#3641 | |
Drives: 2014 WRB BRZ Limited
I did not inspect the banjo bolt or the slave cylinder for defects. Since I was going as fast as i could. I will check when i take it off. So if the bleeder is 6 oclock is yours at 4 or 5 so the shaft of the bolt doesn't touch the lip? Mine is likely touching the lip. That's a good point. Since it is leaking already I'll see if I can clock it a little further ccw to see if that helps. I'll go do that now. |
#3642 | |
Drives: 2016 Scion FR-S RS 2.0
Sent from my Pixel 3 XL using Tapatalk |
| The Following User Says Thank You to jayjay06 For This Useful Post: | BR-ZED (06-29-2020) |
#3643 | |
Drives: 2017 Toyota 86
Yes, I am using the oem fuel line crush washer on the edelbrock banjo and bolt. Someone else in this thread was doing the same. I'll go measure a spare OEM thickness for you later tonight and reply. If you go copper, you should get around the same thickness as what Edelbrock provides or around the OEM thickness. Dont think you're going to have too many choices here. Things to watch out for: washers which are too thin could leave more thread protruding which may bottom out the screw in the hole before the washers are compressed. Too thin could also place the banjo bolt fluid hole outside the banjo loop which could cause the washer to block the hole depending on the washer centering features of the bolt. Two thick can reduce thread engagememnt and strip threads. Usually these issues are caused by having the wrong banjo bolt and banjo combination so I really doubt you will have any issues. It always pays to be attentive to these kinds of details though |
| The Following User Says Thank You to Z06ZN6 For This Useful Post: | BR-ZED (06-29-2020) |
#3644 |
The OEM fuel line banjo crush washer is .040" (1mm) thick. Scratched through the silver coating and it looks like copper.
#3645 |
Awesome! Thanks! Glad to know the OEM part works on the Edelbrock banjo. That's probably the easiest path forward in case I leak. Thanks for your very helpful post above :-)
#3646 | |
I adjusted mine, took 2 to 3 tries because it kept slipping back to touch the ridge when torquing it down... finally got it at an angle I like. First pic: top view. Left us where I was, right is where it is now. You can see the ridge it was resting on is a little scuffed (could be abrasion, could be corrosion from brake fluid) Second pic. Side view, top is before, bottom is after. It does appear to rest on the lip before, almost seems slightly bent. Pic 3: clutch line. This is after the adjustment. Before it was coiled to touch the transmission... now it does NOT touch the transmission, which is good because I don't know how hot that gets. What's interesting if you clock the line at 6 oclock it will rest on that ridge, which seems like it will be an issue... I rebled the clutch, and then had it pumped about 20 times. No visible leaks. Will check again in the morning, repump it about 20 times, check, etc.. hopefully this fixes it... After bleeding the clutch (on the last bleed operation- 5 pumps, hold, bleed, release) pedal didn't come back by itself completely (had to be hand actuated about the last half of travel) but its fine now (comes back by itself) . Is that normal? Got a steady stream of fluid out of the bleeder each time, did it 4 or 5 times, so I don't know if there was even any air due to readjusting the clutch line. Last edited by BR-ZED; 06-29-2020 at 01:09 AM. Reason: Clarify |
#3647 | |
Clutch is working fine for me currently, although I'm on stock clutch and also did Delicious flex fuel, so getting some clutch slip I think (haven't really launched it too hard yet). I'm also on stock tires so taking bets on which one I have to replace first haha! Sent from my Pixel 3 XL using Tapatalk |
#3648 |
Drives: 2019 86 TRD SE
Got my tune and that made a huge difference.
![]() Only two problems. 1.) Keep getting an off P24B9 code, but everything runs perfect. UPDATE: Resolved P24B9 code by uninstalling D-Box. Reason for code still unknown. 2.) Still want more power. Guess its time to start looking into upgrading fuel system and slightly smaller pulley. Curious if anyone knows if these cars respond well to reworked heads or if that is a waste with the FI rout. Last edited by Glitch; 04-23-2021 at 12:32 PM. |
#3649 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Edelbrock SC MAP sensor re-locator. Nylon block with nylon fittings. All you need to do is build your harness and buy a second TMAP sensor. @BR-ZED and @phen8tk have claimed the first 2 so I have 2 left. Made from the left over material I had after making the prototype, which is currently installed on my bypass hose and performing flawlessly (now that I have a new style bypass valve installed). They have all been vacuum tested to -20 psi.
$10 (to cover material cost) + shipping (Ichi approved) Last edited by BirdTRD; 08-23-2021 at 05:52 PM. Reason: sp. |
| The Following User Says Thank You to BirdTRD For This Useful Post: | BR-ZED (06-29-2020) |
#3650 | ||
#3651 |
Simply Forgotus
Yeah, I was going to try your method of backing out the adjustment screw, counting turns and measuring the gap...but the screw snapped so I had to do it the Edelbrock way.
#3652 | |
What screw snapped? The original set screw when you tried to loosen it? |
#3653 | |
Simply Forgotus
Nope, just took the feeler gauge out of the set, it's screwed together. Yes, the set screw, looks like it had a stress fracture to begin with since there was rust inside where the break occurred. |
| The Following User Says Thank You to BirdTRD For This Useful Post: | BR-ZED (06-30-2020) |
#3654 | |
Drives: '14 Ultramarine Fr-S
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 11:09 PM |
