| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 | |
Drives: Blue BRZ Limited with PP
You sure it's not a storm drain? LOL Sent from my SM-N975U using Tapatalk Last edited by ShackAttack; 08-18-2020 at 08:41 AM. |
#16 | |
Sent from my SM-N975U using Tapatalk |
#17 | |
The Dictater
Drives: '13 Red Scion FRS
Also, jack stands are not built to take shock loading, they are likely to collapse as well if either of your jacks fail.... |
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | soundman98 (08-19-2020), WildCard600 (08-18-2020) |
#18 |
Drives: 17 Asphalt 86
A jack, and two stands is enough for DIY.
Something to catch and dispose of the old oil. |
| The Following User Says Thank You to RToyo86 For This Useful Post: | soundman98 (08-19-2020) |
#19 |
I have ramps, you will need a 2x4 in front(2-3 feet long) to give your self extra ground clearance.
#20 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | NoHaveMSG (08-18-2020), soundman98 (08-19-2020) |
#21 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
5qt jugs are between $20 and $25 at Walmart. Filter is no more than $10 for OEM or other quality brand. And auto part stores often have sales for oil and filter, I used to get 6 qts of Castrol and a PureOne filter for under $35 from PepBoys all the time when I had my STi and ran German Castrol
#22 | |
Be Kind
Drives: 2020 86
#23 |
Definitely. 5qt jugs are way cheaper than buying individual quarts
#24 |
JDM Vaping Stance Nation
Drives: 2013 White
Mobil 1 is doing a rebate with their oils. I usually buy mine from walmart. around $23 for a 5 qt. Mobil 1 doing rebate $10 and they're pretty quick. I bought 2 and got my $20 cards already.
Clueless
#25 |
Drives: 2020 Subaru BRZ TS
Is there any DIY garages in your area? Might be worth googling it. The usually offer hourly rates and you can rent their space/tools/lifts. Just throwing in another option. It's quite easy to just do it yourself.
| The Following User Says Thank You to SUSPECT_BRZ For This Useful Post: | soundman98 (08-19-2020) |
#26 | |
Toyota 0W20 oil is actually really good stuff so I use that at about $5 a quart there's nothing cheaper and nothing better, if I don't have time to get to a Toyota dealer I use Castrol Edge high mileage. I use the Subaru filter because they're only about $7-8 now. A fumoto valve and a flat place and the whole thing takes about 10 minutes and you don't need to jack it up if you have a thin catch pan so the chances of you being seen working on the car in the lot can be pretty slim. Next time you get your oil changed have them replace the drain plug with a Fumoto valve so you can do it easily and quickly yourself after that. |
#27 |
I think Walmart is a good option if they have the grates near me. I've got the car with the mechanic for other work and asked him to change the oil while it's on the lift. I'll definitely start doing my own next time, though.
#28 | |
You still have them around?
| Looking For a DIY Garage | Marrk | Southern California | 4 | 03-18-2019 03:54 PM |
| Get it out my garage | PolishFrs13 | Engine, Exhaust, Bolt-Ons | 6 | 01-02-2015 09:40 PM |
| ALL GIRLS GARAGE | White64Goat | Other Vehicles & General Automotive Discussions | 43 | 09-01-2014 03:52 PM |
| No Garage! | Mollusk | BRZ First-Gen (2012+) — General Topics | 29 | 03-13-2013 02:15 PM |
| Garage fr-s | oaroyale | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 01-07-2013 06:38 PM |
