Old 08-02-2020, 03:41 PM   #71
spike021
spike021's Avatar
the command center speaks volumes about how far tech as come since the moonshots. They have probably 100x the tech on those tables then what was in Mission Control, but it looks empty.
I'm sure it helps that software probably accounts for way more of what used to be hardware, so they can switch screens and stuff faster.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following User Says Thank You to spike021 For This Useful Post:
Dadhawk (08-02-2020)
Old 08-02-2020, 03:59 PM   #72
You would think that they would have some better quality cameras available for the video.
Jdmjunkie (08-02-2020), Ultramaroon (08-02-2020)
Old 08-02-2020, 07:38 PM   #73
Spent it all on the space truck
Old 08-03-2020, 10:38 AM   #74
reni
Nobody beats the B[I|R]Z
reni's Avatar
Drives: shopping cart i stole from walmart
NASA astronuts returning to Earth today:
How do the parachutes not all get entangled with each other?
reni is offline   Reply With Quote
Old 08-03-2020, 11:02 AM   #75
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Dude,
Go-Pros are expensive!
Old 08-03-2020, 11:05 AM   #76
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Dude,
Not compared to the datalink hardware required to send Near Real Time HD video hundreds of miles over the air...
Spuds is online now   Reply With Quote
Old 08-03-2020, 11:14 AM   #77
I would have settled for 640x480. I'm pretty sure some of that stuff was like 25x25.
Besides, they managed to do it OK to show the Roadster getting launched into space.
Spuds (08-03-2020)
Old 08-03-2020, 11:18 AM   #78
Spuds
The Dictater
Spuds's Avatar
The forces that keep the parachutes open makes them somewhat rigid. Since the cords are all the same length, the fabric parts bounce off each other. Additionally, the cords themselves create a somewhat rigid cone due to tension. They can't twist around another cone, because as soon as you increase the tension on one side, it causes the whole thing to want to spring back the other way.
The Following 3 Users Say Thank You to Spuds For This Useful Post:
Dadhawk (08-03-2020), reni (08-04-2020), soundman98 (08-03-2020)
Old 08-03-2020, 11:20 AM   #79
It has to do with airflow coming off the outside of the parachutes. They do actually bounce off each other but the air coming off the outside keeps them separated for the most part. If you watch this video starting about 23:25 you can see them deploy and bounce off each other. Since the capsule isn't turning they don't get intangled. If the capsule was spinning they would wrap around each other.
Spuds (08-03-2020)
Old 08-03-2020, 08:36 PM   #80
brewloc
brewloc's Avatar
Drives: '20 86 MT
They also use historical data from lots of testing. We have been using chutes for cargo drops for quite a while. This PPT shows some of that testing data and the understandings of multi-chute behavior we get from testing (slide 35 / collisions).
brewloc is offline   Reply With Quote
The Following 4 Users Say Thank You to brewloc For This Useful Post:
Dadhawk (08-03-2020), reni (08-04-2020), Spuds (08-18-2020), Tcoat (08-04-2020)
Old 08-04-2020, 08:59 PM   #81
brewloc
brewloc's Avatar
Drives: '20 86 MT
SpaceX just did a test hop of SN5 and it was badass!!
And it landed!!
Old 08-18-2020, 12:07 PM   #82
brewloc
brewloc's Avatar
Drives: '20 86 MT
Today's Starlink 10/SkySats 19-21 launch marks the successful reuse of a falcon 9 booster for the sixth time. The same rocket has launched six different payloads into space.
The Following 3 Users Say Thank You to brewloc For This Useful Post:
Dadhawk (08-18-2020), Spuds (08-18-2020), Ultramaroon (08-19-2020)
Old 09-14-2020, 04:11 PM   #83
JD001
JD001's Avatar
Drives: Subaru BRZ
It's life, Jim, but not as we know it... What has Venus just burped!!!
The Following User Says Thank You to JD001 For This Useful Post:
Spuds (09-14-2020)
Old 10-15-2020, 03:50 PM   #84
Spuds
The Dictater
Spuds's Avatar
Refueling in space sounds fun.
https://arstechnica.com/science/2020...aft-refueling/
brewloc (10-18-2020), Dadhawk (10-15-2020)
Which Space Saver will fit? Andrew666 AUSTRALIA 25 06-18-2020 10:07 AM
Cockpit Space Chad86 Scion FR-S / Toyota 86 GT86 General Forum 7 03-15-2014 04:24 PM
First run 86's (Space Saver question) DriftEightSix AUSTRALIA 11 01-10-2013 08:25 AM
FR-S space saver sierra Scion FR-S / Toyota 86 GT86 General Forum 2 11-29-2012 01:18 AM
Trunk space? tranzformer Scion FR-S / Toyota 86 GT86 General Forum 34 04-13-2011 01:29 PM
