Old 08-17-2020, 12:36 AM   #197
Decep
Drives: 2013 FR-S Series 10
I just adjusted my rebound a bit firmer today, front 10 clicks and rear 8 clicks and surprisingly it seems to ride better. I had kind of gotten annoyed with certain floaty feeling on certain undulations during my commute. Tightening up the rebound made it go away. I don't remember what setting i had before but it was whatever was in the RCE settings instructions for street use.
Also got rid of the floaty feeling i had been getting every once in a while on hard turns.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following User Says Thank You to Decep For This Useful Post:
Racecomp Engineering (08-17-2020)
Old 08-22-2020, 03:13 PM   #198
Butterballz
Drives: Black FRS
Finally installed mine with 7kg Swift Springs. Got a basic alignment so it's not dialed in to where I want the alignment to be but it already rides much better than the B8 + Tarmac Springs on the recommended street setting. Feels less harsh on the street and feels much more composed while cornering. The only hard part about the install was removing the front camber plates since I used my Raceseng Cascam. The shock nut had locktite on it so it took a bit of force to remove it and the strap wrench method did not work at all to hold the shaft from spinning. Had to put a socket on the top of the rod which was a bit worrying since I didn't know if it could handle the torque before breaking but it held. The torx bolt on the camber plate was also hard to remove and I almost stripped one trying to remove them.
Butterballz is offline   Reply With Quote
The Following 2 Users Say Thank You to Butterballz For This Useful Post:
cueball89 (08-22-2020), Racecomp Engineering (08-22-2020)
Old 08-23-2020, 02:40 AM   #199
marco_mc22
Drives: Toyota 86
How much torque the top nut need?
marco_mc22 is offline   Reply With Quote
Old 08-23-2020, 07:07 PM   #200
Butterballz
Drives: Black FRS
KW instructions say 26ftlb for the front m12x1.25 nut but I couldn't get it to torque with a crowsfoot wrench and didn't want to risk snapping the top of the shaft. I just gave it a decent snug by hand. The nut I used kinda screwed in a bit tightly since there was some leftover loctite on the threads so it's been holding so far. It's 15ftlb for the rear shocks but since I used the vorshlag top mounts, I couldn't use two nuts to lock them together so I put a bit of loctite and torqued it to 15ftlb.
Old 09-08-2020, 02:52 AM   #201
jflogerzi
jflogerzi's Avatar
We'll add me to the list. Gonna order some tomorrow. Can't wait to get them installed
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Racecomp Engineering (09-08-2020)
Old 10-03-2020, 02:59 AM   #202
jpixel
Drives: 2014 BRZ, 2018 Caymen s
Hey guys, anyone order these and not receive them yet? I ordered mine in July and its still in Germany - Wondering if anyone else has had that experince or just my order?
jpixel is offline   Reply With Quote
Old 10-03-2020, 12:18 PM   #203
We do still have a few people waiting on their SS1's but we've stayed in touch and respond to emails as fast as they come in. Mix of covid19 supply chain delays and in the final stages fedex international also delaying sometimes.
Our apologies but we'll make good on it, we always do.
Myles Williams
RCE
Old 10-06-2020, 11:10 PM   #204
ayoshioka1
Drives: 2019 BRZ / E36 325is
just got my ss-1 in today and i went ahead and installed swift 7k rear along with Raceseng 1inch shock tops.
will install before next track day for buttonwillow before the next coming week.
very excited to try these out and compare vs my current cusco setup.
thanks myles for the help and getting these out to me in a timely manner and answering all of my questions!
23 GR86 Halo MT Prem - Racecomp Engineering SS-2 - Sayber Designs - Voltex - RE71RS - Project Mu
ayoshioka1 is offline   Reply With Quote
The Following 4 Users Say Thank You to ayoshioka1 For This Useful Post:
Mike_ZN6 (10-06-2020), pinoy_dorifto (10-07-2020), Racecomp Engineering (10-07-2020), TylerLieberman (10-07-2020)
Old 10-08-2020, 06:28 PM   #205
Happy to get the text Monday night that the coilovers showed up. Goes to show how wrong tracking numbers can be! Sorry it took so long.
Myles Williams
RCE
Old 10-08-2020, 06:29 PM   #206
Absolutely! Glad things worked out.
Give me some feedback on the 7k rear setup.
Myles
Old 10-08-2020, 11:04 PM   #207
ayoshioka1
Myles
Will do, had some issues with the raceseng top mounts so i scrapped those and used oe mounts. should be able to finalize ride height and get an alignment sometime next week. car already feels a lot better in terms of ride quality and can definitely feel increase in compression stroke. car does not feel harsh and does not crash over bumps like my previous setup. This should translate to more grip on track hopefully. Have street rebound set to 12/14 clicks which seems to be a good sweet spot.
The Following 3 Users Say Thank You to ayoshioka1 For This Useful Post:
falcon_wizard (06-04-2022), Racecomp Engineering (10-09-2020), Thefalls (10-09-2020)
Old 10-13-2020, 08:29 AM   #208
jpixel
Myles Williams
RCE
Sorry forgot to follow up! Huge shout out to Myles for going the extra distance on this one! It was an error from KW and no fault of Racecomp at all. Appreciate it, Myles!
Getting them installed tomorrow and very excited about that.
The Following User Says Thank You to jpixel For This Useful Post:
Racecomp Engineering (10-13-2020)
Old 10-13-2020, 06:19 PM   #209
ayoshioka1
Got the car aligned yesterday. Was only able to max out the camber to 3.1 in the front with oe crash bolts maxed out at the knuckle and top hat. From recent tire temp data -3 was a pretty good starting point as it showed about a 10 degree delta from inside to outside. Rears were set to around -2.4 as that too showed good tire temps with a delta of 10 degrees from inside to outside from the previous track day. To keep things consist I have kept the alignment fairly similar to before but added some tiny bit of toe out in the front to help with turn in and slight toe in the rear. Excited to test these out on track this weekend and will follow up with some feedback.
The Following User Says Thank You to ayoshioka1 For This Useful Post:
Old 10-13-2020, 07:34 PM   #210
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
I think that is as much camber as you can get with SS-1 on OEM crash bolts. I have that exact setup and I am very nearly maxed out at -2.7 in the front.
Mike_ZN6 is offline   Reply With Quote
SuperStreet ToyoTires Meals N' Wheels Meet at Edgie's in Milpitas - photos & videos PMok Northern California 5 02-09-2015 06:26 AM
-0.5 for RaceComp Engineering wrxneffect User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-04-2014 05:21 PM
Mackin FR-S Superstreet Cover Evasive Tuned! Out Now!!! Evasive Motorsports FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 18 12-07-2013 11:20 PM
Racecomp Engineering industrial User/Vendor/Sponsor Reviews, Feedback, Comments 0 05-02-2013 05:17 PM
Racecomp website down? Mikepage Off-Topic Lounge [WARNING: NO POLITICS] 8 04-22-2013 04:12 PM
