Old 08-24-2020, 10:39 AM   #841
prezes_wojtek
Drives: GT86 track usage
To anyone who is using this header: What is header height vs stock header? Is it shorter or taller then stock header? Does it fit OEM bottom engine cover with some space to spare or it's tight fit and any bump to engine cover will impact header too?
Bottom clearance is big topic for me due to quality of roads nearby.
prezes_wojtek is offline   Reply With Quote
Old 08-24-2020, 10:46 AM   #842
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
It seems to vary by person. Many have no issues with the header clearing the engine cover, while for some, it touches. It has become well known that it is recommended to hammer out a couple spots on the cover for the header to have no clearance issues. I did this to be sure before the header install, and never had any problems to begin with.
https://www.ft86club.com/forums/show....php?p=3042220
https://www.ft86club.com/forums/showthread.php?t=96358
Dzmitry is offline   Reply With Quote
Old 08-24-2020, 01:51 PM   #843
prezes_wojtek
That's exactly what I want to avoid: my current custom header had this problem. Looks like no use changing it to ACE then
Old 08-24-2020, 02:10 PM   #844
Dzmitry
Dzmitry's Avatar
Though I don't know your goal, switching to another header like ACE for clearance purposes doesn't sound necessary for you. I don't exactly see the issue to begin with, as no roads that this car is capable of driving on should cause any issues to begin with. What is the worry in hammering out some spots on the cover? The change is something within 0.5" at maximum at those points.
Old 08-24-2020, 03:14 PM   #845
Ernest72
I agree it’s no big deal. Had to hammer two spots to get my JDL uel header to fit. I also put a 1/4 in spacer on the front bolts so the cover is down a bit. No issues.
Old 08-24-2020, 03:22 PM   #846
Ernest72
Originally Posted by conehead View Post
No, I will go from stock to 4-2-1. UEL has that nice subie sound, but it is not the best option for performance. Actually wondering now the different versions of this exhaust compare (150/350/400/etc).
I'm new to this platform so maybe a 4-2-1 option is old news, but I didn't know about it. My SVT Focus came stock with a 4-2-1 and it was perfect. There were no aftermarket headers that could beat it.
I agree if you are trying to maximize gains then EL, but for DD if you want the sound of an UEL then do it. The small gains for NA between headers will not dramatically change your life for DD. Plus the sound might make you think you are faster.
If you are competing, well more is usually better, so EL.
Old 08-24-2020, 04:12 PM   #847
prezes_wojtek
Thanks for answer.
I use my GT86 exclusively on track so I have lowered suspension with progressive springs. However I need to get to track and back and I frequently hit with bottom of engine cover with road bumps. I currently have custom EL header installed and engine well tuned for track. Problem is my header is too big and it pushed out engine cover about 2-3cm down. That's where idea of some other custom EL header is coming from. To get back some of the bottom clearance taken by track suspension and my custom EL header.
I was hoping that ACE will be the answer.
Old 08-24-2020, 04:21 PM   #848
Dzmitry
Dzmitry's Avatar
Thanks for answer.
I mean certainly if your cover is 2-3cm lower than usual, the ACE would get most if not all of that height back for you. In general, if your problem resides in the road hitting your engine cover, then pretty much all headers are equal at that point as your car is built for track. So the problem isn't in your header, might as well go with whatever gains you the bit of clearance back that's the best (assuming money is not of major concern).
Old 08-24-2020, 05:37 PM   #849
CSG Mike
CSG Mike's Avatar
Thanks for answer.
The Ace only needs about 5mm clearancing on the stock undertray. Basically you are taking the ridges and flattening it.
Dzmitry (08-25-2020)
Old 08-26-2020, 05:44 AM   #850
FunnyGopher
Drives: 2015 BRZ Limited
To piggy back this, after hammering my undertray so that the header didn't rub, there was no height change of my undertray. Everything is still in the OEM location and height. There's now just that super tiny bit of clearance needed for the header to not rub.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
The Following User Says Thank You to FunnyGopher For This Useful Post:
Dzmitry (08-26-2020)
nsfwseriouslythisisporn
[REQ]BRZ Independent Fog Lights 1stGenBRZ86 DIY (Do-It-Yourself) Guides 3 04-17-2016 07:34 PM
What do I need for an independent tuner.. Shady195 Software Tuning 2 07-23-2014 10:04 PM
Subaru BRZ/Scion FR-S UEL Header by JDL -- Testing by Moto-East JPxM0Dz BRZ Photos, Videos, Wallpapers, Gallery Forum 13 05-08-2014 09:06 PM
Vortech Finale Review Video | Track Testing | Part 4 of 4 Dezoris Forced Induction 75 04-12-2014 01:45 PM
The Independent Review: Toyota GT86 Boxer-4 Scion FR-S / Toyota 86 GT86 General Forum 31 01-09-2012 07:22 PM
