#29 | |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Ugh, I guess I'll go make a video for those that don't believe |
| The Following User Says Thank You to RZNT4R For This Useful Post: | Yoshoobaroo (06-25-2020) |
#30 |
Wheels for Brains
@Schweiz
Might be a problem with idle/throttle learning. Reset the ECU by pulling the battery and waiting for a bit. The first time you start the car, start it cold and let the car idle by itself for ~10 minutes without any accessories or A/C on. See if that helps. If that doesn't help, try a reset again and do same as above, except run the AC while it is doing the idle learning. |
#31 | |
Drives: 2017 BRZ PP
#32 |
#33 |
Relearning idle speed without cleaning the throttle does nothing, because it's the same throttle and same engine, it'll idle at the same plate position, and if you've got a "step" of carbon/grime at that position, it'll constantly hunt around, as on the step the idle is too low, because it's not a smooth bore anymore, but a step, and above that step it'll idle too high.
#34 | |
Drives: 2017 BRZ PP
#35 |
Drives: FR-S,GTI
That doesn't prove anything.
It's the cycling of the compressor that causes the dip. If the compressor is engaged when the engine idles, the engine already is compensating for the extra load and runs smoothly. It's when the engine is idling and the compressor suddenly engages and loads down the engine is when you get the idle dip. Make another video. This time have the AC off and not in defrost with the engine idling. Now turn on the AC. You will hear the compressor engage and at the exact same time the idle will dip. I'll betcha. |
| The Following User Says Thank You to WNDSRFR For This Useful Post: | Yoshoobaroo (06-24-2020) |
#36 | |
Don't spray intake cleaner into it, rather, spray on a rag and wipe clean. Make sure to go around the bore and all the way behind the throttle plate. It's easier to unbolt it from the intake to reach the back easily, no need to take the coolant hoses off though, just get it loose to reach in, hold the plate open and make sure there's no buildup on the edge. |
| The Following User Says Thank You to RZNT4R For This Useful Post: | Schweiz (06-24-2020) |
#37 | |
Secondly, no, you got what you wanted, take the L. |
#38 | ||
Drives: 2017 BRZ PP
The video that @RZNT4R posted is exactly what my idle was like for the 200 miles after I replaced my battery, A/C or not. Don't know if that changes anything, I just wanted to make sure that was cleared up. |
#39 |
Drives: 2017 BRZ PP
Alright guys. I cleaned the throttle body and reset the ECU and went for a drive. At first the car was fine. Then after about 5 miles it started doing it again. Then randomly in the middle of the drive it went away. Then at the end of the drive it came back.
I recorded
, this time showing that the A/C is off. It shows the in-car voltmeter spazing out, and it shows me switching the cars lights off and on just for the problem to continue. Is this really just the stock tune? Or perhaps something like an alternator issue? Thanks for all your guys' help so far. |
| The Following User Says Thank You to Schweiz For This Useful Post: | humfrz (06-25-2020) |
#40 | |
If you attach the multimeter to the battery with the engine running and all power consuming accessories turned off (especially the A/C) does the multimeter show a fluctuation in voltage coming from the alternator? If so, you may wish to have the alternator bench tested. If not, I would look to have the ECU re-flashed or get a store bought tune. |
#41 | |
Drives: 2017 BRZ PP
#42 |
Drives: brz 2017 hksv2
it s the PI inietting at idle intermittently
steve99 explainef how to fix |
| Intermittent will not start | 333Matt | Issues | Warranty | Recalls / TSB | 11 | 10-24-2019 09:03 PM |
| Flashing and Intermittent CEL - HELP | MugsBRZ | Issues | Warranty | Recalls / TSB | 7 | 10-19-2016 12:56 PM |
| Intermittent Over Heating | Deep Six | Issues | Warranty | Recalls / TSB | 6 | 12-16-2014 10:22 AM |
| Canadian Intermittent RPM dip? | VirUzxZ | CANADA | 23 | 06-24-2014 03:16 PM |
| Acceleration Lag - Intermittent | donnyk | CANADA | 6 | 07-18-2013 12:53 AM |
