Old 09-14-2020, 12:43 PM   #1
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Spark Plugs
Recommendations?
Denso Iridium (OEM)?
or
NGK Racing with Iridium tip and Platinum-coated copper ground?
or
Other brands?
Any suggestions for N/A or F/I?
Type of use, street, track?
Experiences, good, bad, other?
Any brands to steer clear of?
FR-S2GT86 is offline   Reply With Quote
Old 09-14-2020, 12:58 PM   #2
86TOYO2k17
Drives: 2017 toyota 86
hks super fire racing worked well for me with 13psi, stock work fine though too.
Old 09-14-2020, 01:25 PM   #3
It's my understanding that this wheel needs not to be reinvented or modified - just stick with the OEM plugs -
DarkPira7e (09-14-2020), gravitylover (09-15-2020)
Old 09-14-2020, 02:33 PM   #4
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
I'm getting an occasional misfire on cylinders #2 and 4. Am planning on replacing the set to see if it will cure the problem before I install my supercharger.
You don't think installing different plugs for forced induction would have any benefit? Just curious, are you boosted or naturally aspirated?
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
humfrz (09-14-2020)
Old 09-14-2020, 03:43 PM   #5
Misfires could be caused by the coil on plugs rather that the spark plugs.
I haven't heard from the folks that are boosted that they have any problems with the OEM plugs -
I'm not boosted, at age 77, I'm barely naturally aspirated -
The Following 6 Users Say Thank You to humfrz For This Useful Post:
DarkPira7e (09-14-2020), FR-S2GT86 (09-14-2020), gravitylover (09-15-2020), Jdmjunkie (09-14-2020), strat61caster (09-16-2020), vintagemxer (09-14-2020)
Old 09-14-2020, 05:20 PM   #6
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Stock is fine
TommyW is offline   Reply With Quote
Old 09-14-2020, 06:40 PM   #7
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Originally Posted by TommyW View Post
Stock is fine
Stock it is then.
Just went out to look for them and out of three chain parts stores, nobody carries the OEM Denso plugs. None of them even crosses them over to any other brand.
With all of the counterfeit plugs infesting the online shops these days, I'd hate to order them from Amazon.
I know the Toyota and Subaru dealers will have them, but I'm sure they'll be way overpriced.
Old 09-14-2020, 06:54 PM   #8
TommyW
TommyW's Avatar
Stock it is then.
https://www.ftspeed.com/part/fr-s-br...6#.X1_mlWhKjOU
Old 09-14-2020, 06:57 PM   #9
86TOYO2k17
Same price i paid for HKS spark plugs.
Oem work just fine.
But
If needing to replace for some reason I don’t see why upgrading the for the same price would be a bad idea.
Old 09-14-2020, 06:59 PM   #10
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
True, but if I'm going to get down that deep into troubleshooting, then it would probably be a good idea to have the new plugs in hand before taking the existing ones out for inspection, which I will want to at least do first before ruling out two intermittently faulty coils.
humfrz (09-14-2020)
Old 09-14-2020, 07:33 PM   #11
pope
has a funny hat
Drives: 2014 BRZ Limited
Stock it is then.
According to parts.toyota.com and parts.subaru.com they are $18.99ea or $25.95ea respectively.
pope is offline   Reply With Quote
Old 09-15-2020, 12:35 AM   #12
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Those have to be some of the most expensive spark plugs that I've ever had to shell out cash for. But I need to get this done before Thursday so I gotta get 'em. Will call the local Toyota and Subaru dealers tomorrow, hopefully they'll have them in stock and I can drop in and pick them up.
Thanks everyone who chimed in.
Old 09-15-2020, 12:49 AM   #13
pope
has a funny hat
Thanks everyone who chimed in. By the way, does anyone know what the factory torque spec is for the plugs?
17Nm(12.5ft/lbs)
The Following User Says Thank You to pope For This Useful Post:
FR-S2GT86 (09-15-2020)
Old 09-15-2020, 01:27 AM   #14
Oh, look at it this way. You only need 4 plugs and they last at least 60,000 miles -
FR-S2GT86 (09-15-2020), pallen (09-23-2020)
OEM Spark Plugs - NIB JohnPayneFun Mechanical Maintenance and Tools 2 04-20-2020 04:03 PM
spark plugs Legend@wheels Engine, Exhaust, Transmission 3 12-12-2018 01:13 AM
How to gap spark plugs Strife26 Engine, Exhaust, Transmission 38 01-09-2018 02:06 AM
Spark plugs Triumphrider Engine, Exhaust, Transmission 12 06-19-2014 11:47 AM
spark plugs subaruferrucci Engine, Exhaust, Transmission 22 04-10-2013 12:24 PM
