Old 09-07-2020, 07:44 PM   #1
Gloonge
Drives: 2013 frs raven
LTFT creeping negative, AFR's staying normal?
https://datazap.me/u/gloonge/log-159...data=2-9-11-14
Hoping someone can help me make some sense of this nonsense.
Been running this tune for a week or so, and up until today LTFTs have stayed between -7 and -2 for the most part. Today I noticed that at idle and light throttle with the a/c off the LTFTs go to -20 or more. However AFR is normal.
Edelbrock supercharged, uel headers, custom tune from Shiv.
Gloonge is offline   Reply With Quote
Old 09-08-2020, 03:03 AM   #2
kev0
Drives: '14
If it's not the tune, then it's probably bad coil packs/spark plugs since 2013-14's were plagued with bad coil packs. They revised the part later on for 2015+. You can get the new coil packs, but then you need to grab the new harnesses as well.
kev0 is offline   Reply With Quote
Old 09-08-2020, 07:45 AM   #3
Gloonge
Mine is a 13'. The car runs fine other than this little bit of data, no stumbling or hesitation. Is there any way to test for this before handing over a few hundred dollars for coils and a harness?
Old 09-09-2020, 07:16 PM   #4
Gloonge
Today my a/c compressor started knocking loud enough for me to hear it. The bottom bolt backed out. After snuggling that back up the fuel trims seem to have gone back to normal.
So I am assuming that either the belt was slipping or the knock sensor was picking up the vibration. Either way the issue seems to be gone.
Figured I would pop back in there and let everyone know so the search function helps someone some day.
Thanks.
The Following 3 Users Say Thank You to Gloonge For This Useful Post:
kev0 (09-12-2020), Spuds (09-13-2020), theneptune86 (09-12-2020)
Old 09-12-2020, 01:55 PM   #5
theneptune86
Drives: Neptune Blue 2019 Toyota 86
Yikes, good find!!
2019 Neptune Blue Toyota 86 • Gruppe-S UEL Catless Headers • OFT Stage 2 Plus (91)
theneptune86 is offline   Reply With Quote
Old 09-13-2020, 01:19 AM   #6
Gloonge
Originally Posted by theneptune86 View Post
Yikes, good find!!
It sounded like clutch chatter for a few days cause it only happened when trying to start in first gear. Then it was constant so I could hear it at idle.
I'm telling you, forced induction has been the biggest pain in my ass, issues left and right. But that sweet blower noise and power balances out the bs.
The Following User Says Thank You to Gloonge For This Useful Post:
theneptune86 (09-14-2020)
Old 09-13-2020, 01:41 AM   #7
kev0
Drives: '14
Thanks.
Can you grab a picture of the bolt that was loose on the compressor when you get a chance?
Old 09-13-2020, 01:43 AM   #8
Gloonge
Will do. It was the lower bracket bolt though. Making and awful noise.
High negative STFT and LTFT 86TOYO2k17 Issues | Warranty | Recalls / TSB 22 09-30-2025 04:10 PM
Stock car with OFT E85, LTFT spiking negative? MagicianRed Software Tuning 0 06-08-2019 02:45 PM
High negative LTFT OFT Stg1 tune localhost Software Tuning 3 08-29-2018 03:22 PM
Normal LTFT?? dillanp86 Engine, Exhaust, Transmission 16 05-08-2018 12:17 AM
High Negative LTFT on N/A BRZ causing idling issues paintdude258 Software Tuning 57 03-26-2017 09:14 AM
