#29 |
Drives: jrsc_brz
Ok, awesome, I'll probably just replace with a oe door speaker in that case. But before I do that, I found that a rattly drivers door is quite common, so I'll try some foam before I say the culprit is a blown speaker. Thread I found called rattly driver door, or something or other.
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
#30 |
ProCrastinationConsultant
yeah, i forgot to add that-- a little bit of sound dampening can go a long ways.
#31 | |
Drives: 2014 Subaru BRZ SC & 2018 Tacoma
I want to put a sub into my car but I'm not really looking to upgrade anything else. If I install the sub and amp, does that "take away" some of the load from the door speakers (from what I can gather are more just "subwoofers" rather than speakers?) or does it make no difference at all? I am going to do some deadening as well, help try and clean up the rattles and sound
#32 |
no, it would just come through louder.
imagine each and every speaker in the car is a person singing a song in a group, but you're not particularly happy with the singing of one of those particular people. what you're proposing would add another singer that you're hoping to sing louder, over the person singing that you don't care for. a number of people do it, but because it doesn't fix the underlying issues, it's generally not recommended-- you will eventually have more problems because of it.
#33 | |
So it would seem the best bet is to get component 6.5" speakers up front, put those in the door, put the tweeters up in the factory spot and then have the subwoofer in the back and just leave the rear speakers as-is cause they don't do much of anything anyways
#34 | |
| The Following User Says Thank You to soundman98 For This Useful Post: | ArrrBussiere (08-05-2020) |
#35 | |
#36 |
Muscle Car to Import
Drives: 2013 Asphalt FR-S
Can you get any double din head unit to fit in our cars or do they have to be a specific size?
#37 | |
Master Collaborator
There are a few head unit manufacturers out that build modular units with even larger “floating” touch screens, but I’ve not seen any installed in our cars that fit properly. |
| The Following User Says Thank You to FR-S2GT86 For This Useful Post: | DocRecon (09-14-2020) |
#38 | |
Senior Citizen Member
Drives: Then-1977 Celica GT Now-2017 860SE
https://www.crutchfield.com Unfortunately, 200mm head units are hard to find but there are some available: https://www.fasmoto.com/audio-video/...ead-unit-200mm |
| The Following 2 Users Say Thank You to LimitedSlip For This Useful Post: | DocRecon (09-14-2020), soundman98 (08-17-2020) |
#39 |
Drives: 2014 BRZ
I read through some of the audio threads. I want to add a trunk subwoofer, but don't want a new head unit or take apart the dash at this time. In light of that, maybe someone can add insight to the below questions?:
1) I can tap into the audio signal wires coming to the stock rear amp, in order to provide a subwoofer with that same audio signal? 2) Is the above mentioned audio signal full spectrum at that point? 3) Is it better to ground the sub for the power return, or run a dedicated return line to the battery negative terminal? 4) How are people adding high-pass filtering to the door speakers after a sub install (since bass is no longer needed for the doors)? |
#40 | |
Master Collaborator
Answer 2) On the input to the amp, you'll have a full spectrum audio signal. The output however, has never to my knowledge been tested for where the built-in low-pass crossover is set at, nor is it's slope value known. Answer 3) Just ground your subwoofer amp to a bolt somewhere near the amp location. I used the bolt that holds down the OEM amplifier since it's no longer used in my setup. Answer 4) Since I went all aftermarket, I'm using all active crossovers either built into my head units or built into the amplifiers. You may want to add some passive crossovers to the door speakers as a high-pass filter. In effect, you'll have a band-pass setup in your doors like I do, but in your case you'll have very little adjustment potential. You won't be able to adjust the low-pass setting at all built into the OEM amplifier, and you have to physically replace the passive high-pass crossovers every time you feel the need to make an adjustment. Just remember to design your passive crossovers for 2-ohm drivers. Just letting you know what you're getting yourself into by trying to integrate existing factory equipment. It may be easier for you to install another amplifier to power the door speakers that has a band-pass crossover built into it. That way you'll have a much easier time making adjustments. Keep us informed of what you end up doing. I think back now that I could have probably gotten away with removing the passive crossovers from my stock speakers and ran them all off of the active setup that I have now instead of replacing them all with aftermarket drivers. Hmmmm....... |
| The Following 2 Users Say Thank You to FR-S2GT86 For This Useful Post: | indio22 (09-15-2020), soundman98 (09-16-2020) |
#41 | |
Drives: 2014 BRZ
#42 | |
Master Collaborator
One of these days someone will connect one of these factory systems up to an RTA and oscilloscope to give us the exact numbers for information's sake. But until then, and as long as we have aftermarket equipment to replace it with, not too many people are going to really worry about it. |
| OEM Audio+ Reference 500 plus audio system | blackboxmotorsport | Audio/Visual, Electronics, Infotainment, NAV | 0 | 03-22-2019 10:02 PM |
| Does the stock Navigation System self learn?? | BRZnut | Electronics | Audio | NAV | Infotainment | 3 | 01-28-2019 09:16 AM |
| Sound System Upgrade - Lots of Questions from a Relative Newbie | Stang70Fastback | Electronics | Audio | NAV | Infotainment | 15 | 06-08-2016 01:17 AM |
| New Audio System: OEM Audio+ Reference, Audison Prima 8.9, or Hertz Energy setup? | gamjatang | Electronics | Audio | NAV | Infotainment | 10 | 12-04-2015 05:12 PM |
| I am an audio newb, please learn me! | Superchan | Electronics | Audio | NAV | Infotainment | 47 | 04-11-2015 12:56 AM |
