#29 | |
Drives: '13 Whiteout
It's like me building a house and telling my window installers to hurry up and don't take too much time when flashing the windows. Then the windows leak and that extra time to do it right would have been a hell of a lot cheaper |
| The Following User Says Thank You to TommyW For This Useful Post: | Clipdat (09-26-2020) |
#30 | |
Drives: Crapcan
Page 31 starts it. https://static.nhtsa.gov/odi/rcl/201...8V772-6522.pdf Instances of failure seem to be greatly reduced from the beginning. But again, it comes down to guys in a rush trying to make money. Being flat rate you only get paid book time. This pays 12.5 hours, which is tight when considering you need to clean and reseal all surfaces. You also don't know what condition the car coming in is going to be in. It could be a greasy mess and require tons of extra cleanup. There is a reason techs don't last, they either suck, they have a conscious, or they can't make time. The guys that do last are usually pretty damn good.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Dadhawk (09-22-2020) |
#31 |
Or, they open their own shop. That's the case with the mechanics I use. They were the top stars at their dealerships, but got tired of giving all the money to them.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | NoHaveMSG (09-22-2020) |
#32 | |
This of course has been determined by guys with zero training or experience that feel they are personally capable of doing a $500 engine swap in their driveway over the course of an afternoon!
#33 | |
Yes My rebuild was 30 hours. Everything done not only right but better than right. Painstaking attention to detail. |
#34 |
Drives: 2013 pearl white FR-S
My conspiracy theory is this. Toyota and subaru lost a lot of money due to this recall. How do they make up for it? F*ck up the motor so that increased sales of longblocks will make up for recall related costs. That's how I see it.
#35 | |
#36 | |
| The Following User Says Thank You to Dadhawk For This Useful Post: | Tcoat (09-22-2020) |
#37 | |
People have either ignored, forgotten or didn't even know that there were over 30 reported early 2013 engines that spun bearings due to oil starvation years before the recall was even heard of. Most of those engines had never been opened and the sealant was untouched by human hands prior to their failure. Most of those were blamed on the owner but there were enough posts showing blocked oil passages to present the theory that the sealant was improperly applied right from the start. In all probability the robots applying it were still not dialed in properly and they messed up just like the human techs did later. These failure have all but been forgotten since the recall and pushed way back in the pile but a really ambitious member may be able to dig them up. There are reams and reams of arguments with me presenting this theory and a couple of other people calling me a moron because it was impossible to miss apply the sealant and ruin an engine. They all sopped talking when the recall failures started. Wait... What is that guy in a Subaru shirt pointing at me? Is that a laser targeting dot on my chestttttttttttttttttttttttttttttttttttttttttttttt t
#38 | |
Drives: Crapcan
Valve spring recall can’t start car
I was not aware, but I wouldn't be surprised. It's pretty easy to miss-apply. I eff'd up on the cam carrier on one side and had to clean it off and redo it before I even installed it on the head. I used a caulking gun to apply it but it is hard to brace and try to apply properly without slipping up. Plus my hands would get tired. Here is my spare engine I pulled apart that was assembled by a master tech at a Toyota dealer. Note sealant all the way to the cam lobe ![]()
#40 |
Drives: White FR-S kosei k4r 17x8
Called the dealership today.
They said they found the issue it was something about high pressure pump not being connected properly and that they corrected it and the car is running properly now. I am going to pick up the car later today. I asked them about warranty on the engine in case something goes wrong after the recall it will be covered. he said on the phone that if any issues arise within 12 months I can bring it back. but they will not give any document in writing for the warranty. Now I am debating whether to sell it and get something else as daily driver. Will the wrongly connected fuel pump during the service and numerous rough starts have damage/have negative effects on the engine in the long term? when I was at the dealership trying to start the car with the fuel pump issue it was rattling quite violently so I'm concerned about the long term heath of the engine. |
| The Following User Says Thank You to jiffyjhn For This Useful Post: | Clipdat (09-26-2020) |
#41 | |
, and yess u have 12 months or 12k miles witch ever comes first.Sent from my SM-N975U1 using Tapatalk |
| The Following User Says Thank You to padillaricardo48 For This Useful Post: | jiffyjhn (09-26-2020) |
#42 |
If they messed that up, what else do u think is messed up lol
| The Following User Says Thank You to DarkSideFRS For This Useful Post: | Clipdat (09-26-2020) |
| Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 09:32 PM |
| Valve float after valve spring recall | mswbrz | Issues | Warranty | Recalls / TSB | 5 | 11-22-2019 07:03 PM |
| Valve spring recall | meadowz06 | Issues | Warranty | Recalls / TSB | 115 | 06-08-2019 11:38 PM |
| BRZ Valve Spring Recall | mrhemi | Issues | Warranty | Recalls / TSB | 6 | 03-01-2019 03:35 PM |
| Valve Spring Recall | venturaII | New England | 13 | 02-25-2019 07:41 PM |
