go_a_way1
Old 08-03-2020, 02:34 PM   #5531
CSG Mike
CSG Mike's Avatar
Originally Posted by degozaru View Post
I'm looking at a JRSC and I would like to run it with a perrin oil cooler. Is this possible without too much fiddling with drills?
Nope... they'll want to occupy the same locations.
Just get the JR oil cooler.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
degozaru (08-04-2020), HachiRokuX (08-06-2020), Milhouse86 (08-03-2020), Side (08-03-2020)
Old 08-05-2020, 01:17 AM   #5532
Escher
Escher's Avatar
Drives: 2015 FR-S
It's happening this weekend y'all.
Escher is offline   Reply With Quote
The Following 5 Users Say Thank You to Escher For This Useful Post:
CSG Mike (08-06-2020), HachiRokuX (08-06-2020), ML (08-05-2020), pallen (08-05-2020), wheelhaus (08-05-2020)
Old 08-06-2020, 01:53 PM   #5533
degozaru
Drives: 2016 oceanic frs
Thanks Mike...
If you're ever bored during lunch break, feel free to PM me and let me know about how long my backorder (vincent chan) is
I'm afraid to ask David cause I annoyed him so much already asking a bunch of questions about the supercharger
degozaru is offline   Reply With Quote
Old 08-06-2020, 02:26 PM   #5534
CSG Mike
CSG Mike's Avatar
Thanks Mike...
Just email sales@ for an update, but everyone is having issues due to Covid slowing supply chains down.
I know he's got some NA oil coolers in stock. FI I'm not sure but usually he tries to keep at least 2.
Old 08-07-2020, 10:22 PM   #5535
Escher
Escher's Avatar
Drives: 2015 FR-S
Help me forum, you're my only hope.
Step #21 of the installation ask me to first thread the 180mm stud, shorter threaded side first, into the alternator so that two (2) threads are still visible poking out of the rear mounting point. Done and done.
Next, step #22 directs me to thread the 19mm long coupling nut onto the thread until it is seated against the alternator, thus setting the mounting point appropriately.
I have guaranteed this is the correct stud, and the correct coupling nut (they were actually already threaded together in the packaging).
The problem is: there isn't enough thread on the long end coming out of the alternator to seat the coupling nut against the alternator. There's a solid inch or so of bare stud which the nut can't get to. Anyone know what gives here?
Old 08-08-2020, 09:16 AM   #5536
ML
ML's Avatar
Drives: 13 White MT FR-S
can you take a picture?
Old 08-09-2020, 12:20 AM   #5537
Escher
Escher's Avatar
Drives: 2015 FR-S
False alarm. Instructions were somewhat vague. There are two spots where you can see the stud going through the rear of the alternator. I was looking at the more forward one.
Old 08-09-2020, 11:07 PM   #5538
Escher
Escher's Avatar
Drives: 2015 FR-S
No regerts.
The Following 4 Users Say Thank You to Escher For This Useful Post:
CSG Mike (08-10-2020), ML (08-10-2020), mrg666 (09-04-2020), pallen (08-17-2020)
Old 09-04-2020, 01:07 AM   #5539
kowalski
kowalski's Avatar
Drives: 2016 brz
Methanol injection on JRSC - ¿any experiences?
Hi there.
Just curious if anyone has tried to put any methanol/water injection system with the JRSC and what to expect. ¿Is it worth it? ¿Would you be better of with an oil cooler?
At a first glance, it seems it would do no harm (cooler intake temps, arguably extra knock safety). ¿But would it really help make more power? I did not see many info or comments with our brz/86 platform but many other platforms use this system. So...kind of undecided here.
¡Thanks!
kowalski is offline   Reply With Quote
Old 09-04-2020, 01:10 AM   #5540
jflogerzi
jflogerzi's Avatar
Originally Posted by kowalski View Post
Hi there.
¡Thanks!
If your running 91 for sure. 93 less and e85 not worth it. Much better off with an oil cooler first anyways
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
kowalski (09-04-2020)
Old 09-04-2020, 10:38 AM   #5541
86TOYO2k17
Drives: 2017 toyota 86
Hi there.
¡Thanks!
It will make more power, more consistent power, and safer power.
on my setup with 92 octane i ran 14.5 degrees of timing, with WMI alone 17.8 degrees, E45 alone 17.8 degrees and E45 + WMI 21.1 degrees timing.
WMI + E45 will get you the same power/octane benefits/ timing etc as full E85.
WMI is also better than E85 for cooling charge temps.
Also running WMI helps subsidies your fueling system as it has its own pump/nozzle so I did not need to upgrade my injectors / pump like i would have if i was only running E85. and my fuel economy was still very reasonable not being on full E85. If i had easier access to E85 i would probably still just run full E85, but i have 1 station 1.5hour round trip. so i fill up 6 5gallon cans and used 1 5gallon can per fill up (5.5gallons) to space out my trips.
with that being said, i wouldn't get WMI to substitute for an OIL cooler, it will probably help overall temps including OIL a tiny bit. but it is not intended as a full substitute for an OIL cooler, it is just an octane booster / IAT temp cooler.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Old 09-04-2020, 12:13 PM   #5542
kowalski
kowalski's Avatar
Drives: 2016 brz
¡Thanks! very helpful information. ¿This is on top of the JRSC, isn't it? ¿Where did you put the noozel?
Best!
Old 09-04-2020, 03:44 PM   #5543
86TOYO2k17
Best!
I had a sprintex 210 69mm pulley 13psi. E85 or WMI isn’t uniquely beneficial to only one FI system. They all can benefit immensely from more knock resistant fuels and lower intake charge temps.
I had a TB spacer with 1/8npt for nozzle injection.
For a centrifugal style SC i would inject post intercooler but as close to intercooler as possible. This gives it the most time to atomize, absorb, and dissipate heat. Also gives it enough time to lower IATs for the MAF sensor to read the new lower IAT and allow you to adjust the tune accordingly.
WMI is another possible point of failure. But if setup correctly the risk can be heavily mitigated.
The hard part is finding a tuner willing to tune with WMI on this platform. I know xero limit will he did my WMI + FF tune, car ran great and pulled hard. Numerous back to back pulls in hot weather each pull felt the exact same and consistent amount of power. Which on a sprintex is impressive.
Old 09-10-2020, 02:30 PM   #5544
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Hey peeps, I will be purchasing the jackson kit in the near future. My question is support mods, I'm sorry there's 396 pages, that's so much to read to get a simple answer.
There are the support mods that come to mind,
Silicone radiator hoses
Hood vents
Oil cooler/radiator combo
Catch can
Thermostat
Maybe upgraded fans.
Do I need anything else?
I will be using the brz for autox and street.
Thank you.
Dr. BRZ is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
