Old 07-30-2020, 09:10 PM   #141
ZDan
ZDan's Avatar
Drives: '23 BRZ
OK, I'm gettin this battery (LFX36L3-BS12), what's my best bet for terminals? Thesez per 86TOYO2k17? https://www.amazon.com/dp/B00EB8Z60G..._fpugEbKRVQFA0
Old 07-30-2020, 09:17 PM   #142
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
Does that Amazon link still work for you?
You could also try 4xspower.com. Part numbers 558 and 580 in the Accessories/Terminals section.
Mike_ZN6 is offline   Reply With Quote
The Following User Says Thank You to Mike_ZN6 For This Useful Post:
ZDan (07-30-2020)
Old 07-31-2020, 01:44 PM   #143
ZDan
ZDan's Avatar
Drives: '23 BRZ
Thanks! think I'll order those up...
Might get 586 instead of 580, as it looks like 3/4" spacers might not be enough to get the terminals above the top of the battery (looks like about 1" needed)
Old 07-31-2020, 02:11 PM   #144
Mike_ZN6
Mike_ZN6's Avatar
Okay, let me know how they fit. I am planning to get the same battery when mine gives out.
ZDan (07-31-2020)
Old 07-31-2020, 02:12 PM   #145
86TOYO2k17
Drives: 2017 toyota 86
Oddsey Battery 3217-0006 SAE Battery Terminal Kit https://www.amazon.com/dp/B00EB8Z60G..._SPxzB7GIz5AJtName:  BB5D1A55-4BA4-45B4-9A76-507D9170F409.jpeg
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
ZDan (07-31-2020)
Old 07-31-2020, 02:50 PM   #146
ZDan
ZDan's Avatar
Drives: '23 BRZ
I ordered the XS Power 558 and 586 thru Crutchfield. See how that goes, might end up getting smaller spacers and/or shorter terminals if this is too tall...
Old 07-31-2020, 02:56 PM   #147
86TOYO2k17
These Terminals come with the correct spacers and everything that’s needed.
With the dimensions and fitment of everything (depending on how you mount/secure the battery) it’s beneficial to have the terminals spaced outward further apart. Which is an added bonus of these ones.
ZDan (07-31-2020)
Old 07-31-2020, 03:45 PM   #148
ZDan
ZDan's Avatar
Drives: '23 BRZ
Thanks, will see how it goes with what I ordered, this'll be backup plan...
Old 01-18-2021, 10:27 AM   #149
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
Just wanted to post up an inexpensive terminal option that worked for me.
Xs power tall brass posts previously mentioned, but buy through Crutchfield at a cheaper price.
https://www.crutchfield.com/S-EGpZGW...ass-Posts.html
Plus the XS power 557 i-Bar adapter kit, which is basically some brass spacers.
https://www.crutchfield.com/S-Wj9gKV...apter-Kit.html
I then bought some various lengths of stainless m6 fasteners. I believe the final length was m6x35mm.
As you can see the height is perfect for the terminals. I know there are plenty of folks that have used the supplied brackets, but I was wanting a more solid solution. This does the trick.
Untitled by hatchethairy, on Flickr
captain awesome is offline   Reply With Quote
The Following User Says Thank You to captain awesome For This Useful Post:
SubieDoo (01-12-2022)
Old 01-22-2021, 08:45 PM   #150
86TOYO2k17
Pic of it mounted?
Using oem battery tray holes underneath battery?
Old 01-22-2021, 09:10 PM   #151
captain awesome
Wears Pants
Originally I was going to make something but hit the easy button instead. I picked up a used Kinetic Custom Machine bracket. I’m missing the piece that bolts it to the stock bracket but if I can’t locate one I’ll rig something up.
battery bracket by hatchethairy, on Flickr
The captive dogbone part in the pic above goes under this.
This is how it sits though.
Bonburner (01-22-2024)
Old 01-22-2021, 09:38 PM   #152
Mike_ZN6
Mike_ZN6's Avatar
I used the XS Power 558 I-BAR adapters with the XS Power 580 posts. This setup sits a bit taller than yours with the 557 adapters. It looks like the 557 may have been a slightly better option.
Old 01-22-2021, 09:49 PM   #153
Mike_ZN6
Mike_ZN6's Avatar
Pic of it mounted?
The KMC tray mounts to this bracket:
You have to remove the bracket to secure the KMC tray to it. One of the bolts that attach the bracket to the car ends up being covered by the KMC tray. I ended up bending a 10mm IKEA box wrench I had so that it could fit under the tray and turn the bolt to attach the bracket.
Here are some pics of mine mounted up:
The Following 2 Users Say Thank You to Mike_ZN6 For This Useful Post:
SubieDoo (01-12-2022), Wally86 (01-21-2022)
Old 12-31-2023, 04:01 PM   #154
frs23
frs23's Avatar
Drives: FR-S H Lava
Not sure if this question has been asked but for the Shorai, about how long does it take to recharge battery from car alternator after one or two crank start attempts? I am asking this question to see if I get this setup, then if I have a few short drives will it need to recharge from a wall battery charger / tender.
frs23 is offline   Reply With Quote
Bad battery 5hairpins Issues | Warranty | Recalls / TSB 3 02-25-2013 11:01 AM
Help with Car Battery Synack Off-Topic Lounge [WARNING: NO POLITICS] 0 01-13-2013 11:05 PM
Winter: Electric car & battery warmer install JSUB BRZ First-Gen (2012+) — General Topics 2 12-26-2012 11:55 AM
Tips and Tricks: Disconnecting the Battery Necessary Post Intake Install? ScionFR-S Engine, Exhaust, Transmission 8 12-17-2012 06:39 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 04:59 PM
