#911 |
Steve Bodalenko
Drives: Toyota 86 GTS
So which ones do you recommend? Cusco seem plentiful. Is there a specific model that fits. It’s mentioned at the start of this thread that the STI fits as well. Doesn’t supply the model number though..
#912 |
Drives: Q5 + BRZ + M796
STI is suppose to be best but whatever you like. They are cosmetic with a little effect.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Bodalenko (06-26-2020) |
#913 | |
Drives: RX-7 / BRZ
Here is Sti's sales pitch on their flexible bars. The tS BRZ models also include flexible V-braces. https://www.sti.jp/en/parts/feature/...etowerbar.html
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
| The Following User Says Thank You to Kiske For This Useful Post: | Bodalenko (06-27-2020) |
#914 | |
But as was pointed out above, the existing diagonal braces do the real work...and the strut brace is less significant (on the road at least). |
| The Following User Says Thank You to grumpysnapper For This Useful Post: | Bodalenko (06-28-2020) |
#915 |
Steve Bodalenko
Judging by the replies the Harrop doesn’t sit as high as I thought.I’ve settled for the basic Whiteline. If the effects are minimal I’m glad I spent as little as I did...
| The Following User Says Thank You to Bodalenko For This Useful Post: | grumpysnapper (06-28-2020) |
#916 |
Drives: 2013 Subaru BRZ "sti"
Still pending the CARB approval letter? I saw some posts about CARB saying the order is pending but no official document like which was released for Edelbrock kit.
#917 |
I’m sure it is delayed even more NOW because of coronavirus. Which posts are you referring to because they have been pending CARB for years?
#918 |
I added the Edelbrock coolant reservoir to my setup. I found that even though the fill plugs were topped off when I checked, there was still low coolant levels as I circulated the pump during this install. After adding a few cups worth of coolant, all the hoses felt much firmer. I'm sure there is still some air in the system, but considering the reservoir almost ran dry multiple times, I have to believe that this will be much better. I'm surprised it was this bad considering how many times I purged the system and topped off the fill plugs. Then again, I have custom coolant lines. By the temperature of the hoses, this setup seems to be circulating coolant much better.
The bracket and reservoir were solid pieces. I did file off the Edelbrock logo. My only complaint is the lid is the type where you over tighten it, and it jumps a thread and needs retightening, which leaves someone always feeling like it needs to be tighter. If it had a stronger locking cap and if it didn't purge air to the atmosphere, and instead, had a line I could 'T' into the existing coolant overflow reservoir then that would seem best. Overall, I am happy with the addition. ![]()
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | grumpysnapper (07-07-2020) |
#919 |
Very nicely done, looks great. The reservoir mod makes more sense to me now
![]() Interested on why (and how) you decided to re-route your coolant hoses? |
#920 |
Steve Bodalenko
Strange that Harrop haven't included this in their kits. Seems like a no brainer. If you did self install you know how much coolant you used. I had Harrop install mine so hop its at the right level. A clear reservoir would make it simple. Must be a work around for us in Oz. Buying a Edelbrock one here would probably be impossible or impossibly expensive.
What size pipe is used? |
#921 | ||
5/8 or 3/4. Whatever size is the piping that connects to the pump. I called up Edelbrock and ordered it through them. I have no idea if they would ship internationally or what that would cost.
| The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post: | Bodalenko (07-31-2020), grumpysnapper (07-07-2020) |
#922 | |
Drives: 2013 Black FR-S
| The Following User Says Thank You to sw20kosh For This Useful Post: | Irace86.2.0 (07-09-2020) |
#923 | |
My setup is different than stock, so it makes more sense to add this into my setup than for everyone to do this. I have the top two bleed holes and this, and it made a difference. https://imgur.com/1SbPvd2
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | sw20kosh (07-09-2020) |
#924 | |
Steve Bodalenko
| JDL turbo kit owners thread | yomny | Forced Induction | 1352 | 01-08-2025 05:20 AM |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 02:18 PM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 03:31 AM |
| Harrop car lip kit? | djdnz | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 12-15-2015 03:50 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 01:58 PM |
