#2 |
Drives: 2020 Subaru BRZ TS
Most likely suspension related based on your description of the issue. I'm guessing a ball joint is starting to wear out.
#3 |
Check your passenger A pillar. My FRS had a light rattle from what I assume was an airbag wire inside the interior cover. Took me weeks to track it down. Warmed the plastic up a bit with a hairdryer and gave it a whack on the side with the palm of my hand and it went away.
#4 |
Drives: 2013 FR-S Series 10
buckle in buddy 'cause there's more where that came from. especially when the temperature drops
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
#5 |
Senior Citizen Member
Drives: Then-1977 Celica GT Now-2017 860SE
Check the glove box door. When the noise occurs, put your hand on the door or unlatch it. Don't ask me how I know . . .
#6 |
Drives: 15FRS, 05MustangGT, 85Toyota truck
Most likely there's still something under one of the front seats.
Put both seats forward as far as they will go, also tilting the seat backs forward. Get on the ground, on your knees. From the rear of the seats reach under them, moving your hands along the inside of the seat rails. Feel for any objects which are not part of the car. Check these areas with a bright flashlight as well. With the seats each all the way forward and also all the way back, feel along the sides of the seats between them and the console, also outer sides of seats. Use the crevice tool of a canister or shop vac placing it under the seats, searching for any items which your hands could not reach. Certainly you've already put both seats all the way back, checked under their forward parts with your hands for loose objects. We often forget some of the things we do inside our vehicles. Some time ago I found an old french fry under the driver's seat, always having thought I never ate in my car. I am a stickler for not wanting rattles and squeaks. My 6 year old car with 68,000 miles on it does not have any such appreciable noises. |
#7 |
Thanks for all the tips/suggestions. Ill get back if I discover the culprit
| Rattle sound coming from engine @ 2,500 rpm in 6th Gear | FRS2017 | Issues | Warranty | Recalls / TSB | 8 | 12-26-2019 08:02 AM |
| 'Fluttering'/soft rattle at speed | Symbiont | BRZ First-Gen (2012+) — General Topics | 35 | 12-22-2016 02:23 PM |
| Rattle from driver's side door lock. | Mandy | Issues | Warranty | Recalls / TSB | 0 | 07-10-2013 09:44 PM |
| Door Rattle? | 636 | Issues | Warranty | Recalls / TSB | 3 | 10-17-2012 07:18 PM |
| Does anyone have a rattle coming from the center dash? | Liquidsnake | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 09-30-2012 11:09 AM |
