| Member's Car Journals Car journals by our members. |
Drives: 2014 Scion FRS
Kevin's from salvaged to track FRS
Picked up this previously salvaged title 2014 FRS down in Houston, TX and brought it all the way to Iowa. The car itself is basically stock besides some Stance Suspension coilovers and lower control arms.
Once I got it home, I swapped out the brake lines, fluids, and pads and took it for a spin around Mid-Ohio. Car felt great and was a blast to drive despite having some 500 treadwear all season tires. Plan to turn the car into my weekend warrior track car that I can drive to and from the track. Current Mod List: Verus Engineering UCW Rear Wing Verus Engineering Composite Front Splitter FT86SpeedFactory UEL Header Verus Engineering Hood Louvers Perrin Oil Cooler FactionFab FR-Spec Coilovers Grimmspeed Strut Tower Brace Grimmspeed Master Cylinder Brace Hawk HP+ Pads FactionFab Swept Slot Rotors Verus Engineering Brake Cooling Kit Apex EC-7R 17x9 +35mm Falken Azenis RT660 245/40/17 Rays Gram Lights 57CR Ceramic White Pearl 17x9 +38 Falken Azenis FK510 245/40/17 Remark R1 Spec Titanium Catback Exhaust Tomei Front Pipe Motiv Overpipe Recaro Profi SPG Buddy Club Super Low Down Seat Rails ![]() ![]() ![]() Will be trying to document the whole process through my YouTube channel and on here, so if you're interested in following along grab a seat! Last edited by thekevinvo; 09-29-2021 at 04:37 PM. |
#2 |
Installed the Perrin Oil Cooler to take care of the high engine oil temps at the track.
#3 |
Rust bucket enthusiast
Very nice, though I do think the FRS looks best with the spacer invaders plastic stuff in the front grille.
I painted the white hat on my crash bar using red plastidip and you actually can't tell the difference, I highly recommend if it you're going to leave it out there! |
#4 | |
#5 |
Brake system got an overhaul with some new rotors
#6 |
Drives: 2013 Scion FR-S 10 Series
When are the JDM headlights coming?
Sent from my iPhone using Tapatalk Pro |
#7 |
#8 |
Finally got rid of some horrendous clunking in my front suspension.
#9 |
Drives: Crapcan
I find the WL end links come loose easily. I would recommend some blue locktite. I have had to tighten mine twice in the last year, right front is making noise again.
#10 |
#11 |
Cleaned up the engine bay a little bit with the Grimmspeed Pulley Cover & Hood Struts
#12 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Oh, you're the dude from SubieSpeed and FTSpeed while Thomas is hiding from spark plugs
#13 |
#14 |
Changed out the transmission fluid.
| Turning a salvaged title FRS into my track car | thekevinvo | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-28-2020 10:42 AM |
| Project Rekt - Salvaged BRZ track build | statik | Member's Car Journals | 31 | 05-16-2016 06:13 PM |
| WTF is up with all the salvaged cars?! | suaveflooder | Off-Topic Lounge [WARNING: NO POLITICS] | 40 | 04-09-2014 05:21 PM |
| Kevin Brown | Paul_S | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 2 | 03-20-2013 05:39 PM |
| Kevin's BRZ | kgc | Member's Car Journals | 13 | 09-19-2012 02:39 PM |
