Old 08-13-2020, 09:04 AM   #225
seanp.97
seanp.97's Avatar
Drives: 2018 BRZ tS
Originally Posted by dragoontwo View Post
Did you check the OZ website to see fitment options for that wheel?
yeah, but they only give a range of the possible offsets they have. not very specific on which numbers within that range is used for manufacturing.
seanp.97 is offline   Reply With Quote
Old 08-13-2020, 10:33 AM   #226
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I suppose you're right. I thought they had their specs broken out like most other wheel companies. If Tire Rack list them at that spec, they probably are. You could always reach out to them to confirm.
The Following User Says Thank You to dragoontwo For This Useful Post:
seanp.97 (08-13-2020)
Old 08-13-2020, 01:26 PM   #227
Flukester
Flukester's Avatar
Drives: 2019 BRZ - Raiu
Originally Posted by timurrrr View Post
Can you please figure out if spacers are needed or not?
Paging @mixxxx and @CL._.86
I am also trying to find out if 57DR 17x9+38 wheels require spacers or not. Especially on a BRZ with Performance Package and completely stock suspension. (No camber bolts, stock struts, etc).
Also, is there any rubbing on the fenders in the front (fenders not rolled) or any rubbing at full steering lock?
Looking at getting these wheels and run some 245/40R17 tires (not sure what exactly, possibly RS4 or RE71R or perhaps something less sticky at first).
Can anyone please confirm if 57DR 17x9+38 wheels fit on an otherwise stock BRZ PP ?
Thanks!
Fluke
Flukester is offline   Reply With Quote
Old 08-13-2020, 09:53 PM   #228
mixxxx
mixxxx's Avatar
Thanks!
Fluke
no spacers needed. no rubbing. worked fine when i took it to the track.
mixxxx is offline   Reply With Quote
Old 08-14-2020, 10:29 AM   #229
Flukester
Flukester's Avatar
Thanks @mixxxx !
Could you please confirm if you have (or had at that point) a completely stock suspension or not? How close are the spokes to the Brembo calipers in the front?
Thanks!
Fluke
The Following User Says Thank You to Flukester For This Useful Post:
mixxxx (08-16-2020)
Old 08-14-2020, 10:57 AM   #230
pslater
Drives: 2017 Golf R
hey are these actually 17x8 or 17x7.5? cuz tire rack’s got ultraleggeras 17x7.5 et35, and it got me confused cuz i haven’t seen anyone talk or post about 17x7.5 ultraleggeras. does anyone know if they might’ve made an error on their website, or if they really do exist, do they also clear the pp brembos?
they're 17x8.
if you go to OZ's website, you can find the full size listings that they produce. tire rack doesn't have every size known to man. (they're also very conservative with recommended fitments.)
the 17x7.5's do exist as far as i'm aware. no idea if they clear PP/RS/tS brembos, but i would imagine they do based on the spoke design.
pslater is offline   Reply With Quote
The Following User Says Thank You to pslater For This Useful Post:
seanp.97 (08-14-2020)
Old 08-14-2020, 11:06 AM   #231
seanp.97
seanp.97's Avatar
Drives: 2018 BRZ tS
Originally Posted by pslater View Post
they're 17x8.
thank you! appreciate the reply
Old 08-14-2020, 02:20 PM   #232
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
We'd appreciate if you could share close-up pictures clearly showing the distance between the wheel and the calipers.
The Following 2 Users Say Thank You to timurrrr For This Useful Post:
calcal (08-14-2020), Flukester (08-14-2020)
Old 08-14-2020, 04:16 PM   #233
NaturallyAspirated
NaturallyAspirated's Avatar
Drives: 2019 BRZ w/ PP
@spike021 has 17x9 +38 57DRs as well (thread here)
I think he's lowered on RCE Yellows but the coil diameter should be similar so that you can compare the spacing to the inside of the tire.
NaturallyAspirated is offline   Reply With Quote
Old 08-14-2020, 05:39 PM   #234
spike021
spike021's Avatar
Yeah, this.
I did need 3mm spacers in front because I don't have camber plates, and the tires I chose (Continental ExtremeContact Sports) have a wider sidewall than I initially expected at the time. So they were touching the strut perches ever so slightly. I'm running -1.6 or so in front with camber bolts right now.
I'd assume with less negative camber I would've had better clearance. That or, of course, using camber plates as well.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following User Says Thank You to spike021 For This Useful Post:
NaturallyAspirated (08-14-2020)
Old 08-25-2020, 08:01 PM   #235
seanp.97
seanp.97's Avatar
Drives: 2018 BRZ tS
Originally Posted by stanrc View Post
I have the Konig Hypergram 17x8 +40 and I would say technically they do fit. The rubber cap on the bleed valve comes incredibly close though. I put on a 3mm spacer on the front just to be safe.
did you have the 3mm spacer on in those pictures, or were those pictures taken without the 3mm spacer?
Old 08-25-2020, 10:07 PM   #236
stanrc
Drives: 2017 BRZ
Those were taken without the spacer! I drove around for a few weeks and even did a track day with no spacer and there were no issues, but it did make me nervous so I put on the 3mm spacers later.
stanrc is offline   Reply With Quote
Old 08-25-2020, 10:18 PM   #237
seanp.97
seanp.97's Avatar
Drives: 2018 BRZ tS
oh no issues without the spacers really?? it looks so dam close im so surprised lol..
also if you dont mind answering again, how’s the clearance between the barrel of the wheel and the calipers?
Old 08-25-2020, 10:41 PM   #238
SkyeHack
SkyeHack's Avatar
Drives: 2018 BRZ tS
Ray's Gram Lights 57CR Wheel - 17x9 / 5x100 / Offset +38
Michelin Pilot Sport 4 S 245/40/17
Stock Suspension
SkyeHack is offline   Reply With Quote
brz, performance package, wheels
Finding wheels to clear brembos jojosbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-13-2018 09:46 AM
Performance package Brembos Ernest72 Want-To-Buy Requests 2 07-14-2018 09:06 AM
Performance Package Brembos Freezing to Wheels? texastwurkt3am Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-23-2018 09:31 AM
What pads fit the Performance Package Brembos? mistople Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-03-2018 06:15 PM
