Old 08-14-2020, 11:24 PM   #939
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I had ordered a 75mm pulley from Harrop USA. They didn't have the belts. I got an invoice for wire transfers, but did a credit card transaction over the phone with Chris. I like the Gatorback style belts, so I am going to see if I can find a 4060960 version and see if it'll fit. Technically, it is only a 5mm difference in length.
Just for reference: I found stock numbers for Continental OE/Elite belts in 4060960 (96.0''), 4060965 (96.5''), 4060967 (96.7''), 4060969 (96.9'') and 4060970 (97.0''). No other in between sizes. Looks like the Gatorback (old Goodyear) and Elite models might be phasing out.
Old 08-21-2020, 01:24 AM   #940
byun
byun's Avatar
Drives: 2015 BRZ CWP
Here’s the belt part numbers. I’ve been running continental belts that have been great.
75mm pulley 6PK2445
85mm pulley 6PK2453
90mm pulley 6PK2465
byun is offline   Reply With Quote
The Following User Says Thank You to byun For This Useful Post:
Irace86.2.0 (08-21-2020)
Old 08-21-2020, 10:10 PM   #941
Irace86.2.0
I got a 2440 one. 5mm difference. I’ll have to see if it works on the 75mm pulley just as good.
Old 08-23-2020, 09:30 PM   #942
Chriswongbrz
Drives: 2015 brz
What’s the best oil cooler for the kit besides the Harrop oil cooler?
Chriswongbrz is offline   Reply With Quote
Old 08-23-2020, 11:06 PM   #943
Irace86.2.0
Define best
Old 08-24-2020, 10:29 AM   #944
grumpysnapper
grumpysnapper's Avatar
I run a HKS cooler mounted behind the fog light area on the right front.
I found a set of non fog light plastic grills, and cut away all the plastic between the "grills" for max air flow, and then vented behind the cooler into the front wheel well.
I've also fitted a small electric fan (wired into the water cooling fan circuit) to help during lower speeds.
grumpysnapper is offline   Reply With Quote
Old 08-26-2020, 06:53 AM   #945
FunnyGopher
Drives: 2015 BRZ Limited
Guys! It's 50 state emissions legal now! They just dropped the news on their instagram. I can't find any other reference to it being CARB approved though. I imagine websites and other media will be updated shortly.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
The Following 2 Users Say Thank You to FunnyGopher For This Useful Post:
Irace86.2.0 (08-26-2020), strat61caster (08-26-2020)
Old 08-26-2020, 10:08 AM   #946
Irace86.2.0
Don’t kid! Really?!?
Old 08-26-2020, 10:10 AM   #947
Irace86.2.0
75mm pulley 6PK2445
85mm pulley 6PK2453
90mm pulley 6PK2465
The 2440mm fits fine with room to spare on the 75mm.
Old 08-26-2020, 10:27 AM   #948
Irace86.2.0
https://www.instagram.com/p/CEWNbZlAWOr/
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
BAT_BRZ (08-26-2020), tehShirt (08-26-2020)
Old 08-26-2020, 12:40 PM   #949
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Decided to push the limits of the stock block and see how long it lasts. Switched from the 85mm to 75mm pulley and had Neal @theracersline and Zach @Counterspacegarage dial it in on E85. Pretty impressed with the results
what headers and exhaust do you have on it? this is a similar setup that im thinking about going to next year with power id be looking for. also can it be turned for 93 for places that dont have sheetz?
Old 08-26-2020, 01:48 PM   #950
Irace86.2.0
https://www.ft86club.com/forums/show...&postcount=930
85mm is probably the limits on 93. You could do 75mm, but I don’t know how safe it would be or how much overhead there would be for pulling timing. There would be minimal gains changing the pulleys from 85mm to 75mm on 93, so any tuning for 93 would only be there in case you were stranded without E85.
A boost controller would be better, IMO, than having to change pulleys or having to pull large amounts of timing, but there is still extra heat generated from over-spinning the blower.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
byun (08-27-2020)
Old 08-26-2020, 02:20 PM   #951
Breadman
Breadman's Avatar
not sure how i missed that post. but thank you. i have e85 around me the issue is when i head eat there is only 93. i guess once i get my bonus i can always give them a call and see what they have to say
The Following User Says Thank You to Breadman For This Useful Post:
Old 08-26-2020, 09:05 PM   #952
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
It will cost more but ecutek cam controll the factory bypass valve. You could have a low boost map that operates bleeding boost. Or your can opt for a 3 port and bleed boost through port #3.
There is also a way of doing this with a boost controller or even easy pro's gauge controller which os specifically for that.
https://easyperformance.com/products...ost-controller
The Following 2 Users Say Thank You to Kiske For This Useful Post:
Breadman (08-27-2020), Irace86.2.0 (08-26-2020)
JDL turbo kit owners thread yomny Forced Induction 1352 01-08-2025 05:20 AM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
Harrop car lip kit? djdnz Cosmetic Modification (Interior/Exterior/Lighting) 15 12-15-2015 03:50 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
