Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-07-2020, 08:16 PM | #1 |
Drives: 2013 FRS 6MT Hot Lava
OEM Piston Weight - Re-Balance?
Hi all,
I'm planning on rebuilding my 2013 FRS engine soon with all OEM parts except for pistons. I want to go with 13.5:1 compression and 87mm diameter to get a tiny bit more NA power with E85. My question is: When I get aftermarket pistons that are a different weight from OEM (I cant find OEM piston weight info anywhere) will I have to re-balance the engine in any way? Thanks, Joe |
08-09-2020, 02:46 PM | #3 |
Drives: 86
Why not swap out for stronger rods while everything's apart?
08-09-2020, 09:13 PM | #4 |
Drives: Scion FR-S 10 Series
08-10-2020, 02:00 AM | #5 |
Seņor Member
Lighter rods don't seem to be a thing for the FA20
1974 TA22 Celica
2013 86 GT |
08-10-2020, 12:26 PM | #6 |
Drives: JRSC BRZ SOLD
No need for stronger rods when NA and apart from one fella with custom Ti con rods the OEMs are plenty light. If anything maybe make sure the current or new OEM rods are all of equal weight and balanced since the new pistons will be. |
08-10-2020, 12:34 PM | #7 |
Drives: 2017 toyota 86
Get some head work done while the heads are off. oversized valves, springs, port/polish etc... maybe even a cam. Rev her out to 7800 with the 13.5 compression, and get an ace 150 header for that top end. Maybe toss in some ITBs. you could Probably have The highest WHP non stroked NA FA20.
08-10-2020, 12:45 PM | #8 |
Just throw $15k at it. NBD
08-10-2020, 01:53 PM | #9 |
08-10-2020, 01:59 PM | #10 |
Drives: Crapcan
That way the rocker arms come out at higher velocity
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
08-10-2020, 02:12 PM | #11 |
08-11-2020, 02:21 AM | #12 | |
Drives: 2017 86 860 Special Edition
The Following User Says Thank You to RayRay88 For This Useful Post: | PulsarBeeerz (08-11-2020) |
08-11-2020, 02:07 PM | #13 | |
Yup the only ones that seem to have it figured out are Element Tuning and after you add up all the stuff mentioned, you are well over $15k... Smarter to wait for the KMiata K24 swap in reality. |
The Following User Says Thank You to PulsarBeeerz For This Useful Post: | NoHaveMSG (08-12-2020) |
08-11-2020, 11:28 PM | #14 | |
Seņor Member
1974 TA22 Celica
2013 86 GT |
The Following 3 Users Say Thank You to Turdinator For This Useful Post: |
Similar Threads | ||||
PP Brembo front rotor weight, lighter-weight alternatives? | ZDan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 30 | 02-14-2022 07:03 PM |
Balance | d1ck | Tracking / Autocross / HPDE / Drifting | 25 | 07-28-2014 01:20 PM |
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) | glamcem | Tracking / Autocross / HPDE / Drifting | 21 | 07-01-2014 11:38 AM |
Weight Ratio/Balance Varies p/transmission? | makesdrivingfunagain | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 03-27-2014 10:49 PM |
More on the CG and balance... | Carban | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 09-28-2012 07:07 PM |
