Old 09-27-2020, 01:51 PM   #22359
JD001
JD001's Avatar
Drives: Subaru BRZ
Time to rebadge
It's like a dog that just sniffed something interesting on the sidewalk...
The Following 3 Users Say Thank You to JD001 For This Useful Post:
Decep (09-27-2020), JesseG (09-30-2020), Ultramaroon (09-30-2020)
Old 09-27-2020, 02:15 PM   #22360
mrg666
pessimistic skeptic
mrg666's Avatar
Originally Posted by RToyo86 View Post
I did it with my integra through the vacuum lines and noticed a difference. Also the huge plumes of white smoke out the back. The people watching me leave must have been confused as hell
Our Honda Odyssey was idling luck a diesel truck after 100K miles. Dealer recommended valve readjustment for $500. I have applied Sea Foam exacly like I have done with my FR-S and it was running like new again. I don't think I will let them do valve adjustment, it is not needed. Just another Sea Foam story
The Following User Says Thank You to mrg666 For This Useful Post:
humfrz (09-27-2020)
Old 09-27-2020, 02:52 PM   #22361
soundman98
ProCrastinationConsultant
soundman98's Avatar
with all vehicles moving towards hydraulically-adjusted valve lash, it's important to keep the oil clean. dirty oil gums up the adjusters, and leads to 'valve adjustment' requirements..
had at 2 cars so far that had similar symptoms. but those i corrected with more frequent oil changes.
mrg666 (09-27-2020)
Old 09-27-2020, 06:55 PM   #22362
Don't you worry about that treatment rusting other parts of the car? -
mrg666 (09-27-2020)
Old 09-27-2020, 07:18 PM   #22363
mrg666
pessimistic skeptic
mrg666's Avatar
Key is rinsing in a river next week, no rust so far.
The Following 2 Users Say Thank You to mrg666 For This Useful Post:
humfrz (09-27-2020), soundman98 (09-27-2020)
Old 09-27-2020, 08:21 PM   #22364
So, then you will take it to a car wash and have the girls do a 3 bucket wash to get the dirty river water off of it?
DAMN! That reminds me - I forgot to take ma meds this morning -
Old 09-27-2020, 08:32 PM   #22365
jflogerzi
jflogerzi's Avatar
A 16 oz. bottle is perfect for 4oz. into the oil and 12 oz. into full fuel tank. I changed the oil after using half of fuel since I didn't want to drive with all that sludge in the oil. Engine was already running remarkably better. Drained oil color was very dark. I think the remaining half tank will work a little more on the injectors if the full cleaning is not already done. But the engine is running so much better, I am falling in love with this car all over again.
Might try this. I have 73k on the obo but the car drives really good atm
2013 Series 10 FRS #553
Old 09-27-2020, 10:15 PM   #22366
mrg666
pessimistic skeptic
mrg666's Avatar
Wink
Nope, jacuzzi works better for all purposes
humfrz (09-27-2020)
Old 09-28-2020, 01:03 AM   #22367
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
This week I've washed, clayed, and waxed the car, replaced the trunk, reverse, and dome lights with LED bulbs.
The LEDs in the dome light are so bright that they hurt to look at now hahaha.
Also got some Nokya 7000K halogen bulbs coming to replaced the DRL/High Beam bulbs. (I really doubt halogens can hit 7000K .. but we'll see)
The Following User Says Thank You to Bonburner For This Useful Post:
JesseG (09-29-2020)
Old 09-28-2020, 06:03 AM   #22368
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Door dinged my self with my girlfriends car while at the cottage :'(
Then went for a sunday cruise on my favorite road within an hour drive.
The Following 8 Users Say Thank You to RToyo86 For This Useful Post:
beltax90 (09-28-2020), Bobharp (10-01-2020), FLIPDADY (09-28-2020), JesseG (09-29-2020), mrg666 (09-28-2020), Overdrive (09-30-2020), Tcoat (09-28-2020), Ultramaroon (09-30-2020)
Old 09-28-2020, 09:00 AM   #22369
mrg666
pessimistic skeptic
mrg666's Avatar
Still beautiful
The Following 4 Users Say Thank You to mrg666 For This Useful Post:
Compelica (10-01-2020), JesseG (09-29-2020), RToyo86 (09-30-2020), Ultramaroon (09-30-2020)
Old 09-29-2020, 05:11 PM   #22370
thekevinvo
Drives: 2014 Scion FRS
Installed the Verus Engineering brake cooling kit today
thekevinvo is offline   Reply With Quote
The Following User Says Thank You to thekevinvo For This Useful Post:
MJones_RB (09-30-2020)
Old 09-29-2020, 06:43 PM   #22371
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
Still beautiful
Yep, still sexy! And a good drive always helps. I did the same thing when I noticed a big scratch recently. Ha!
JesseG is offline   Reply With Quote
The Following User Says Thank You to JesseG For This Useful Post:
mrg666 (09-30-2020)
Old 09-30-2020, 12:01 PM   #22372
WNDSRFR
Drives: FR-S,GTI
Changed my battery today.
Forgot about the cigarette lighter trick so I had to reset the clock, radio presets, rev limit and light and the gear indicator. Why is the default for the gear indicator "off" anyway? Why would anyone not want to know what gear they're in?
After I reset everything I still had the tire low pressure light on. I figured "maybe I have to drive a while and it will go off." Nope.
Maybe I have to turn the car off and restart it. Nope.
Maybe a tire is low. Yep
All 4 tires were low. How did changing the battery decrease the pressure in all the tires?
It didn't.
It was a complete coincidence that the light came on after changing the battery.
What happened is.....
It's been about 95 degrees everyday for as long as I can remember. Today it's 70 degrees.
I'll bet in a couple days when it's 95 again my tire pressures will be over 35 PSI.
The Following 3 Users Say Thank You to WNDSRFR For This Useful Post:
humfrz (09-30-2020), JesseG (09-30-2020), MJones_RB (09-30-2020)
