Old 08-30-2020, 01:10 AM   #1
mcbrawr
Drives: 2014 BRZ Limited
Inconsistent Acceleration w/ SBD 500x
Everyone:
I've been trying to iron out an issue with my car since my tune was completed with James (HRI). Car seems to stumble randomly at partial throttle with respect to acceleration. Doesn't always seem to happen. Feels like it's losing/gaining a significant amount of power in a ~500-1k rpm band right below when boost starts to build (~3-4k). Problem doesn't seem to be nearly as noticeable, if at all, when it's WOT or even moderately pressed on. Only during a normal, driving two minutes to a gas station, kind of gentle acceleration does it stumble. James says the tune looks fine based on my logs. Anyone have this issue?
PTuning suggested my Primary O2 on the log file didn't look great, but I'm not educated enough on tuning to make a judgement for myself. I can e-mail tunes to anyone. The logs are too large for datazap.
Thanks!
'14 BRZ Limited | SBD500X + HRI Tuning | Tanabe Concept G Exhaust | XXR 527 18x8.75 | Hankook Ventus V12 EVO2 245/40/18
mcbrawr is offline   Reply With Quote
Old 08-30-2020, 01:14 AM   #2
mcbrawr
Worth noting: I've checked all of my piping, the BOV multiple times, all bolts and hoses. No leaks that I can find.
Old 08-30-2020, 01:18 AM   #3
BlOody_BoOger
BlOody_BoOger's Avatar
Drives: Hot lava FRS Monogram Charizard
MAF scaling maybe
BlOody_BoOger is offline   Reply With Quote
Old 08-31-2020, 08:42 PM   #4
jflogerzi
jflogerzi's Avatar
Is that connection under the manifold clamped? I know these can pop up when boosted..
2013 Series 10 FRS #553
Old 09-04-2020, 11:08 PM   #5
dholloway543
Software Hobbiest
Drives: 2015 FRS
Im going to have to agree on maf scaling. If your on ecutek or maybe oft has speed density but when the engine is inside the maf range it could use the maf still. Tuning for the turbo would mainly focus on the speed density tables in order to make it safe but maybe the maf got skipped. If you want to check record a log and see if your LTFT (Long term fuel trim) + STFT(Short term fuel trim) are greater than a 5% value or less than a -5% value. If that is the case then your maf scaling is off.
If your on oft it might be all speed density and the stumble you feel might be temp. based. Speed density doesnt do well with variations in air density such as altitude or temp. If you say it happens after stopping at a gas station it might be heat soaking temp on your intake causing the issue. If thats the case than ECUTEK is probably the solution your looking for.
If not then im out of ideas.
dholloway543 is offline   Reply With Quote
SBD 500x Turbo Kit funkjaw Engine, Exhaust, Bolt-Ons 4 04-22-2020 08:39 PM
SBD Turbo - 400x vs 500x James Russels Forced Induction 29 07-23-2017 11:23 AM
3rd gear inconsistent shifting mike the snake Issues | Warranty | Recalls / TSB 30 11-22-2013 03:54 PM
Inconsistent gear box? wootwoot Engine, Exhaust, Transmission 12 10-07-2013 02:15 PM
