Old 08-17-2020, 07:10 PM   #1
uchiha
Drives: BRZ 2020
Overreving engine with automatic transmition
Hi guys,
I've an automatic 20' BRZ (heavy traffic area, don't hate ).
I usually drive in manual mode and was wondering if it's possible to overrev the engine with automatic transmition.
e.g, i usually downshift at 4k RPM and i get to around 6k rpm when need some power.
What will happen if i downshift at 6k, will the transmition allow it?
Thanks
uchiha is offline   Reply With Quote
Old 08-17-2020, 07:46 PM   #2
Gloonge
Drives: 2013 frs raven
Originally Posted by uchiha View Post
Hi guys,
Thanks
Most autos with a "manual" function have a bunch of nannies that won't let your shift up or down if your outside of the rev range.
Gloonge is offline   Reply With Quote
The Following 2 Users Say Thank You to Gloonge For This Useful Post:
soundman98 (08-17-2020), Spuds (08-18-2020)
Old 08-18-2020, 03:08 AM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
In one instance I did manage to downshift directly into the rev limiter. I have OFT as that is likely different than stock. it has never let me do it beyond that one instance, normally it leaves a cushion of some sort
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
mrg666 (08-18-2020), Spuds (08-18-2020)
Old 08-18-2020, 07:40 AM   #4
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
OFT has a "soft rev limiter" formed by reducing timing to negative values in the top 200rpm or so. The actual "redline" is higher than the engine can achieve in gear because of this. You probably got it right in that range where the transmission saw it was ok, but the timing was reduced.
The Following User Says Thank You to Spuds For This Useful Post:
finch1750 (08-18-2020)
Old 08-18-2020, 09:48 AM   #5
mrg666
pessimistic skeptic
mrg666's Avatar
Hi guys,
Thanks
The transmission does not stop you from down shifting. The rev limiter will cut the throttle if you exceed redline over ~7500 rpm. Manual mode of AT is just "manual" in this car with a very useful rev match. There is just no clutch. I never downshifted directly to a rev above redline though. It is a good thing if AT stops that from happening instead of letting the rev limiter cutting the throttle right after downshift.
Old 08-18-2020, 09:56 AM   #6
mrg666
pessimistic skeptic
mrg666's Avatar
That is good to know and have. Thanks!
Old 08-18-2020, 10:02 AM   #7
I drive in manual mode a good bit. You can downshift pretty much at any point. As mentioned, it's the REV Limiter that keeps you from exceeding redline, not the transmission.
The only time I've seen the transmission do anything "automatic" in manual mode is downshift if you are going slow enough the engine would stall otherwise.
On the other end, you can bounce off the rev limiter to your hearts content as far as i can tell from practical experience.
Old 08-18-2020, 12:57 PM   #8
Spuds
The Dictater
Spuds's Avatar
I understood the question to be whether the AT would let you money shift.
The Following 3 Users Say Thank You to Spuds For This Useful Post:
Dadhawk (08-18-2020), finch1750 (08-18-2020), Ohio Enthusiast (08-18-2020)
Old 08-18-2020, 01:39 PM   #9
In my experience, it will not. Although technically it may let you shift down but at the same time the REV limiter keeps it left of red. I really haven't done it close enough in a while to know for sure.
I suppose never say never, there may be some magic combination of shifting, throttling, left nostril twitching all at the same time that could get past the nannies.
Spuds (08-18-2020)
Old 08-18-2020, 02:23 PM   #10
86TOYO2k17
Drives: 2017 toyota 86
It won’t let you money shift. It also wont skip over gears similar to sequential.
If shifting to a gear would put you above 7400rpm rev limiter it won’t let you shift to the new gear. You can shift into a gear if when shifting it will end up at 7399rpm in the new gear and then immediately bang off limiter if you give it any gas. It also won’t let you up shift into a gear if it will drop RPM too low in the new gear IE 700rpm in 2nd won’t let you shift to 3rd.
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
Irace86.2.0 (08-19-2020), Ohio Enthusiast (08-18-2020)
Old 08-19-2020, 01:53 AM   #11
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
It seems like this was answered already by @86TOYO2k17 but just for extreme clarity, money shifting is the act of accidentally downshifting instead of upshifting, and when this happens, the engine is pulled by the car's momentum and gearing into rpms that exceeds the rev limiter, whether your foot is on the accelerator or not. For instance, if someone took their car to redline in third gear, and instead of upshifting into fourth gear (dropping rpms), they accidentally downshifted back to second gear (raising the rpms).
If we use this chart, and the example I gave, then we see that in third gear at redline we would be traveling around 95mph. If we shifted into second gear by accident then we would still be close to 95mph, and the rpms would be around 10,500rpms.
The Following 4 Users Say Thank You to Irace86.2.0 For This Useful Post:
churchx (08-19-2020), Dadhawk (08-19-2020), mrg666 (08-19-2020), Ohio Enthusiast (08-19-2020)
Old 08-19-2020, 11:23 AM   #12
mrg666
pessimistic skeptic
mrg666's Avatar
Even worse, if the rev limiter cuts the throttle at the same time when the engine is forced to rev at 10500rpm, there can be engine damage until engine brake slows the car down and rpm decrease below red line. I would imagine that is a big impact load on valvetrain and connecting rods. I have done accidental downshifts before and the AT allowed those. Since the shifting mechanism is sequential, one has to do a triple tap for such a severe case. I think the AT will not do that downshift, but I have no intention to find out.
Old 08-19-2020, 04:22 PM   #13
Irace86.2.0
Not multiple. Downshift at redline by hitting the wrong paddle in an automatic that doesn't lock you out of gear is all it takes. Hit the rev limiter in this situation is good, so the accelerator wouldn't cause even more revs.
Yes, this is bad on the connecting rods and on the valvetrain, specifically for valve float.
Old 08-19-2020, 04:51 PM   #14
WildCard600
WildCard600's Avatar
Drives: 2020 86
That face when you downshift and send the revs to the moon.
"But muh rev limiter...."
WildCard600 is offline   Reply With Quote
The Following User Says Thank You to WildCard600 For This Useful Post:
How to remove engine with automatic tranny? knucklehead DIY (Do-It-Yourself) Guides 3 04-11-2020 12:35 AM
WTB: 2017+ engine from an automatic 86/brz iceblaze Southern California 1 09-12-2019 07:58 PM
Anyone know where I can get a 2013 automatic Scion FR-S main engine wiring harness Mark_1017 Scion FR-S / Toyota 86 GT86 General Forum 3 09-19-2017 04:01 PM
Using handbrake with automatic gt86 and other issues with the automatic version Tommygt86 Scion FR-S / Toyota 86 GT86 General Forum 9 04-06-2015 04:42 AM
