go_a_way1, MisterSheep
Old 08-16-2020, 08:02 AM   #22247
Purist
Purist's Avatar
Drives: Subaru BRZ
Originally Posted by fminicooper View Post
Whiteline rear bushings. And yes I crossed threatened one bolt.
Perrin lock outs.
Removed Eibach rear away bar. Trying OEM again.
Coming Bilstein B6 rear struts.
Sent from my SM-G892A using Tapatalk
How long did it take? Did you have to take any components out to press out the old bushes?
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 08-16-2020, 09:43 AM   #22248
new2subaru
Weight Weenie
Drives: 15 FR-S
Last couple of days.
Put the rear interior, carpet and trunk pieces back in. Detailed the interior. Going on a short trip soon and wanted to dull the noise and make it it a bit more habitable lol
Removed the rear whitline sway bar due to noise. I have to figure that out yet. Squeak, squeak, SQUEAK!
Old 08-16-2020, 11:11 AM   #22249
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Ran two 30 min sessions on the west track at CMP yesterday. I was in good company, this old Datsun ran in the group and made some cool noises.
RIP to the outter edge of my driver front tire. Needs more camber, and probably a rotation between sessions.
Old 08-16-2020, 02:25 PM   #22250
jflogerzi
jflogerzi's Avatar
Autocross day at Fontana AAA speedway
2013 Series 10 FRS #553
Old 08-16-2020, 02:30 PM   #22251
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Cleaned up some stuff for the rebuild!
No "before" photos of the alternator but it was grungy
The Following 4 Users Say Thank You to DarkPira7e For This Useful Post:
Bobharp (08-16-2020), Cedric (08-16-2020), MJones_RB (08-17-2020), new2subaru (08-16-2020)
Old 08-16-2020, 03:03 PM   #22252
TheBossMan
Drives: White Toyota 86
DIY Upgrades
Wussup Gang
My first time on this platform.
I'm busy upgrading my clutch and flywheel, using the OEM parts:
- Re-compounding the clutch plate with high performance compound
- Skimming the flywheel friction surface as well as taking some meat of the back.
I want to build a DIY custom turbo kit for my car and need some help, is there anyone that can assist?
Thank you.
TheBossMan is offline   Reply With Quote
Old 08-16-2020, 03:15 PM   #22253
jflogerzi
jflogerzi's Avatar
Originally Posted by TheBossMan View Post
Wussup Gang
Thank you.
Get stronger rated parts. OEM is not going to handle a turbo kit as you turn up boost or run e85. Southbend is very OEM like just beefed up
The Following User Says Thank You to jflogerzi For This Useful Post:
DarkPira7e (08-16-2020)
Old 08-17-2020, 01:38 AM   #22254
fminicooper
Drives: FRS Hot Lava
Just in case it seems unfortunatly I misslead the right name.
I did the KDT922 "Whiteline Rear Crossmember Mount Insert Bushings"
You dont need a press.
it took me several hours, including the repair of the thread, I swet like a pig.
fminicooper is offline   Reply With Quote
The Following User Says Thank You to fminicooper For This Useful Post:
Purist (08-17-2020)
Old 08-19-2020, 03:55 AM   #22255
Cedric
Cedric's Avatar
Drives: 2013 Scion FR-S 10 Series
WHAT DID YOU DO TO YOUR FRS TODAY?
Installed the 80mm Tomei frontpipe and overpipe. Now I’m just waiting for the catback to come in September and the car will have a full Tomei exhaust. It already sounds crazy right now, the catback is gonna make it a little quieter but it’s gonna sound way nicer than the muffler delete that’s on the car.
Make sure you wear gloves when handling titanium, and if you make contact with it, wipe it with rubbing alcohol before you start it!
Also if anybody is wondering, the Tomei 80mm frontpipe fits the stock midpipe.
Sent from my iPhone using Tapatalk Pro
Cedric is offline   Reply With Quote
The Following 3 Users Say Thank You to Cedric For This Useful Post:
Clipdat (08-22-2020), mrg666 (08-19-2020), SuperTom (08-21-2020)
Old 08-19-2020, 12:03 PM   #22256
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Requested quotes for shipping it (my FR-S) to the island of Hawaii. I'll be moving in 6 months.
Lil update:
Healthy
Happily married
Unemployed (Semi-retired?) Still deciding lol
Excited about life!
ALOHA!
I LIKE TIRES!
The Following 5 Users Say Thank You to Leonardo For This Useful Post:
Clipdat (08-22-2020), humfrz (08-19-2020), mrg666 (08-19-2020), new2subaru (08-19-2020), NoHaveMSG (08-19-2020)
Old 08-19-2020, 12:27 PM   #22257
mrg666
pessimistic skeptic
mrg666's Avatar
Lil update:
Healthy
Happily married
Excited about life!
ALOHA!
WOW! Good luck and have fun!
The Following User Says Thank You to mrg666 For This Useful Post:
Leonardo (08-19-2020)
Old 08-19-2020, 08:54 PM   #22258
Lil update:
Healthy
Happily married
Excited about life!
ALOHA!
Sounds great!
I got the picture -
Old 08-19-2020, 10:06 PM   #22259
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Lil update:
Healthy
Happily married
Excited about life!
ALOHA!
You don't even hit 3rd gear until you hit the other shore.
Good luck!
Old 08-20-2020, 12:50 AM   #22260
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
So I had some stripes added to my car by 9Livery today and I'm REALLY impressed with how much the pattern matches my TRD fins. Probably the only thing that sucks is that the TRD CF patterns are not as noticeable from afar, but then again perhaps the unintended subtlety is a good thing.
Name:  cf stripe.jpg
Name:  cf stripe 2.jpg
The Following 3 Users Say Thank You to KR-S For This Useful Post:
beltax90 (08-20-2020), MJones_RB (08-20-2020), NoHaveMSG (08-20-2020)
