Old 07-22-2012, 03:13 AM   #15
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
It seems he also sells other hardware to remotely lower the windows. A lot of people are interested in that too. Good find OP.
Old 07-22-2012, 11:46 AM   #16
sterile stork
Drives: 2011 Subaru STi
I have his Tap Turn I system, I used it in my STi, beautiful system and excellently put together. Nothing but positive remarks for his products.
sterile stork is offline   Reply With Quote
Old 07-22-2012, 12:04 PM   #17
thorlius
Canadian
Drives: Frieda: Firestorm/MT (11/28/2012)
Originally Posted by notFRS View Post
Any info on the install? Is it just a new relay you remove the stock one and add in the modified one?
I ordered it, but don't have it yet. Or the car, either. :happy0180:
He confirmed it should work based on the electrical diagrams, and yeah, apparently you just find the source of the tick sound, and replace the stock Denso module with his.
thorlius is offline   Reply With Quote
Old 07-23-2012, 08:35 AM   #18
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
Just placed an order for one. It will be nice to have the three blink tap feature on my BRZ. Since my GTI came with it I've grown to appreciate this feature.
Can't tell you how many times I've done a half blink lane change with my BRZ the past few weeks.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 07-23-2012, 09:09 AM   #19
KRAZYK
Self Entitled
KRAZYK's Avatar
Drives: 13' Red FR-S, 12' Toyota Tundra
This should work for the FR-S also right?
KRAZYK is offline   Reply With Quote
Old 07-23-2012, 11:42 AM   #20
DIE1000DEATHS
TechNINJA
DIE1000DEATHS's Avatar
Drives: Whiteout MT, 87 Mustang, 09 RUCKUS
Never had this on a vehicle, but am definitely GOING TO!. As far as his window modules, they look to integrate to the German cars only. Otherwise he utilizes DEI (known for owning Viper, Python, etc...) 530T window automation modules. This would require a bit more work than most people are probably comfortable with... I have installed these on all my vehicles to remotely roll up or down the windows, as well as using Field Disturbance, or Mass Sensors, to be able to arm the car with the windows down and roll them up when someone gets too close.
DIE1000DEATHS is offline   Reply With Quote
Old 07-23-2012, 12:12 PM   #21
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
If it works on our cars i want!
Lee358 is offline   Reply With Quote
Old 07-23-2012, 09:43 PM   #22
thorlius
Canadian
It should - the part should be the same one as that used by Subaru. Looks like the two companies use the same Denso flasher on most if not all of their lineups.
Old 07-23-2012, 09:52 PM   #23
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Ordered. Thanks again for the heads-up!
cobrabyte is offline   Reply With Quote
Old 07-24-2012, 07:39 AM   #24
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
Purchased as well. Thanks for the link.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 07-24-2012, 08:47 AM   #25
Paragon
Guest
Posts: n/a
can someone post a DIY when you get this just to show how hard/easy the install is?
Old 07-24-2012, 09:37 AM   #26
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Originally Posted by michaelahess View Post
Three flashes? Wow, that's far too short in my opinion. I have the signal on until the lane change is done. You folks must be trusting of other drives, assuming they actually pay attention!
I agree... The signal needs to indicate WHAT you're going to do in advance... Not what you are DOING!
Subaru STI :
Old 07-24-2012, 09:42 AM   #27
KRAZYK
Self Entitled
KRAZYK's Avatar
Says you can program it for more than 3 flashes if you want..
The 3 flash thing is just a common tap-flash configuration equiped in some cars and trucks. I had it in my last truck and loved it.. obviously there are times for it - and other times 3 isnt enough so you have to do it manually.
Old 07-24-2012, 10:07 AM   #28
Here's a thought I had. If other production vehicles have this, and its driven by the flasher, could you possible just purchase the flasher from one of those cars and plug it in, assuming it is plug compatible?
Turn signal lights Brzer Cosmetic Modification (Interior/Exterior/Lighting) 9 10-18-2012 01:36 PM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 03:32 AM
Turn Signal Repeaters Ben_G Cosmetic Modification (Interior/Exterior/Lighting) 1 06-22-2012 10:26 PM
FINALLY My Turn! Gaiakai Scion FR-S / Toyota 86 GT86 General Forum 10 06-12-2012 12:52 AM
