Old 01-16-2015, 11:35 AM   #15
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Originally Posted by Whatabouteggs View Post
To play devil's advocate, you could run a pulley like that with a wastegate and build boost faster.
A 2.87 pulley with an electronically controlled external wastegate tied to an octane/ethanol sensor would be a kickass tune.
I thought about doing something like that, but at the end of the day I just want to keep it simple. I don't have plans to upgrade internals / clutch stuff yet, so staying under 300hp is ideal currently.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 01-18-2015, 09:14 PM   #16
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Originally Posted by BirgeyT1 View Post
off topic but yopu definitely listen to the Ticket with that awesome username!
Well it was either that or Ragonk Force.
Whatabouteggs is offline   Reply With Quote
Old 01-24-2015, 06:42 PM   #17
Cal3000
Drives: Panda FR-S
I was reading on the vortech website that anything above 10psi you will need to change the bypass valve?
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 06-09-2018, 09:19 PM   #18
enomadra
Drives: 2016 FRS-RS
Originally Posted by Gopherboy6956 View Post
So - Stock is 3.48, then there's 3.125, and 2.87 - I want to run pump gas - so 3.125 is probably the most useful one to nab?
And is the correct gates pulley for that setup the Hundai Genesis one?
Thanks!
I shredded the gates blue racing belt because it jump of the edge of the pulley when I hit the rev limiter. I'm now running the 1/2 shorter belt and it's been good so far 2500 miles. I was a bear to get on but possible.
enomadra is offline   Reply With Quote
Old 12-18-2018, 11:14 AM   #19
Super05
Drives: 6psi 2.5i 180whp looking for more
How big is the crank pulley on the BRZ?
Super05 is offline   Reply With Quote
Old 12-18-2018, 11:43 AM   #20
Gopherboy6956
I'd have to measure one - which I have somewhere in my garage - but the OEM part number is 12305AA370 so you might be able to google it.
Old 12-18-2018, 12:17 PM   #21
Super05
Thanks - Google says 5.826748713587742 - that may not be exact but it's close.
Old 08-22-2020, 04:42 AM   #22
shadowking1711
Drives: Scion FR-S
Do any of you have a part number for the belt required to run the 2.87 pulley? I plan on running it soon with 93/E85 Currently making 363HP on E85
shadowking1711 is offline   Reply With Quote
Old 08-22-2020, 07:33 PM   #23
bfrank1972
Drives: 2013 FR-S Argento
Currently running a 3.125 pulley on 93, maybe making somewhere in the upper 200's, never dynoed. Wanted the smaller pully mostly for a little earlier boost rampup, tuner pulled a bit of timing on the top end.
Related question: stock clutch is holding fine on the power it is making now, if I decide to go flex fuel and run E85, think a new clutch is necessary? I don't typically drive like a lunatic, no heavy slippage/launches, mostly just rolling in-gear stuff.
Sent from my SM-G965U using Tapatalk
Perrin crank pulley / Beatrush alternator pulley Krimlin Engine, Exhaust, Bolt-Ons 7 08-26-2013 10:12 AM
Anyone know what belt size to use for a 3.125 pulley on the Vortech System? tg_1981 Forced Induction 17 08-16-2013 09:50 AM
vortech smaller pulley charged86 Engine, Exhaust, Bolt-Ons 2 08-02-2013 10:02 AM
vortech pulley ft86me Forced Induction 14 06-05-2013 03:27 PM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
