Old 08-12-2020, 05:14 PM   #15
ozafar
Drives: 2015 Scion FRS Release Series 1.0
In the true DD spirit, I tried to drive into as deep snow as possible. It worked!
ozafar is offline   Reply With Quote
The Following User Says Thank You to ozafar For This Useful Post:
p1l0t (08-12-2020)
Old 08-13-2020, 10:05 AM   #16
ozafar
First set of rims I bought. Plastidipped them black so I can sell them in the future in the color they came (which was gold).
Installed the APR splitter too. If I could do it again, I would've mounted it independently from the bumper. Alas, I mounted it to the bumper and now it points slightly upwards.
(BTW, the yellow line on the edge of the splitter is my own drawing to see how it would look, I must have deleted the original picture.)
Old 08-13-2020, 10:07 AM   #17
ozafar
Tinted the headlihgts and indicator lens black.
Old 08-13-2020, 10:10 AM   #18
ozafar
The next set of upgrades are mostly all turbo-related. I wanted to have good airflow before installing it, so I got the Seibon vented hood.
First I installed it with QL-38 hood pins (yes, drilling into a new CF hood IS SCARY)
Then I had to get the car ready for paint. After it was done, I couldn't have been happier.
Old 08-13-2020, 10:13 AM   #19
ozafar
Standing rain water actually confirms the effectiveness of the hood. Before I leave the house, the whole hood has water droplets on it.
After 10 min of freeway driving, parked at the office I can see all the water is gone except the droplets behind the vents.
This means there must be airflow upwards out of the vents, creating a low pressure field behind it.
It's pretty cool to see water just sitting there while going 85 mph lol
Old 08-13-2020, 01:31 PM   #20
ozafar
As I upgrade, I sell OEM parts as soon as I can. Seems that the person buying my header was a fellow Release Series owner!
Old 08-13-2020, 02:31 PM   #21
ozafar
Speed By Design 500X advice
Around this time I had the turbo installed. I don't have any pictures, but I can give advice for anyone looking to install a Speed By Design 500X:
1. Make sure you install both PCV and CCV catch cans. They will catch more oil than you will guess.
2. Make sure you weld the metal front pipe bracket provided. It is only welded on one side! Trust me, have that other side welded too.
3. I used Shiv @OFT for tuning, I would highly recommend.
4. Make sure you replace all bolts and studs provided with Grade 8 or higher bolts
5a. DO NOT use any exhaust wrap. ESPECIALLY headers. The trapped heat will FAIL the welds. Instead, spend a little extra and get a vented hood. That heat needs to escape, so give it airflow to escape.
5b. Do not use the turbo blanket. Again, that heat will ruin your bearings. Instead, protect you air intake tube with some wrap.
Basically, wrap should be used to keep things that should stay cool from getting hot, not preventing hot things from getting other components hot.
Old 08-13-2020, 02:32 PM   #22
ozafar
Here is that front bracket that will fail if not welded on both sides.
Old 08-13-2020, 02:34 PM   #23
ozafar
Put my snow tires back on for the winter. Some fun winter pics!
Old 08-13-2020, 02:38 PM   #24
ozafar
Next was the diffuser. After its installation I could see water fly up into the air like never before, when it rained. The installation is actually quite easy.
Old 08-13-2020, 02:41 PM   #25
ozafar
Size of the diffuser compared to the car
Old 08-14-2020, 09:44 AM   #26
ozafar
Some more front end downforce to balance to diffuser. These are ACE canards, painted to match.
Old 08-14-2020, 09:48 AM   #27
ozafar
Next was the oil cooler. Took some time, but well worth it since you absolutely need one to track the car. I added mesh fog light bezels to help airflow.
Later on, I added a switch-operated cooling fan to that oil cooler to really get some nice airflow.
Old 08-14-2020, 09:53 AM   #28
ozafar
Parked next to a ZL1 1LE, a Ram 3500 Megacab, and a tractor. LOL
Dzmitry (08-14-2020)
Release Series 2.0 daftpunk Scion FR-S / Toyota 86 GT86 General Forum 25 11-20-2015 01:44 PM
FS: DRL Mod for Monogram/10-Series/Release Series 1.0 leoh007 Exterior Parts (Aero, Lighting, Etc.) 0 05-12-2015 01:15 PM
FS: DRL Mod for Monogram/10-Series/Release Series 1.0 leoh007 Audio/Visual, Electronics, Infotainment, NAV 0 05-12-2015 01:14 PM
10-Series Totaled w/ 10 Miles. 636 Scion FR-S / Toyota 86 GT86 General Forum 40 01-03-2014 06:49 PM
